02-09-2014, 02:04 AM
Is it possible to improve upon my current method of storing and writing equations and expressions for use during an exam for use in the solver application. I also want to delete the old variables, so there are no conflicts.
I work with about 6-7 equations per topic, which i need to reuse often, especially during an exam, therefore i need to be able to store these equations for quick access.
Process:
While this works, it is cumbersome and takes some time to delete all the variables and assign each object. I was thinking that some sort of list i can copy and paste into the stack such as {E1:=a=b+c, E2:=c=d+e, E3:=e=f+g}...
To be honest, I use a great program called PEQUM for the HP 50G, though its not available for the prime
Thank you,
Rich
Unnecessary but extra information...
I need to evaluate a variable numerically and often in terms of another variable with respect to all other equations. I need to be able to take the solutions to these in terms of a differential equation represented numerically and a general solution.
Process:
- Create a Note that lists all of the equations on a topic.
- Go to Shift -> Mem to delete all variables and assignments that I will be using. (Not sure if this is necessary)
- I copy and paste each equation that I need onto the stack
- I then use the assignment operator := to assign them to E1, E2, E3... etc. I then use the Solver application
- The solver app then asks me to create each variable if it is not defined.
Thank you,
Rich
