05-25-2016, 01:23 PM
I'm trying to write a code to generate a graph of torque in the calculator, when I write the code in the emulator it runs without errors but when I transfer to calculator displays syntax error. The emulator and claculadora are versioned 8151. Also when the step calculator ready programs that took on the website shows syntax error, however this correct syntax. Displays error in variable declaration for example
LOCATION X, Y; syntax error of.
I thought was the problem then updated to version 10077 and the problem continues, the emulator works in syntax error calculator.
(Written with google translator)
