07-15-2016, 08:21 AM
To those of you who own a 50g and use an SD card, I have 3 questions:
1. Does the SD card speed matter? Is there any discernible speed difference between the cheapest SD card available versus a fast card? (I am thinking about getting a 1GB card. I assume this is a better way to transfer to/from a computer than using USB connectivity (Hoppi/KERMIT), correct? I use a Mac.)
2. The HP 50g User's Guide says, "The HP 50g will only work with cards in the FAT16 or FAT32 format." but this HP Forum thread says, "If you place a new SD card into the HP 50g and it is not recognized, it should probably be reformatted under FAT16." This appears to be conflicting information. What is correct?
3. Rather than key-in long text notes on the calculator, is it possible to save notes as a *.txt file via PC to the SD card, then insert the SD in the calculator and either use the notes directly off the SD or save them (STO) to internal memory?
Thank you.
Thank you.
