02-03-2014, 06:52 AM
02-03-2014, 04:22 PM
(02-03-2014 06:52 AM)walter b Wrote: [ -> ]In the old forum, we had and , but these don't work here anymore. What to do?
You can use _{x} inside of an in-line LaTeX expression to get A\(_{x}\), for example.
In-line LaTeX expression are \ ( expression \ ) without the spaces between the \ and the ( or ). Similarly, superscripts are done with ^{x}, A\(^{x}\), for example.
02-03-2014, 09:31 PM
I could add [sub] but perhaps with the LaTex solution it is not needed?
02-03-2014, 11:19 PM
(02-03-2014 09:31 PM)Dave Hicks Wrote: [ -> ]I could add [sub] but perhaps with the LaTex solution it is not needed?
I would appreciate [sub]! It seems more natural.
02-04-2014, 09:19 AM
02-04-2014, 11:54 PM
OK let's try the new sub and sup: H2O, A2. You can only use them one level deep but I think that was true of the old code as well.
02-04-2014, 11:57 PM
Thank you!!
02-05-2014, 06:10 AM
02-05-2014, 04:05 PM
(02-04-2014 11:54 PM)Dave Hicks Wrote: [ -> ]OK let's try the new sub and sup: H2O, A2. You can only use them one level deep but I think that was true of the old code as well.
Yes, it works well \(b^{u^{t}}\) \(i_{t}\) \(c^{a^{n^{'^{t}}}}\) \(d_{o}\) \(t^{h^{i^{s}}}\)
