(06-06-2016 05:04 PM)Thomas_Sch Wrote: [ -> ]I'm curious: Why you are trying to copy a comment to the entry line?
on the ENTRY line also you can create CAS programs
______________________________________________
f1(x,y,z):=BEGIN local, v1,v2,v3; return x+y+z; END; [enter]
then you can edit the program
[Shift]+[Tools](Mem)
then go to "CAS VARS" ITEM
select f1 [EDIT] [EDIT]
the edition appears in a
new entry line, should be on full display for easy coding, note that if you paste // the interpreted as a double division and not as a comment also found another problem , the comments disappear when edited and loss of information
I like to comment on my programs, other absolutely not
// version 0.1 Jun 5 2016 by COMPSYSTEMS
#cas
diff_table(xpr,var):=
LOCAL nparts, operator, part1, part2;
print("");
//CASE 1: if the expression is a variable name or identifier
if (type(xpr)==DOM_IDENT) then
// CASE 2: if the expression is equal to the variable, example diff(x,x)=1, otherwise diff(x,y)=0
return when(xpr==var,1,0);
end;
// number of parts of the expression
nparts:=part(xpr);
//operator
operator:=part(xpr,0);
//CASE 3: diff(k,v)=0
//print(nparts); print(operator); wait;
if (nparts==0) then
return 0; // xpr=pi, i, numbers
end;
if (nparts>1) then
part1:=part(xpr,1);
part2:=part(xpr,2);
print(part1);print(part2);wait;
else
part1:=part(xpr,1);
print(part1); wait;
end;
//CASE 4: diff(-f(v),v)=0 // NEG(xpr)
if (operator=="-") then
return -1*diff_table(part1,var);
end;
//CASE 5: diff(k*f(v),v)=0 // NEG(xpr)
if (operator="*" and type(part1)==DOM_INT) then
return part1*diff_table(part2,var);
end;
//CASE 6: diff(|f(v)|,v) with f(v)=v
if (operator=="abs" and string(part1)==string(var)) then
return sign(var); // assuming a function from R -> R
//return var/abs(var); // Alternate Form
end;
//CASE 7: diff(|f(v)|,v)
if (operator=="abs" and string(part1)≠string(var)) then
return sign(var)*diff_table(part1,var);
end;
// //CASE 8: diff(√(f(v)),v)
// if operator=="√" and string(part1)==string(var) then
// return 1/(2*√(var));
// end;
// //CASE 9: diff(√(v),v)
// if operator=="√" and string(part1)≠string(var) then
// return diff_table(part1,var)/(2*√(var));
// end;
//CASE 8: diff(ln(v),v)
if (operator=="ln" and string(part1)==string(var)) then
return 1/var;
end;
//CASE 9: diff(ln(f(v)),v)
if (operator=="ln" and string(part1)≠string(var)) then
return diff_table(part1,var)/part1;
end;
//fun.trig
//CASE 10: diff(sin(v),v)
if operator="sin" and string(part1)==string(var) then
return cos(var);
end;
//CASE 11: diff(sin(f(v)),v)
if operator="sin" and string(part1)≠string(var) then
return cos(part1)*deriv(p1,var);
end;
//CASE 12: diff(cos(v),v)
if operator="cos" and string(part1)==string(var) then
return sin(var);
end;
//CASE 13: diff(cos(f(v)),v)
if operator="cos" and string(part1)≠string(var) then
return sin(part1)*deriv(part1,var);
end;
//CASE 14: diff(tan(v),v)
if operator="tan" and string(part1)==string(var) then
return sec(var)^2 ;
end;
//CASE 15: diff(tan(f(v)),v)
if operator="tan" and string(p1)≠string(var) then
return sec(part1)^2*deriv(part1,var);
end;
// codifying
return Done;
#end
Attached image view, comments disappear in this "windows", impossible uncomment, comments serve to not execute code while the code is created
