I am making a program an at some point i need the program to:
1) Find the roots of a cubic polinomi
2) The roots are always going to be 2 complex and 1 real ( cause of the physics behind). And i want the program to select the real one and define it as "Z"
3) Now that Z is define as one number ( the real root out of the three possible) it can continuo with my calculations.
I have the doubt that if I calculate the roots through Cas.function('expresion'), the three routs will come out as a vector, list, matrix or what?
Is this a
PRIME specific question? otherwise, HP calculator programs for the solution of cubic equations go back to at least the HP-65 with program #7 in MATH PAC 1.
Kahan has two source locations on the topic:
a.
To Solve a Real Cubic Equation
found at
Cubic
b.
To Solve A Real Cubic Equation
found at
AD a206859
as well as
Analytic Solution of Quartic & Cubic Polynomials by
A J Helou, BCE, M.Sc., Ph.D.
BEST!
SlideRule
(03-09-2016 02:43 AM)SlideRule Wrote: [ -> ]Is this a PRIME specific question? otherwise, HP calculator programs for the solution of cubic equations go back to at least the HP-65 with program #7 in MATH PAC 1.
a. To Solve a Real Cubic Equation
found at Cubic
b. To Solve A Real Cubic Equation
found at AD a206859
as well as Analytic Solution of Quartic & Cubic Polynomials by A J Helou, BCE, M.Sc., Ph.D.
BEST!
SlideRule
Thank you very much, and yes, its for the HP PRIME.
I was thinking to use the CAS.function('expression') to find the roots instead of programming a cubic root finder. My real problem is which command should I use in the programm so that when the CAS.function gives the 3 roots, the programm choses the only real root out of the 3 roots ( 2 complex and 1 real.) and then define that real root as the valua of "Z" so it follows its calculations.
(03-09-2016 04:26 AM)Eugenio Wrote: [ -> ]I was thinking to use the CAS.function('expression') to find the roots instead of programming a cubic root finder. My real problem is which command should I use in the programm so that when the CAS.function gives the 3 roots, the programm choses the only real root out of the 3 roots ( 2 complex and 1 real.) and then define that real root as the valua of "Z" so it follows its calculations.
This should work for you:
EXPORT RealRoot(poly)
LOCAL s;
s:=CAS.proot(poly);
EXECON("IFTE(TYPE(&1),0,Z:=&1)",mat2list(s));
RETURN Z;
For example for $$2*x^3+x^2-2$$ RealRoot([2,1,0,-2]) returns 0.858094329497
(03-09-2016 08:38 AM)Didier Lachieze Wrote: [ -> ] (03-09-2016 04:26 AM)Eugenio Wrote: [ -> ]I was thinking to use the CAS.function('expression') to find the roots instead of programming a cubic root finder. My real problem is which command should I use in the programm so that when the CAS.function gives the 3 roots, the programm choses the only real root out of the 3 roots ( 2 complex and 1 real.) and then define that real root as the valua of "Z" so it follows its calculations.
LOCAL s;
s:=CAS.proot(poly);
RETURN Z;
Thank you so much for your help, it has been really helpfull. It works and suits perfectly
