Hi to all
my name is Matteo and i'm writing from Italy. Maybe someone can help me
I used about a long time and "old" HP48GX and i always make USRRPL language to programming it.
Recently i discover HP48XGCC, a GCC cross linker for Saturn processor and i think "wow i can program my hp with it as i do with my 50G (and TI89 LOL)"
I'm very happy but... it don't work...
I download the right .zip file (compiled with .bin) and i tried to use it on LINUX, MAC, Win (with cygwin) but nothing, i always have some error.
Someone of you have never used it? or have some problem?
Please help me
thanks
Matteo
Could you please be a bit more specific:
- Which file ? from where ? what does it contain ?
- Which version have you tried ? on which operating system.
- Which error ?
(05-10-2016 03:18 PM)roadrunner Wrote: [ -> ]He may be talking about this:
http://hp48xgcc.sourceforge.net/
or some other, similar software. I couldn't say for sure.
-road
Yes I talking about it... Nobody never used it in the past? I know it's a long time ago...
Instead of keeping us guessing, tell us what did you try, what did not work and which error messages did you get...
(05-10-2016 06:51 PM)Alejandro Paz(Germany) Wrote: [ -> ]Instead of keeping us guessing, tell us what did you try, what did not work and which error messages did you get...
ok i make a screenshot of the error
What is ENOENT error? and why i can't execute CPP? and what is CPP?
I tried to find something in internet but i can't find nothing... I think that i put my .c program into a wrong directory
(05-10-2016 07:53 PM)#ich Wrote: [ -> ]ok i make a screenshot of the error
Hello Matteo,
CPP is an acronym for the
C PreProcessor, a component of gcc.
Did you read the
manual page ?
From your screenshot, it seems that you're lacking some linux environment.
"Make sure you have GNU Make. Unfortunatelly, if you're a Windows95 user this can take some work to accomplish (start at
http://www.cygnus.com/gnu-win32)."
Well, the URL is no longer valid, but you may give a try to Cygwin (with gcc & make packages) ?
I find that the way you invoked the compiler a bit strange:
In the manual they recommend you have a /usr directory at the top of the C drive. You can also try MinGW instead of cygwin.
The -O option (Optimization level) needs a switch like 's' for size, or '0' for none, or '2' for optimize more (-O2 is what the manual recommends)
try it like this (assuming that xgcc is in the PATH and Residuo_secco.c is in the current directory):
xgcc -O2 Residuo_secco.c -o Residuo_secco
btw: ENOENT means file not found.
(05-11-2016 03:52 AM)Alejandro Paz(Germany) Wrote: [ -> ]I find that the way you invoked the compiler a bit strange:
Hi
thank you for your help.
You give me some ideas and i started to do some test but nothing working
BUT
I found it:
http://www.hpcalc.org/hp48/pc/programming/htrxgcc.zip
this document explain how use XGCC 48 into WIN3.11 (LOL). Here i found the solution and now it's all OK!!!
PS: the original manual DO NOT EXPLAIN the correct procedure because don't talk about -lcore command. I think in the past other people had my problem...
great! anything to watch out, or did it just work out as presented in the document?
