02-11-2014, 07:15 PM
The firmware still needs a lot of work, this is only a test. Also I still don't decide if to use a very cheap 433/333 mhz RF module or just a plain 2.4ghz one.
#include <Usb.h>
#define EP_MAXPKTSIZE 64 // max size for data via USB
#define EP_INTERRUPT 0x03
#define HID_REQUEST_GET_REPORT 0x01
#define HID_REQUEST_SET_REPORT 0x09
#define PRIME_MAX_ENDPOINTS 2
#define PRIME_CONTROL_PIPE 0
#define PRIME_OUTPUT_PIPE 1
#define PRIME_INPUT_PIPE 2
#define PRIME_REPORT_BUFFER_SIZE 64
#define PRIME_VID 1008
#define PRIME_PID 1089
#define DEBUG_USB_HOST
class PrimeUsb:USBDeviceConfig
public:
PrimeUsb (USB*);
virtual uint8_t Init(uint8_t parent, uint8_t port, bool lowspeed);
virtual uint8_t Release();
virtual uint8_t Poll();
virtual uint8_t GetAddress() { return bAddress; };
void attachOnInit(void (*funcOnInit)(void)) { pFuncOnInit = funcOnInit; };
bool PrimeConnected;
protected:
USB *pUsb;
uint8_t bAddress;
EpInfo epInfo[PRIME_MAX_ENDPOINTS];
private:
void onInit();
void (*pFuncOnInit)(void); // Pointer to function called in onInit()
bool bPollEnable;
uint32_t timer;
uint8_t readBuf[EP_MAXPKTSIZE]; // General purpose buffer for input data
uint8_t writeBuf[EP_MAXPKTSIZE]; // General purpose buffer for output data
void readReport(); // read incoming data
void printReport(); // print incoming date - Uncomment for debugging
PrimeUsb::PrimeUsb (USB *p):pUsb(p)
for(uint8_t i = 0; i < PRIME_MAX_ENDPOINTS; i++) {
epInfo[i].epAddr = 0;
epInfo[i].maxPktSize = (i) ? 0 : 8;
epInfo[i].epAttribs = 0;
epInfo[i].bmNakPower = (i) ? USB_NAK_NOWAIT : USB_NAK_MAX_POWER;
if(pUsb) // register in USB subsystem
pUsb->RegisterDeviceClass(this); //set devConfig[] entry
void PrimeUsb::onInit() {
/*if(pFuncOnInit)
pFuncOnInit(); // Call the user function*/
/* Performs a cleanup after failed Init() attempt */
uint8_t PrimeUsb::Release() {
PrimeConnected = false;
pUsb->GetAddressPool().FreeAddress(bAddress);
bAddress = 0;
bPollEnable = false;
return 0;
uint8_t test[EP_MAXPKTSIZE] =
0x00, 0xF2, 0x01, 0x00, 0x00, 0x00, 0x0C, 0x48, 0x00, 0x45, 0x00, 0x4C, 0x00, 0x4C, 0x00, 0x4F,
0x00, 0x00, 0x00, 0x31, 0x78, 0x5E, 0x27, 0x31, 0x06, 0x10, 0x00, 0x00, 0xF0, 0x95, 0x37, 0x30,
0x14, 0x91, 0x6D, 0x31, 0x94, 0x90, 0x6D, 0x31, 0x94, 0x91, 0x6D, 0x31, 0xE4, 0x91, 0x6D, 0x31,
0x00, 0x4E, 0x27, 0x31, 0x74, 0x5E, 0x27, 0x31, 0x78, 0x5E, 0x27, 0x31, 0x00, 0x00, 0x00, 0x00,
uint8_t PrimeUsb::Poll() {
if(!bPollEnable)
return 0;
if(PrimeConnected)
uint16_t BUFFER_SIZE = EP_MAXPKTSIZE;
pUsb->inTransfer(bAddress, epInfo[ PRIME_INPUT_PIPE ].epAddr, &BUFFER_SIZE, readBuf); // input on endpoint 1
if(millis() - timer > 100)
{ // Loop 100ms before processing data
readReport();
printReport();
if(millis() - timer > 4000) { // Send at least every 4th second
Notify(PSTR("\r\nPreparing..."), 0x80);
pUsb->outTransfer(bAddress, epInfo[ PRIME_OUTPUT_PIPE ].epAddr, EP_MAXPKTSIZE, test);
timer = millis();
Notify(PSTR("\r\nSending report..."), 0x80);
void PrimeUsb::readReport() {
//ButtonState = (uint32_t)(readBuf[2] | ((uint16_t)readBuf[3] << 8) | ((uint32_t)readBuf[4] << 16));
Notify(PSTR("\r\nReading report..."), 0x80);
void PrimeUsb::printReport() {
for(uint8_t i = 0; i < PRIME_REPORT_BUFFER_SIZE; i++) {
D_PrintHex<uint8_t > (readBuf[i], 0x80);
Notify(PSTR(" "), 0x80);
Notify(PSTR("\r\n"), 0x80);
uint8_t PrimeUsb::Init(uint8_t parent, uint8_t port, bool lowspeed) {
uint8_t buf[sizeof (USB_DEVICE_DESCRIPTOR)];
USB_DEVICE_DESCRIPTOR * udd = reinterpret_cast<USB_DEVICE_DESCRIPTOR*>(buf);
uint8_t rcode;
UsbDevice *p = NULL;
EpInfo *oldep_ptr = NULL;
uint16_t PID;
uint16_t VID;
// get memory address of USB device address pool
AddressPool &addrPool = pUsb->GetAddressPool();
#ifdef DEBUG_USB_HOST
Notify(PSTR("\r\nPrime Init"), 0x80);
#endif
// check if address has already been assigned to an instance
if(bAddress) {
Notify(PSTR("\r\nAddress in use"), 0x80);
#endif
return USB_ERROR_CLASS_INSTANCE_ALREADY_IN_USE;
// Get pointer to pseudo device with address 0 assigned
p = addrPool.GetUsbDevicePtr(0);
if(!p) {
Notify(PSTR("\r\nAddress not found"), 0x80);
#endif
return USB_ERROR_ADDRESS_NOT_FOUND_IN_POOL;
if(!p->epinfo) {
Notify(PSTR("\r\nepinfo is null"), 0x80);
#endif
return USB_ERROR_EPINFO_IS_NULL;
// Save old pointer to EP_RECORD of address 0
oldep_ptr = p->epinfo;
// Temporary assign new pointer to epInfo to p->epinfo in order to avoid toggle inconsistence
p->epinfo = epInfo;
p->lowspeed = lowspeed;
// Get device descriptor
rcode = pUsb->getDevDescr(0, 0, sizeof (USB_DEVICE_DESCRIPTOR), (uint8_t*)buf); // Get device descriptor - addr, ep, nbytes, data
// Restore p->epinfo
p->epinfo = oldep_ptr;
if(rcode)
goto FailGetDevDescr;
VID = udd->idVendor;
PID = udd->idProduct;
if(VID != PRIME_VID || PID != PRIME_PID)
goto FailUnknownDevice;
// We are connected
PrimeConnected = true;
// Allocate new address according to device class
bAddress = addrPool.AllocAddress(parent, false, port);
if(!bAddress)
return USB_ERROR_OUT_OF_ADDRESS_SPACE_IN_POOL;
// Extract Max Packet Size from device descriptor
epInfo[0].maxPktSize = udd->bMaxPacketSize0;
// Assign new address to the device
rcode = pUsb->setAddr(0, 0, bAddress);
if(rcode) {
p->lowspeed = false;
addrPool.FreeAddress(bAddress);
bAddress = 0;
Notify(PSTR("\r\nsetAddr: "), 0x80);
D_PrintHex<uint8_t > (rcode, 0x80);
#endif
return rcode;
#ifdef EXTRADEBUG
Notify(PSTR("\r\nAddr: "), 0x80);
D_PrintHex<uint8_t > (bAddress, 0x80);
#endif
//delay(300); // Spec says you should wait at least 200ms
//get pointer to assigned address record
p = addrPool.GetUsbDevicePtr(bAddress);
if(!p)
// Assign epInfo to epinfo pointer - only EP0 is known
rcode = pUsb->setEpInfoEntry(bAddress, 1, epInfo);
if(rcode)
goto FailSetDevTblEntry;
/* Initialize data structures for endpoints of device */
epInfo[ PRIME_OUTPUT_PIPE ].epAddr = 0x2; // output endpoint
epInfo[ PRIME_OUTPUT_PIPE ].epAttribs = EP_INTERRUPT;
epInfo[ PRIME_OUTPUT_PIPE ].bmNakPower = USB_NAK_NOWAIT; // Only poll once for interrupt endpoints
epInfo[ PRIME_OUTPUT_PIPE ].maxPktSize = EP_MAXPKTSIZE;
epInfo[ PRIME_OUTPUT_PIPE ].bmSndToggle = 0;
epInfo[ PRIME_OUTPUT_PIPE ].bmRcvToggle = 0;
epInfo[ PRIME_INPUT_PIPE ].epAddr = 0x01; // report endpoint
epInfo[ PRIME_INPUT_PIPE ].epAttribs = EP_INTERRUPT;
epInfo[ PRIME_INPUT_PIPE ].bmNakPower = USB_NAK_NOWAIT; // Only poll once for interrupt endpoints
epInfo[ PRIME_INPUT_PIPE ].maxPktSize = EP_MAXPKTSIZE;
epInfo[ PRIME_INPUT_PIPE ].bmSndToggle = 0;
epInfo[ PRIME_INPUT_PIPE ].bmRcvToggle = 0;
rcode = pUsb->setEpInfoEntry(bAddress, 3, epInfo);
if(rcode)
delay(200); //Give time for address change
rcode = pUsb->setConf(bAddress, epInfo[ PRIME_CONTROL_PIPE ].epAddr, 1);
if(rcode)
goto FailSetConfDescr;
Serial.println("here");
onInit();
bPollEnable = true;
timer = millis();
return 0; // Successful configuration
/* Diagnostic messages */
FailGetDevDescr:
NotifyFailGetDevDescr();
goto Fail;
#endif
FailSetDevTblEntry:
NotifyFailSetDevTblEntry();
goto Fail;
#endif
FailSetConfDescr:
NotifyFailSetConfDescr();
#endif
goto Fail;
FailUnknownDevice:
NotifyFailUnknownDevice(VID, PID);
#endif
rcode = USB_DEV_CONFIG_ERROR_DEVICE_NOT_SUPPORTED;
Fail:
Notify(PSTR("\r\nInit Failed, error code: "), 0x80);
NotifyFail(rcode);
#endif
Release();
return rcode;
USB Usb;
PrimeUsb myPrime(&Usb);
void setup()
Serial.begin(115200);
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nPrime USB Library Started"));
void loop()
Usb.Task();
