1: In the first version of the CAS of hpprime, I suggested control the exit (simplify none, minimum, maximum), my request was accepted, to port some good programs that I have, I need also the output controlled from a program
simplifyFlag (arg);
arg = 0 -> none
arg = 1 -> minimum
arg = 2 -> maximum
2: also I need entries are not rewritten or simplified
for example, the followings line of code, the logic says must be true and not false
getOperator:=0;
_________________________
part(x^(1/2),getOperator)=="^"; -> true ok
part(√(x),getOperator)=="√"; -> false ?
part(1/x),getOperator)=="/"; -> false ?
part(inv(x),getOperator)=="inv"; -> true ok
part(cot(x)),getOperator)=="cot"; -> false ?
part(sec(x)),getOperator)=="sec"; -> false ? sec(x)=1/cos(x)
part(asec(x)),getOperator)=="asec"; -> false ?
part(acos((1/x)),getOperator)=="acos"; -> true ok
part((x^3/x^2),0))=="/"; -> false ?
sqrt(x) is evaled to pow(x,1/2) and 1/x to inv(x)
expressions rewrite alters the domains of expressions in many cases, rewrite the expressions is difficult to identify entry
fabulous if you can include a flag, so that the entries are not evaluated, at least in xcas
for example I want to know what the numerator and denominator of the following expression 'x^3/x^2', to make a symbolic derivation step as didactic project from my university, unfortunately this is evaluated as X =(
the following code will never be executed, the CAS hpprime is good, but does not allow me to do I want,
with simple improvements could be the best CAS on calculators, the hp48/50 calculator retains the inputs to run obj-> that is similar to PART function (see PART FUNCTION on HP48/50)
http://www.hpmuseum.org/forum/thread-6377.html)
if (operator=="/") then
Return (part2*diff_table(part1,var)-part1*diff_table(part2,var))/(part2^2);
end;
∂(x^3/x^2,x) -> ((x^2*∂(x^3,x))-(x^3*∂(x^2,x)))/x^2^2 -> 1
// version 0.2 Jun 6 2016 by COMPSYSTEMS COPYLEFT inv(©)
#cas
diff_table(xpr,var):=
LOCAL nparts, operator, part1, part2;
LOCAL xprSameVar;
//CASE 1: if the expression is a variable name or identifier
if (type(xpr)==DOM_IDENT) then
// CASE 2: if the expression is equal to the variable, example diff(x,x)=1, otherwise diff(x,y)=0
return when(xpr==var,1,0);
end;
// number of parts of the expression
nparts:=part(xpr);
//operator
operator:=part(xpr,0);
end;
quote() prevents evaluation.
very well
but It requires placing parenthesis '()' IT IS A PROBLEM OF HISTORY VIEW?
please follow the following...
simplify maximum, '' = [()] KEY
x^3/x^2 input returns x^3/x^2 , outpu returns x OK
'x^3/x^2' returns ERROR
with '()'
'(x^3/x^2)' input returns 'x^3/x^2' OK
also if I write quote (x^3/x^2) [enter], then under the input, to entry line also generates an error
(06-08-2016 08:55 PM)compsystems Wrote: [ -> ]but It requires placing parenthesis '()' IT IS A PROBLEM OF HISTORY VIEW?
No, it is a problem of ' being used for "stop evaluation by quoting the object" (legacy HP usage) and ' being used for taking a derivative (CAS useage).
It works fine provided you aren't touching your ' directly. Add a space before/after and your are fine.
Other simple solution is to not alloy x^2' as syntax for a derivative... :-|
try again
quote (x^3 / x^2) [enter] '(x^3/x^2)' ok
then up to history and copy the entry into the input line [enter] -> ERROR SINTAX '(x^3/x^2')
this moving a quotation mark (right) outside the brackets '(x^3/x^2')
your agree with the problem?
including a space at the beginning works, but to copy the expression to the input line fails
' + [SPC] + x^3/x^2 + ' [ENTER] '(x^3/x^2)' ok
for Bernard
getOperator:=0;
part1:=1;
part2:=2;
part(x^3/x^2); -> part(x^3 * 1/x^2) -> returns 2 OK
part(x^3/x^2,getOperator); -> part(x^3 * 1/x^2,0) -> returns "*" OK
part(x^3/x^2,part1); -> part(x^3 * 1/x^2, 1) -> returns x^3 OK
part(x^3/x^2,part2); -> part(x^3 * 1/x^2, 2) -> returns 1/x^2 OK
now
part(quote(x^3/x^2)); -> part( '(x^3 / x^2)' ); -> returns 2 OK
part(quote(x^3/x^2),getOperator); -> part( '(x^3 / x^2)', 0 ); -> returns "/" OK OK
part(quote(x^3/x^2),part1); -> part( '(x^3 / x^2)', 1 ); -> returns x^3 OK
part(quote(x^3/x^2),part2); -> part( '(x^3 / x^2)', 2 ); -> returns x^2 OK
but
expr1:=quote(x^3/x^2) ;
part(expr1); -> part( '(x^3 / x^2)' ) -> returns 2 OK
part(expr1,getOperator); -> part( '(x^3 / x^2)', 0 ); -> returns "*" ???????????
part(expr1,part1); -> part( '(x^3 / x^2)', 1 ); -> returns x^3 OK
part(expr1,part2); -> part( '(x^3 / x^2)', 2 ); -> returns 1/x^2 ???????????
Evaluation replaces division by *inv()
For quoting, you can use the quote() function to avoid confusion with ' derivative
quote apparently is not working
Try this again and tells me
within a program ...
getOperator:=0;
part1:=1;
part2:=2;
part(expr1); ->returns 2 OK
part(expr1,getOperator); -> returns "*" ??? must be "/"
part(expr1,part1); -> returns x^3 OK
part(expr1,part2); -> returns 1/x^2 ??? ??? must be x^2
That's because part does not quote it's arguments, they are evaluated.
but this makes useless the QUOTE command, the expression must be preserved, which proposes solution to code my problem?, it is possible with the CAS language of HPprime or not?
the idea is to store the math expressions as identifiers, they are part of the arguments of a function, also as inserted an expression into an argument if this can change
You should not try to prevent evaluation and live with the fact that some operations are rewritten differently after evaluation. Think of *inv() as a division, +neg() as a substraction and pow(.,1/2) as a sqrt. This should not change much a derivation program, in fact there are a little less rules to write.
sorry for my bad English, I hope you can understand
>> it is true, it is possible for many cases, the idea is to show step by step the partial derivation for program educational, not intend to show the final answer, the only way is keeping the entry as entered, for example: ∂(x^3/x^2,x) -> "((x^2*∂(x^3,x))-(x^3*∂(x^2,x)))/x^2^2" y not "1"
the QUOTE instruction loses all his power, when the argument is an identifier that contains a symbolic expression.
[challenge] please can improve your command at least xcas?
QUOTE (expr) -> 'expr'
I think adding a new data type
type ('expr') -> DOM_unmodifiedSYMBOLIC
I think that would be the only "cas" that allow you to manipulate expressions, ideal for developing programs step by step, I want to write programs similar to those that are in
http://www.tinspireapps.com but free
But you can already write that kind of programs. It will just require adaptations, if you want to recognize a quotient for example you must first find a root node * then look in the arguments for an inv, and if you find one (or more) collect them into what will be your denominator. For sqrt, you don't have anything special to do, the rule for pow is OK (it is also for *inv() but this will not be exactly the rule that is usually teached, at least in France).
What am I doing wrong so that the following code does not work?
#cas
prg_cas(xpr):=
local getOperator, part1, part2, expr1;
getOperator:=0;
part1:=1;
part2:=2;
print("original input: " + xpr); wait; // x^3/x^2 // OK
print("with '': " + quote(xpr)); wait;
expr1:=quote(xpr);
print("with '' and stored in ID: " + expr1); wait;
print("operator: "+ part(quote(xpr),getOperator) ); wait;
print("operator: "+ part(quote(expr1),0) ); wait;
print("part1: "+ part(quote(expr1),part1) ); wait;
print("part1: "+ part(quote(xpr),part1) ); wait;
print("part2: "+ part(quote(xpr),part2) ); wait;
#end
prg_cas((x^3/x^2)) [ENTER]
you can't use quote on a variable name you want to evaluate.
You shoud use part(eval(.,1),.)
for example
a:=quote(sqrt(x));
part(eval(a,1),0);
will return sqrt
I can not find documentation of the EVAL command, which means the second argument of EVAL
part( eval(a,
1), 0);
The following code, why not call QUOTE to xpr ID or argument of p1(xpr)?
#cas
p1(xpr):=
getOperator:=0;
part1:=1;
part2:=2;
print( "original input: " + xpr ); wait; // retunrs x^3/x^2, PRINT recall xpr ID, OK
print( ": " + 3*xpr*6 ); wait; // returns 3*x^3/x^2*6, PRINT also recall xpr ID, OK
print( ": " + collect(3*xpr*6) ); wait; // returns 18*x, OK
print( "with '': " + quote(xpr) ); wait; // returns xpr ??, why not call QUOTE to xpr ID?
print( "with ' ' and eval external: " + eval(quote(xpr)) ); wait; // returns x^3/x^2 OK
print( "with ' ' and eval internal:'': " + quote(eval(xpr)) ); wait; // returns eval(xpr) ??
#end
