Full Version: [SOLVED]here is a program that no longer works after FW10077 update
[EDIT] The solution was provided by Tim here: http://www.hpmuseum.org/forum/thread-6095.html
I would like first to thank the whole team for this great work update.
It does not bother me to have to change the line of code if the current or future change brings simplifications ...
For exemple : Here is a program that no longer work...
Based on function app. The complete code is at the end of this post. It is a Bode plot program...
In the symb view place a transfert function in term of X for exemple 1/(1+X) and then press plot view key... The Bode gain plot works as before but the phase and step response fail...
I try to debug these function:
export calcule_phases()
local k,j,r,retard;
local f, a,num,denomi,cnum,cdenom,phi;
  for k from 1 to length(liste_fonctions) do
     if ISCHECK(k MOD 10) AND recalc_phase(k) then
       f:=replace(string(liste_fonctions(k)),"X","x");
       r:=instring(f,"e");
       if r then
                retard:=right(f,size(f)-1-r);
                f:=left(f,r-2);
       end;
       a:=CAS.froot(f,"x");
       num:=string(CAS.numer(f));
       denomi:=string(CAS.denom(f));
       cnum:=CAS.lcoeff(num,"x");
       cdenom:=CAS.lcoeff(denomi,"x");
       phi:=string(ARG(cnum/cdenom));
       FOR j FROM 1 TO length(a) STEP 2 DO
           IF RE(a(j))<>0 THEN
                phi:=phi+"+"+a(j+1)+"*ATAN(("+IM(a(j))+"-X)/("+RE(a(j))+"))";
           ELSE IF a(j)==0 THEN
                    phi:=phi+"+"+a(j+1)+"*90";
                ELSE phi:=phi+"+"+a(j+1)+"*90*SIGN(X-"+IM(a(j))+")";
           END; //fin IF
       END; //fin FOR j
     if r then phi:=phi+"+"+replace(retard,"x","X") end;
     phi:="'"+replace(phi,"X","ALOG(X)")+"'";
    liste_phases(k):=EXPR(phi);
    recalc_phase(k):=0;
   end; //fin if ischek
 end; //fin for k
After these line
f var contain the string "1/(1+x)"
The following lines do not work anymore..
In the HOME view i make some tests:
denom("1/(1+x)") => 1+x OK (no more CAS. prefixe when called from the catalog ?)
but if I first create a var with the same string f:="1/(1+x)"
then
denom(f) => 1 (wrong)...
May I have some help ?
I must say that these code pass the check test in the program editor when the digital grouping is set to the default dot but failled with the coma as digital grouping setting... What about the pragma on these new firmware ?
Thank's a lot for your help.
Didier
Here is the complete code of my Bode program
#pragma mode( separator(.,;) integer(h64) )
copie_les_fonctions();
replace_les_fonctions();
place_les_modules();
place_les_phases();
place_les_rep_temp();
calcule_modules();
calcule_phases();
calcule_rep_temp();
Symb();
export liste_fonctions:=MAKELIST(0,X,1,10);
export liste_modules:={};
export liste_phases:={};
export liste_rep_temp:={};
recalc_module:=MAKELIST(1,X,1,10);
recalc_phase:=MAKELIST(1,X,1,10);
recalc_temp:=MAKELIST(1,X,1,10);
modif:=0;
export copie_les_fonctions()
begin
  local k;
  for k from 1 to 10 do
    if ISCHECK(k MOD 10) then
      if EVAL(EXPR("F"+k MOD 10)≠liste_fonctions(k)) then
        IFERR liste_fonctions(k):=EXPR("F"+k MOD 10) then MSGBOX("Erreur de copie sur F"+k MOD 10) end;
        recalc_module(k):=1;
        recalc_phase(k):=1;
        recalc_temp(k):=1;
      end;
    end;
  end;
  modif:=0;
end;
export replace_les_fonctions()
begin
  local k;
      expr("F"+k MOD 10+":=liste_fonctions("+k+")");
    end;
  end;
end;
export place_les_modules()
begin
  local k;
  for k from 1 to length(liste_modules) do
       expr("F"+k MOD 10+":=liste_modules("+k+")");
     end;
  end;
end;
export place_les_phases()
begin
  local k;
  for k from 1 to length(liste_phases) do
       expr("F"+k MOD 10+":=liste_phases("+k+")");
     end;
  end;
end;
export place_les_rep_temp()
begin
  local k;
  for k from 1 to length(liste_rep_temp) do
       expr("F"+k MOD 10+":=liste_rep_temp("+k+")");
     end;
  end;
end;
export calcule_modules()
begin
  local k;
       if ISCHECK(k MOD 10) AND recalc_module(k) then
         liste_modules(k):=20*LOG(ABS(subst(liste_fonctions(k),'X','i*ALOG(X)')));
         recalc_module(k):=0;
       end;
    end;
end;
local k,j,r,retard;
       r:=instring(f,"e");
       if r then
                f:=left(f,r-2);
       end;
           IF RE(a(j))<>0 THEN
           END; //fin IF
       END; //fin FOR j
    recalc_phase(k):=0;
 end; //fin for k
export calcule_rep_temp()
begin
   local f, k;
        if ISCHECK(k MOD 10) AND recalc_temp(k) then
          f:=REPLACE(STRING(liste_fonctions(k)),"X","x");
          f:=f+"*1/x,x,x";
          f:="'("+REPLACE(STRING(CAS.ilaplace(f)),"x","X")+")*PIECEWISE(X<0,0,X≥0,1)'";
          IF instring(f,"ilaplace")
            THEN MSGBOX("Problème avec F"+k MOD 10); CONTINUE;
            ELSE liste_rep_temp(k):=EXPR(f);
          recalc_temp(k):=0;
        end;
     end;
end;
Symb()
begin
  modif:=1;
  replace_les_fonctions;
  STARTVIEW(0,1);
end;
Plot()
begin
  local choix;
  if modif then copie_les_fonctions end;
  CHOOSE(choix,"Choisissez un type de tracé",{"Module","phase","réponse indicielle"});
  CASE
   IF choix==1 THEN calcule_modules; place_les_modules;Ytick:=20 END;
   IF choix==2 THEN calcule_phases; place_les_phases;Ytick:=45 END;
   IF choix==3 THEN calcule_rep_temp; place_les_rep_temp; Xmin:=−0.2 END;
   //DEFAULT
  STARTVIEW(1,1);
end;
START()
begin
 modif:=1;
 STARTVIEW(0,1);
end;
Another program doesn't work on new released firmware is the 3D graphing plotter... it doesn't plot any graph...
(04-21-2016 08:58 PM)Anderson Costa Wrote: [ -> ]Another program doesn't work on new released firmware is the 3D graphing plotter... it doesn't plot any graph...
Graph 3D by Han?
here it seems to works and plot graphs...
(04-21-2016 09:08 PM)salvomic Wrote: [ -> ]
Graph 3D by Han?
Yes... I can't plot 3D graphs on my Virtual Calculator... I typed the function and pressed Plot, after plotting it give me an "Error: invalid Object" pop up. And the graph doesn't appear.
Graph 3D by Han?
3D Graph by Han works flawlessly for me too...
(04-21-2016 09:12 PM)Anderson Costa Wrote: [ -> ]Yes... I can't plot 3D graphs on my Virtual Calculator... I typed the function and pressed Plot, after plotting it give me an "Error: invalid Object" pop up. And the graph doesn't appear.
I'm trying something like
V3 X^2-Y^2 and it plots
In plot setup I have:
Min -10 Ymin -10 Zmin -10, Xmax 10 Ymax 10 Zmax 10
Tape surface Zoom 8.64
Trasparent, show grid show box on, others off
I think to have version 2.32
I cannot run Graph3D. It says "Invalid Objet".
(04-21-2016 09:14 PM)mandresve Wrote: [ -> ]
(04-21-2016 09:08 PM)salvomic Wrote: [ -> ]Graph 3D by Han?
I had an outdated version... I downloaded the most recent version and Graph 3D works very well...
(04-21-2016 09:25 PM)Anderson Costa Wrote: [ -> ]I had an outdated version... I downloaded the most recent version and Graph 3D works very well...
I still have the same error. I´ve just checked that last version is 2.422. What am I doing bad?
(04-21-2016 09:39 PM)akmon Wrote: [ -> ]I still have the same error. I´ve just checked that last version is 2.422. What am I doing bad?
also with 2.422 it runs well here.
The main thread is on http://www.hpmuseum.org/forum/thread-95.html if it could be useful to you...
Added: Han wrote: «First ensure that the app is properly installed. To check, press [Shift][Plot] to see if you can adjust the settings for Graph3D. If you do not see the proper settings then the application is likely not installed correctly. If you are in RPN mode, switch to algebraic mode. You may even want to test the installation on the virtual calculator. If it works on the emulator, then you can simply transfer the app from the emulator to the actual calculator.»
Salvo
There is an error with "Hmin" "Hmax" variables in a program with the new firmware Sad
(04-22-2016 05:11 AM)Mic Wrote: [ -> ]There is an error with "Hmin" "Hmax" variables in a program with the new firmware Sad
Explain?
Those are variables in stat1 and inference. If either of those are open you will (correctly) conflict.
There was an error because Hmin and Hmax were not created by default.
I have also a problem with my DELTA program. Apparently, name "DELTA" is not accepted for an unknown reason ?
(04-22-2016 10:55 AM)Mic Wrote: [ -> ]There was an error because Hmin and Hmax were not created by default.
Hmin and Hmax were incorrectly flagged as "global" variables previously. They are actually plot setup values in the stat1var app, and inference app. They are no longer flagged as global and hence the error. You were actually storing and modifying the plot setup values in one of the apps.
DELTA is a command in the quadratic explorer. Do you have it open?
