Hello !
If I try to calculate the canonical form of a quadratic equation using Ans, the Prime says: "Error: Bad Argument Value" (see attached example)
If I copy/paste the last result in the parenthesis it works fine.
Same problem both on emulator as on the real Prime.
(04-27-2016 09:23 AM)retoa Wrote: [ -> ]Hello !
Problem confirmed, when using the "simplify" menu button to carry out the simplification.
However, entering "simplify(3*(x+1/3)^2+14/3)" directly from the keyboard and then doing "canonical_form(ANS)" works correctly.
Nigel (UK)
(04-27-2016 01:41 PM)Nigel (UK) Wrote: [ -> ] (04-27-2016 09:23 AM)retoa Wrote: [ -> ]Hello !
Nigel (UK)
For me was the same. Using the key Simplify the error appears but typing simplify (...) works correctly
