From \(Q = mC\Delta T\) you will get \(\Delta T = {Q\over mC}\), with \(C=4182 {J\over kg \Delta K}\) being the specific heat of water at 20ºC. With this you get \[\Delta T = {25000 J\over 2kg · 4182 {J\over kg \Delta K}} = 2.989 \Delta K\]
Then the final temperature will be: \(T_0+\Delta T = 20 ºC + 2.989 \Delta K =\) Inconsistent units.
$\frac{N_i}{D_i}=\frac{N_{i-1}}{D_{i-1}}+\frac{1}{F_i}=\frac{F_i\cdotN_{i-1}+D_{i-1}}{D_{i-1}\cdotF_i}$
(05-08-2016 08:56 PM)emece67 Wrote: [ -> ]From \(Q = mC\Delta T\) you will get \(\Delta T = {Q\over mC}\), with \(C=4182 {J\over kg \Delta K}\) being the specific heat of water at 20ºC. With this you get \[\Delta T = {25000 J\over 2kg · 4182 {J\over kg \Delta K}} = 2.989 \Delta K\]
\(\frac{N_i}{D_i}=\frac{N_{i-1}}{D_{i-1}}+\frac{1}{F_i}=\frac{F_i · N_{i-1}+D_{i-1}}{D_{i-1} · F_i}\)
JÍHÁÁÁÁ!
(05-08-2016 08:56 PM)emece67 Wrote: [ -> ][•••]
I might be wrong, I haven't been involved in thermal issues since my second course in the University.
Kelvin degrees = Centigrade degrees + the absolute zero offset
Offsets are canceled in the Delta, so that there would be no incoherence. The same Delta in Centigrade degrees would have the very same value.
Fahrenheit degrees are another story, you know.
(02-19-2017 03:40 PM)Csaba Tizedes Wrote: [ -> ] (05-08-2016 08:56 PM)emece67 Wrote: [ -> ]From \(Q = mC\Delta T\) you will get \(\Delta T = {Q\over mC}\), with \(C=4182 {J\over kg \Delta K}\) being the specific heat of water at 20ºC. With this you get \[\Delta T = {25000 J\over 2kg · 4182 {J\over kg \Delta K}} = 2.989 \Delta K\]
JÍHÁÁÁÁ!
From these equations (\(\beta\) in radian):
\(R_2 · \beta=2 · r · \pi\), and
\((R_2+s) · \beta=2 · R · \pi\)
we get:
\(R_2=\frac{\frac{h}{cos \alpha}}{\frac{R}{R-h_x}-1}\), and
\(\beta=\frac{2 · (R-h_x) · \pi}{R_2}\)
