06-18-2016, 01:50 AM
Hi all,
The 67 calculator/emulator finally came to life today. Its been quite a task to debug the actual calculator as the firmware has become quite complex. The image (if it appears) is showing the calculator asking to load the second card of a 2 card program.
I have added a ASCII text based program card editor to the PC emulator. It will load/save HP65 and HP67 programs and allow editing. It will also format them into *.hpp files and can be saved and then loaded directly into the PC emulator and the hardware calculator as program cards.
I have had a brief look around with not much success and as I have limited access to internet at this remote location, does anyone have a real two card 67 program that is text based, or a link to one? I would like to try it out to verify that everything works ok from text to running in the calculator.
cheers
Tony
cheers
Tony
