Hi!
It's my first post in here
1)How I can print char at X,Y position? In TI-Basic was command Output(X,Y,"Blabla"
I know how print in graphics mode, but I need it in a text mode.
2) If I understood right, inside we have Windows CE + ARM. What about C/C++ compilers for it?
To my knowledge there is no distinction between a graphics mode and a text mode on the Prime.
Everything you see on the screen is just a bunch of pixels which are accessible via the G0 grob. You may read it or overwrite it as you want.
So to put a text at x,y you just do a TEXTOUT_P("blah",x,y) [look at in-device-help for further formatting options]. Since the Prime will refresh (i.e. overdraw) your screen at the end of your program, you may do a FREEZE or WAIT or something similiar to halt program execution before finishing.
Where did you hear about Win CE running in Prime?
That would be a huge (and disappointing) surprise to me...
1) In the "text mode" there is no way to set the position, is just an output terminal. You can use:
Syntax: TEXTOUT_P(text, [G], x, y, [font], [textColor], [width], [backgroundColor])
http://www.hpmuseum.org/forum/thread-494.html
2) Not confirmed and not yet.
(02-06-2014 03:24 PM)eried Wrote: [ -> ]2) Not confirmed
Never will be. I beleive this strange idea came from someone who mounted the filesystem and saw some files they thought belonged to a wince install. You know, files like filesystem.dll and similar which could only exist on windows...
But you know, it is not only the filename, but the untouched PE structure:
http://cl.ly/TmA1
Yup, that's the cause of a number of people (among which myself, clearly) thinking that the Prime was based on WinCE, even if we saw at the same time that the user-visible part of the Prime firmware is an ELF file, while ELF is not WinCE's favorite format.
Out of the box, the Prime provides no access to native code. critor and I scratched an itch and showed months ago that modified firmware upgrades (and as such, certainly, arbitrary firmware upgrades) were possible on the Prime, see some sub-pages of
http://tiplanet.org/hpwiki/index.php?title=HP_Prime
If someone finds enough time, the Prime would become the second calculator, after the TI-Nspire, for which a Linux port is available (and for best results, based on Device Tree and integrated into mainline Linux, like the Nspire port).
Thanks for replies.
I just little bit analyzed FW files, and can say: Inside is Besta RTOS, based on WinCE. Later I'll explain all things.
(02-07-2014 02:26 PM)MrKalach Wrote: [ -> ]Thanks for replies.
It makes sense, but there is no much info in Besta/Inventek website (no much info at all in that website)
(02-07-2014 06:54 PM)eried Wrote: [ -> ] (02-07-2014 02:26 PM)MrKalach Wrote: [ -> ]Thanks for replies.
Code contains some debug info and addresses in the web. One address keep to admin panel. I think inside all what we need
And I assume that FW was compiled in
Keil MDK-ARM
"calculation" code is in amrif.elf(inside u can see references to SDKLIB.DLL and CORE.DLL, sounds unbelievable but it's real ELF, which use DLL libs). Also this code have some opensource libs for math.
I will be so nice if it really runs that. Anyone knows what happens if the firmware is uploaded wrongly (by mistake/purpose), there is a recovery mode able to recover the device without jtag/etc ?
Quote:I just little bit analyzed FW files, and can say: Inside is Besta RTOS, based on WinCE. Later I'll explain all things.
Quote:"calculation" code is in amrif.elf(inside u can see references to SDKLIB.DLL and CORE.DLL, sounds unbelievable but it's real ELF, which use DLL libs). Also this code have some opensource libs for math.
So far, you've discovered nothing that we didn't already know (and is documented on the TI-Planet hpwiki, or is common knowledge, such as HP using some version of xcas).
But be sure to go on: it's pretty good to see someone else interested, and who has some time on his hands
As already outlined elsewhere, the first step towards Linux would be to replace armfir.elf with another ELF file, loaded at the same address (we know that it works), and drawing something onto the screen until the calculator is unplugged from a USB host and a battery is removed.
(02-07-2014 09:27 PM)debrouxl Wrote: [ -> ]Quote:I just little bit analyzed FW files, and can say: Inside is Besta RTOS, based on WinCE. Later I'll explain all things.
Ups
I didn't see. What about hardware? How start bootloader?
The hardware is described on the TI-Planet hpwiki as well, see
http://tiplanet.org/hpwiki/index.php?tit...e/Hardware
As described at the sibling
http://tiplanet.org/hpwiki/index.php?tit.../Emulation page, Linux has good support for the S3C2416 chip in itself, and some old out-of-tree QEMU forks support it as well. The specific MMIO / hardware connections used in the Prime are currently undocumented, AFAICT.
The ARM processor always starts execution at address 0, so the bootloader is loaded at address 0. Someone did a one-off posting of a commented disassembly, suitable for IDA, of the first 4 KB of BXCBOOT0.BIN: the relevant page is linked from the Special:ListUsers page of the TI-Planet hpwiki.
The text of that page shows that BXCBOOT0.BIN is 0x40000 bytes, and among other things, the first 4 KB of code copy and relocate the last 0x3C000 of those 0x40000 bytes to 0x30C00000 before executing them.
Ok. Can u explain me why BXCBOOT0.BIN and BESTAARM.ROM has same addres in usbtool.exe? In bxcboot0 we have vectors table. But bestaarm has very different structure. It's made by armlink with lzma compression. I'm trying decompress it, but my ida doesn't have arm decompiller(hexrays).
ps. sorry for my english
I've never had a serious look at BESTAARM.ROM (that is, beyond reading the list of strings produced by `strings`).
On the TI-Nspire platform, historically, before an emulator was made, there have been two methods for decrypting the OS:
* a standalone decrypter using the standard implementation of the Blowfish cipher, which is the most scriptable way, provided someone can find the key;
* manual use of GDB's sim target:
http://www.yaronet.com/posts.php?sl=0&s=...&h=116#116 .
If there's LZMA-compressed data in BESTAARM.ROM, both methods may be usable: extracting the input data and passing it to a generic LZMA decompressor, or running the calculator-side decompressor function in GDB's sim target.
