03-21-2016, 05:51 PM
Back last year, a member of this website pointed to the simplicity of using the Gauss-Legendre quadrature (with a 3rd order Legendre polynomial) with vintage and new HP calculators. This prospect made me think of using a "chained" version of that type of quadrature to yield relatively good results. Here are my preliminary results usin Excel VBA.
The following Excel VB Code compares the chained Simpson's rule with a "chained" Gauss-Legendre quadrature using a 3rd order Legendre polynomial. The following is the configuration contents of the Excel sheet:
Here is the VBA code:
As you experiment with different functions and integration ranges, you should see that the chained Gauss-Legendre quadrature is significantly more accurate than Simpson's rule. Both methods use three points per divided interval.
Enjoy!
Namir
Cell Contents
A1 "A"
A2 "B"
A3 "N"
A4 "FX"
A5 "Simpson"
A6 ""
A7 Exact
B1 value for A, e.g. 1
B2 value for B, e.g. 2
B3 value for N, e.g. 19
B4 string for FX, e.g. "1/X"
C5 Formula for % error for Simpson's rule
C6 Formula for % error for Gauss-Legendre quadrature
Function Fx(ByVal sFx As String, ByVal X As Double) As Double
sFx = Replace(sFx, "EXP(", "!")
sFx = Replace(sFx, "X", "(" & X & ")")
sFx = Replace(sFx, "!", "EXP(")
Fx = Evaluate(sFx)
End Function
Sub go3()
Const MAX = 3
Dim A As Double, B As Double, Xa As Double, Xb As Double
Dim N As Integer, I As Integer, J As Integer, C As Integer, h As Double
Dim Sum As Double, Sum2 As Double, X As Double
Dim Xar(MAX) As Double, Wt(MAX) As Double, T1 As Double, T2 As Double
Dim sFx As String
A = [B1].Value
B = [B2].Value
N = [B3].Value
sFx = [B4].Value
sFx = UCase(Replace(sFx, " ", ""))
' Simpson's rule
If N Mod 2 = 0 Then N = N + 1
h = (B - A) / (N + 1)
X = A + h
Sum = Fx(sFx, A) + Fx(sFx, B) + 4 * Fx(sFx, X)
C = 2
For I = 2 To N
X = X + h
Sum = Sum + C * Fx(sFx, X)
C = 6 - C
Next I
[B5].Value = h / 3 * Sum
' Gauss Quadrature
N = [B8].Value * [B3].Value
Xar(1) = 0
Wt(1) = 8 / 9
Xar(2) = Sqr(3 / 5)
Wt(2) = 5 / 9
Xar(3) = -Xar(2)
Wt(3) = Wt(2)
Xa = A
Xb = Xa + h
Sum = 0
Do
T1 = (Xb - Xa) / 2
T2 = (Xb + Xa) / 2
Sum2 = 0
For J = 1 To MAX
Sum2 = Sum2 + Wt(J) * Fx(sFx, T1 * Xar(J) + T2)
Next J
Sum = Sum + T1 * Sum2
Xa = Xb
Xb = Xb + h
Loop Until Xa >= B
[A6].Value = "GS" & MAX
[B6].Value = Sum
End Sub
Enjoy!
Namir
