Is it possible to do so? For example I have the follwing program:
LININT
EXPORT X1,X2,Y1,Y2;
EXPORT LININT()
INPUT(X2,"X INTERCEPT","Xi=","ENTER THE X INTERCEPT");
INPUT(Y1,"Y INTERCEPT","Yi=","ENTER THE Y INTERCEPT");
'Y1=M*X1+C'▶E1;
'Y2=M*X2+C'▶E2;
0▶X1;
0▶Y2;
STARTAPP("Solve");
STARTVIEW(2);
Right after the STARTVIEW(2) I would like to set the variables to solve for and then solve it. Is it possible to do this and where do I find the commands to do so?
Kinds Regards
Mick C
Mick,
Does this program what you want to achieve?
EXPORT X1,X2,Y1,Y2;
EXPORT LININT()
LOCAL i;
'Y1=M*X1+C'▶E1;
'Y2=M*X2+C'▶E2;
0▶X1;
0▶Y2;
STARTAPP("Solve");
FOR i := 0 TO 9 DO
UNCHECK(i);
CHOOSE(eq, "Choose Equation", "E1", "E2");
CASE
IF eq == 1 THEN
CHECK(1);
IF eq == 2 THEN
CHECK(2);
END; // END CASE
STARTVIEW(2);
What the program does:
- This program starts the Solve app after entering the X2 and Y1 variables
- It uncheckes all equations in the list
- Now you can choose the equation to solve
- The program switches to the numeric view
Do you want to solve the equations seperately or both together?
Dominik
There was a thread a couple of weeks ago with object something like 'Equation library' that i dealed with Larsf.
There were a couple of approachs to start the solve by program.
Hope it helps,
Giancarlo
Giancarlo,
Do you mean this thread?
HP Prime programmable eq solver
This is one of the must useful topics I have read so far in this forum, many thanks!
Dominik
Hello Dominik,
The purists could argue that trying to run the HP PRIME as the 'HP48/49/50 solve' is not consistent with the new 'vision' :+)
bye
Giancarlo
Are you suggesting that I am trying to do this backwards?
Edit: How else would you work with multiple equations other than typing them in repeatedly?
Mick C
