08-07-2016, 07:57 PM
Input:
Clear the registers/finance registers
Press [ g ] (GTO) 00 to get the pointer to line 00. (000 for the HP 12C Platinum editions. Remember, the Platinum editions have up to 400 steps and line numbers are in triple digits)
Store -1 in [ n ] (don’t worry, n is incremented in the main loop)
Store periodic interest rate in [ i ].
Store 0 in register 0 (0 [STO] [ 0 ]). Register 0 is use for calculating NPV
Enter each cash flow one at a time, and press [R/S].
Ready to calculate:
Press [ g ] (GTO) 10 (or 010) to get the pointer to line 10.
Press [R/S] to get NPV (net present value)
Press [R/S] to get NFV (net future value)
Press [R/S] to get NUS (net utility stream)
Program:
Example:
Rate: 15%
Cash Flow # Flow
0 -10,000.00
1 2500.00
2 3500.00
3 5000.00
4 5000.00
Input:
[ f ] CLEAR FIN, [ f ] CLEAR PRGM
-1 [ n ] // do this on each new problem
0 [STO] [ 0 ] // do this on each new problem
15 [ i ]
10000 [CHS] [R/S]
2500 [R/S]
3500 [R/S]
5000 [R/S]
5000 [R/S]
Results:
[GTO] 10 [R/S]: NPV = 966.76
[R/S]: NFV = 1690.88
[R/S]: NUS = 338.62
Input slowly and carefully.
This blog entry is property of Edward Shore, 2016.
Ready to calculate:
Program:
STEP CODE KEY
01 16 CHS // main loop: input data
02 15 FV
03 45, 11 RCL n
04 1 1
05 40 +
06 11 n
07 13 PV
08 44, 40, 0 STO+ 0
09 43, 33, 0 GTO 00 // finish main loop
10 45, 0 RCL 0 // calculation part
11 31 R/S // net present value
12 1 1
13 16 CHS
14 13 PV
15 0 0
16 14 PMT
17 15 FV
18 45, 0 RCL 0
19 20 *
20 31 R/S // net future value
21 45, 0 RCL 0
22 1 1
23 16 CHS
24 14 PMT
25 0 0
26 15 FV
27 13 PV
28 10 ÷
29 31 R/S // net utility stream
Example:
Rate: 15%
Cash Flow # Flow
0 -10,000.00
1 2500.00
2 3500.00
3 5000.00
4 5000.00
Input:
15 [ i ]
10000 [CHS] [R/S]
2500 [R/S]
3500 [R/S]
5000 [R/S]
5000 [R/S]
Results:
[R/S]: NUS = 338.62
