02-10-2014, 01:49 AM
If you press Edit (or start typing something) in the Symb screen:
You get "edition" menu options:
But if you tap a field, you still can input a sentence but the menu does not change, the Edit menu and the check menu (the square root char used as 'toggle' button) don't work either:
