Hi I try to get a formula working on my Prime. I cannot find in the user manual how to do it. Any help appreciated.
It keeps giving input syntax errors. I tried to drop the % and even one character variabels but it is not working.
Formula Ceq= %C+((%Mn+%Si)/6)+((%Cr+%Mo+%V)/5)+((%Ni+%Cu)/15)
Just want a list to fill-in the available variables
(06-08-2016 11:18 AM)TopQ Wrote: [ -> ]Hi I try to get a formula working on my Prime. ...
try:
Ceq := C+((Mn+Si)/6)+((Cr+Mo+V)/5)+((Ni+Cu)/15)
to assign something to a variable use :=
don't use %
Dear Salvomic
Thank you for your gesture, but Double variables like Mn, Si, etc are giving a sytaxerror. I can change Mn to M and Si to S, But will get problems with C an Cu.
I tried to use a spreadsheet instaid, but as soon I type Si in a cell the complete HP connection program on my PC shuts down due to an error.
Is there a simple way to type a formula and get a list of variables to fill in, or do I have to make a program for it?
I forgot to say that if you are in Home upper case variables are reserved, so the Prime tries to do (i.e.) C*u and you get an error, in command line.
You can use that expression in a program or in CAS (if every variable is defined)...
Thank you. that solved the problem
