How do you use format to format numbers into strings?
EXPORT HOWFMT()
MSGBOX(format(9.3456,"s3"));
Gives a bad argument error.
(06-29-2016 09:41 PM)StephenG1CMZ Wrote: [ -> ]How do you use format to format numbers into strings?
The format command is a CAS command which Home doesn't know how to handle. So use
CAS(format(9.3456,"s3")) when using it in a non-CAS program.
Try:
EXPORT HOWFMT()
MSGBOX(format(9.3456,QUOTE("s3")));
-road
Thanks, both of those worked. I had tried CAS.format() instead of CAS(format()).
(06-30-2016 07:12 AM)StephenG1CMZ Wrote: [ -> ]Thanks, both of those worked. I had tried CAS.format() instead of CAS(format()).
When should I use CAS.
command and when should I use CAS(
command) ?
Tom L
