07-15-2016, 01:21 AM
07-15-2016, 02:20 AM
Mine returns the correct solution. I've tried it with several different settings for handling complex solutions (since you're using csolve), and I still get the right answer.
07-15-2016, 06:09 AM
I first get the same result as you but I had something assigned to x. After purge(x) I got the correct result.
07-15-2016, 12:28 PM
07-15-2016, 03:11 PM
(07-15-2016 06:09 AM)Didier Lachieze Wrote: [ -> ]I first get the same result as you but I had something assigned to x. After purge(x) I got the correct result.I've fallen for this trap when I was new to Maple. Drove me insane, but it has to work this way.
07-15-2016, 10:37 PM
Dear people, you are right.
Since I have a lot of program in my HP Prime (also in the emulator), always I run the calculator (for example in mi PC), it creats all the variables of the programs again.
So "x" has a specific value. When I go to the memory and clear all CAS variables, Matrixes & Lists; the equation gives the correct solution.
We hope the devs soon realease another firmware with more features
