Full Version: Bugs with "Copy" soft key in CAS mode
I've noticed two bugs with the "Copy" soft-key in CAS mode:
- when i try to copy a command that contains a number in scientific notation, the result is this:
[attachment=3714]
Sometimes the command is still accepted, sometimes no.
- when i try to copy a command that contains a *(i don't know how it's called)* this is the result:
[attachment=3715]
This is quite annoying, especially with large formulas.
Is there a way to solve this?
The first one seems to work on the latest firmware.
Cyrille
What do you mean? You can't reproduce it or the command is still accepted? On which firmware?
