05-26-2016, 05:10 PM
Syntax:
part(Expr, Integer)
Returns the nth sub expression of an expression. If the second argument is empty, returns the number of parts.
If the second argument is ZERO, returns the operator if any, otherwise returns the same expression as string
samples OK
part(sin(x)+cos(y)) → 2 // two parts sin(x) & cos(y)
part(sin(x)+cos(y),1) → sin(x) // first part
part(sin(x)+cos(y),2) → cos(y) // second part
part(sin(x)+cos(y),3) → "nonexistent part in the expression"
part(sin(x)+cos(y),0) → "+" // operator between parts
part( part(sin(x)+cos(y),1)) → 1 // number of parts of the first part
part( part(sin(x)+cos(y),2)) → 1 // number of parts of the second part
part( part(sin(x)+cos(y),1),1) → x // firts part of the firts part, sin(x)→ x
part( part(sin(x)+cos(y),2),1) → y // firts part of the second part, cos(y)→ y
part( part(sin(x)+cos(y),1),0) → "sin" // operator of the firts part, sin(x)→ "sin"
part( part(sin(x)+cos(y),2),0) → "cos" // operator of the second part, cos(x)→ "cos"
part(sin(x)) → 1 // one part
part(sin(x),1) → x // first part
part(sin(x),0) → "sin" // operator "sin"
part(part(exp(x)*sin(x) + cos(x),1),2) → sin(x) // second part of the first part exp(x)*sin(x) → sin(x)
part(part(exp(x)*sin(x) + cos(x),1),0) → "*" // operator of the first part exp(x)*sin(x) → "*"
part(part(exp(x)*sin(x) + cos(x),2),0) → "cos" // operator of the second part cos(x)→ "cos"
part(part(exp(x)*sin(x) + cos(x),2),1) → "x"
part(part(exp(x)*sin(x) + cos(x),1)) → 2
part(part(exp(x)*sin(x) + cos(x),1),1) → exp(x)
part(part(part(e^x*sin(x) + cos(x),1),1),1) → x
part(part(part(e^x*sin(x) + cos(x),1),1),0) → "exp"
special cases
part(-X) → 1 // one parts
part(-X,1) → 1 // firts part, X
part(-X,0) → "-" // operator "-"
part(X1) → 0 // No parts
part(X1,0) → "X1"
part(-1) → 0 // No parts OK
part(-X,0) → "-1"
part(-5!) → 0 // No parts OK
part(-5!,0)) → "-120"
BUG
part(e^x) → 1 // must be 2, e & x, with "^" operator, no consistency with string(e^x) -> "e^x" and not "exp(x)", this generates problems within a program code
part(Expr, Integer)
samples OK
special cases
part(X1,0) → "X1"
part(-X,0) → "-1"
BUG
