02-28-2016, 05:15 PM
Does anyone know how I can get or what I can change to get exact answers from this Simplex program?
Thanks
Thanks
PHASEONE();
SPIVOT();
ROUNDING();
EXPORT SIM16()
LOCAL V,C,P,S1,S2,S3,S4,S5;
LOCAL O,I,L,M,T,TAB,A,B;
LOCAL E,K,S,Z,Q,NEG,STP1,STP2;
LOCAL NZR,NZN,J,R,NSE,MIN;
LOCAL LLL,RRR,MCL,MAX,ONEZC;
LOCAL Q1,Q2,Q3,Q4,W,ORG,OOK;
LOCAL ALLN,LA,LB,ILL,ILL2,MTS,FST;
LOCAL MTAB,LST,LMX,SAM,FIX,PACK;
LOCAL II,KK,LATAB,JJ,CON,INF,ILL3;
LOCAL OTAB,TEMP,ILL4,ORGTAB;
INPUT({{V,[0],{55,20,0}},{C,[0],{55,20,1}}},"SIMPLEX",{"NUMBER OF VARIABLES:","NUMBER OF CONSTRINTS:"});
O:=MAKELIST(0,X,1,V);
T:=MAKELIST(O,X,1,C);
E:=MAKELIST(0,X,1,C);
S:=MAKELIST(2,X,1,C);
S1:="{P,{""Max"",""Min""},{1,17,0}}";
S3:="";
S4:="""P"",";
M:=−1;
FOR I FROM 1 TO V DO
IF ((I MOD 3)==1) THEN L:=27;END;
IF ((I MOD 3)==2) THEN L:=27+27;END;
IF ((I MOD 3)==0) THEN L:=27+27*2;END;
IF (I MOD 3)==1 THEN M:=M+1;END;
S3:=S3+"{O("+I+"),[0],{"+L+",18,"+M+"}},";
S4:=S4+"""+X"+I+""",";
S3:=LEFT(S3,DIM(S3)-1);
S5:="";
M:=M+1;
FOR K FROM 1 TO C DO
IF ((I MOD 3)==1) THEN L:=6;END;
IF ((I MOD 3)==2) THEN L:=6+24;END;
IF ((I MOD 3)==0) THEN L:=6+24*2;END;
IF ((I MOD 3)==1) THEN M:=M+1;END;
S5:=S5+"{T("+K+","+I+"),[0],{"+L+",17,"+(M)+"}},";
S4:=S4+"""X"+I+""",";
S5:=S5+"{S("+K+"),{""≥"",""≤"",""=""},{72,9,"+(M)+"}},{E("+K+"),[0],{82,17,"+(M)+"}},";
S4:=S4+""""","""",";
S5:=LEFT(S5,DIM(S5)-1);
S4:=LEFT(S4,DIM(S4)-1);
S2:="INPUT({"+S1+","+S3+","+S5+"},""SIMPLEX"",{"+S4+"})";
EXPR(S2);
//PRINT EQUATIONS
PRINT();
S1:="";
IF P==1 THEN S1:="MAXIMIZE: P= ";
ELSE S1:="MINIMIZE: P= ";END;
IF SIGN(O(I))==−1 THEN S1:=S1+" - ";END;
IF SIGN(O(I))≥0 AND I≠1 THEN S1:=S1+" + ";END;
S1:=S1+ABS(O(I))+"_X"+I;
END;//FOR I
PRINT(S1);
PRINT("SUBJECT TO:");
S1:="";
IF SIGN(T(K,I))==−1 THEN S1:=S1+" - ";END;
IF SIGN(T(K,I))≥0 AND I≠1 THEN S1:=S1+" + ";END;
S1:=S1+ABS(T(K,I))+"_X"+I;
END;//FOR I
IF S(K)==1 THEN S1:=S1+" ≥ ";END;
IF S(K)==2 THEN S1:=S1+" ≤ ";END;
IF S(K)==3 THEN S1:=S1+" = ";END;
IF SIGN(E(K))==−1 THEN S1:=S1+"-";END;
S1:=S1+ABS(E(K));
PRINT(S1);
END;//FOR K
PRINT("---------------------");
//Equal
FIX:=SIZE(S);
FOR I FROM 1 TO FIX DO
IF S(I)==3 THEN
S(I):=2;
C:=C+1;
T(C):=T(I);
E(C):=E(I);
S(C):=1;
END;//IF S(I)
END;//FOR I
TAB:=append(T,(−1)^P*O);
TAB:=list2mat(TAB);
A:=MAKEMAT(0,1,C+1);
FOR I FROM 1 TO C DO
A:=A*0;
A(1,I):=(−1)^S(I);
ADDCOL(TAB,A(1),V+I);
Z:=MAKEMAT(0,1,C+1);
Z(1,C+1):=1;
ADDCOL(TAB,Z(1),C+V+1);
E:=append(E,0);
B:=list2mat(E,C+1);
ADDCOL(TAB,B(1),C+V+2);
ORG:=TAB;
//RETURN(TAB);
//PHASE ONE
STP1:=0;
PACK:={};
PACK:=PHASEONE(TAB,C,V,STP1);
TAB:=PACK(1);
STP1:=PACK(4);
//SIMPLEX
STP2:=0;
REPEAT
MIN:=1ᴇ12;NEG:=0;TEMP:=ROUNDING(TAB,C,V,6);
IF TEMP(C+1,C+V+1)<0 THEN TAB(C+1):=-1*TAB(C+1);TEMP(C+1):=-1*TEMP(C+1);END;
FOR LA FROM 1 TO C+1 DO
ALLN:=1;
FOR LB FROM 1 TO C+V+2 DO
IF TEMP(LA,LB)>0 THEN ALLN:=0;END;
END;//FOR-LB
IF ALLN THEN TAB(LA):=−1*TAB(LA);TEMP(LA):=−1*TEMP(LA);END;
END;//FOR-LA
OOK:=2;
FOR I FROM 1 TO V+C DO
IF (TEMP(C+1,I)<0) AND (TEMP(C+1,I)<MIN) THEN
OOK:=0;
IF SIGN(TEMP(K,C+V+2))*TEMP(K,I)>0 OR (TEMP(K,I)>0 AND TEMP(K,C+V+2)==0) THEN
OOK:=1;
END;//IF2
END;//FOR-K
IF OOK==1 THEN
MIN:=TEMP(C+1,I);J:=I;NEG:=1;
END;//IF3
END;//FOR-I
IF NEG==1 THEN
MIN:=1ᴇ12;R:=0;
IF SIGN(TEMP(K,C+V+2))*TEMP(K,J)>0 OR (TEMP(K,J)>0 AND TEMP(K,C+V+2)==0) THEN
IF RANDINT(1,2)==1 THEN
Q1:=(TEMP(K,C+V+2)/TEMP(K,J))<MIN;
ELSE
Q1:=(TEMP(K,C+V+2)/TEMP(K,J))<=MIN;
Q2:=(TEMP(K,C+V+2)/TEMP(K,J))≥0;
IF Q1 AND Q2 THEN
MIN:=TEMP(K,C+V+2)/TEMP(K,J);
R:=K;
TAB:=SPIVOT(TAB,R,J);
//TAB:=ROUNDING(TAB,C,V,9);
//FOR II FROM 1 TO C+1 DO
//FOR KK FROM 1 TO C+V+2 DO
//TAB(II,KK):=ROUND(TAB(II,KK),9);
//END;//FOR KK
//END;//FOR II
PRINT("SIMPLEX ROW="+R+" COL="+J);
IF ROUND(TAB(C+1,C+V+1),6)<0 THEN TAB(C+1):=-1*TAB(C+1);END;
//FOR W FROM 1 TO C+1 DO
//IF lgcd(TAB(W))>0 THEN TAB(W):=TAB(W)/lgcd(TAB(W));END;
//END;//FOR W
TAB:=PACK(1);
STP1:=PACK(4);
//RETURN(TAB);
//PRINT("OOK="+OOK);
STP2:=STP2+1;
UNTIL NEG==0 OR STP2>=100;
//RETURN(TAB);
//ROUNDING
ORGTAB:=TAB;
TAB:=ROUNDING(TAB,C,V,6);
//TAB(II,KK):=ROUND(TAB(II,KK),6);
//END;//FOR KK
//END;//FOR II
//CHECK INVALID SOLUTION
ILL2:=0;
FOR I FROM 1 TO C+V DO
NZN:=0;NZR:=0;
FOR K FROM 1 TO C+1 DO
IF TAB(K,I)≠0 THEN NZN:=NZN+1;NZR:=K;END;
END;//FOR-K
IF NZN≠0 THEN
IF (NZN==1) AND (SIGN(TAB(NZR,C+V+2))*SIGN(TAB(NZR,I))<0) THEN
ILL2:=1;
END;//IF-(NZN==1)
END;//IF-NZN≠0
END;//FOR-I
//FIND VALID SOLUTION
JJ:=2;LATAB:={};ILL4:=0;
LATAB(1):=ORG;
LATAB(2):=TAB;
MTAB:=TAB;MTS:={};FST:=0;LST:={};LMX:={};
ILL3:=0;
REPEAT
FST:=FST+1;
S1:="";CON:={};INF:=0;
NZN:=0;NZR:=0;
IF MTAB(K,I)≠0 THEN NZN:=NZN+1;NZR:=K;END;
IF NZN==1 THEN
IF I≤V THEN
IF contains(CON,NZR)==0 THEN
CON:=append(CON,NZR);
ELSE
INF:=1;ILL3:=1;
END;//IF CONTAINS
END;//IF I≤V
MTAB(NZR):=ROUND(MTAB(NZR)/MTAB(NZR,I),4);
IF I<=V AND INF==0 THEN S1:=S1+"X"+I+"="+MTAB(NZR,C+V+2)+" , ";END;
IF I≤V AND INF==1 THEN S1:=S1+"X"+I+"=0 , ";END;
ELSE
IF I<=V THEN S1:=S1+"X"+I+"=0 , ";END;
IF MTAB(C+1,I)==0 AND FST==1 THEN MTS:=append(MTS,I);END;
IF MTAB(C+1,C+V+1)≠0 THEN
MTAB(C+1):=ROUND(MTAB(C+1)/MTAB(C+1,C+V+1),4);
S1:=S1+"P="+((-1)^(P+1)*MTAB(C+1,C+V+2));
ELSE
S1:=S1+"P=NA"
SAM:=0;
IF FST==1 THEN
PRINT(S1);
ELSE
FOR I FROM 1 TO FST-1 DO
IF S1==LST(I) THEN SAM:=1;END;
END;//FOR I
IF SAM==0 THEN
PRINT(S1);
JJ:=JJ+1;
LATAB(JJ):=OTAB;
ILL4:=1;
END;//IF SAM
END;//IF FST
IF SIZE(MTS)>0 AND FST==1 THEN
FOR I FROM 1 TO SIZE(MTS) DO
MIN:=1ᴇ12;R:=0;
IF SIGN(TAB(K,C+V+2))*TAB(K,MTS(I))>0 OR (TAB(K,MTS(I))>0 AND TAB(K,C+V+2)==0) THEN
Q1:=(TAB(K,C+V+2)/TAB(K,MTS(I)))<MIN;
Q2:=(TAB(K,C+V+2)/TAB(K,MTS(I)))≥0;
IF Q1 AND Q2 THEN
MIN:=TAB(K,C+V+2)/TAB(K,MTS(I));
R:=K;
IF R==0 THEN
LMX(I):=TAB;
ELSE
LMX(I):=ROUNDING(SPIVOT(ORGTAB,R,MTS(I)),C,V,6);
END;//IF R
END;//FOR I
END;//IF-SIZE
IF SIZE(MTS)>0 AND FST≤SIZE(MTS) THEN
MTAB:=LMX(FST);
OTAB:=MTAB;
LST(FST):=S1;
END;//IF SIZE
UNTIL FST==(SIZE(MTS)+1);
//PRINT();
//PRINT({V,C,P});
//PRINT(O);
//PRINT(T);
//PRINT(S);
//PRINT(B);
//PRINT(TAB);
//PRINT(S1);
IF OOK==0 OR STP1==100 OR STP2==100 OR (ILL AND (STP2==0) AND 0) OR (ILL2 AND 1) THEN
PRINT("*may not have optimal solution*");
END;//IF-OOK
//PRINT({"OOK=",OOK,"STP1=",STP1,"STP2=",STP2,"ILL=",ILL,"ILL2=",ILL2,"ILL3=",ILL3});
IF ILL3 THEN PRINT("*Infinitely many solutions*");END;
IF OOK==0 AND ILL2==0 THEN PRINT("*Unbounded*");END;
IF ILL2 THEN PRINT("*No feasible solution*");END;
IF ILL4 THEN PRINT("*Multiple optimal solutions*");END;
//IF SIZE(MTS)>0 THEN
//PRINT("*may has more than one solution*");
//END;//IF-SIZE
//RETURN({ORG,TAB});
PRINT("-END-");
RETURN(LATAB);
//PHASE ONE
LOCAL LA,LB,ALLN,ONEZC;
LOCAL ILL,LLL,NSE,NZN,NZR,K,I;
LOCAL RRR,MCL,W,MAX;
LOCAL II,KK,TEMP;
ONEZC:=0;
REPEAT
ALLN:=1;ILL:=0;
END;//FOR-LB
END;//FOR-LA
NSE:=0;LLL:=0;
NZN:=0;NZR:=0;
IF TEMP(K,I)≠0 THEN NZN:=NZN+1;NZR:=K;END;
END;//FOR-K
IF NZN≠0 THEN
IF (NZN==1) AND (SIGN(TEMP(NZR,C+V+2))*SIGN(TEMP(NZR,I))<0) AND (ONEZC==0) THEN
ALLN:=1;
FOR LB FROM 1 TO C+V DO
IF SIGN(TEMP(NZR,C+V+2))*SIGN(TEMP(NZR,LB))>0 THEN ALLN:=0;END;
END;//FOR-LB
IF ALLN==0 THEN
NSE:=1;RRR:=NZR;LLL:=I;
ELSE
ILL:=1;
END;//IF-ALLN
END;//IF-(NZN==1)
END;//IF-NZN≠0
//IF (NZN==1) AND (TAB(NZR,C+V+2)==0) AND (ONEZC==0)THEN NSE:=1;RRR:=NZR;LLL:=I;ONEZC:=1;END;
END;//FOR-I
IF NSE==1 THEN
MAX:=0;MCL:=0;
IF SIGN(TEMP(RRR,C+V+2))*TEMP(RRR,I)>MAX AND I≠LLL THEN MCL:=I;MAX:=SIGN(TEMP(RRR,C+V+2))*TEMP(RRR,I);END;
//TAB(RRR):=TAB(RRR)/TAB(RRR,MCL);
TAB:=SPIVOT(TAB,RRR,MCL);
//END;//FOR KK
//END;//FOR II
PRINT("PHASE ONE:ROW="+RRR+" COL="+MCL);
//END;//FOR W
//IF WAIT(−1)==30 THEN RETURN(TAB);END;
STP1:=STP1+1;
UNTIL NSE==0 OR STP1>=100;
RETURN({TAB,C,V,STP1});
SPIVOT(M,RO,CO)
LOCAL T,K,SI;
T:=M;
SI:=SIZE(M);
T(RO):=M(RO)/M(RO,CO);
FOR K FROM 1 to SI(1) DO
IF K≠RO THEN
T(K):=M(K)-M(K,CO)*T(RO);
END;//IF K≠RO
END;//FOR K
RETURN(T);
ROUNDING(M,C,V,D)
LOCAL II,KK;
M(II,KK):=ROUND(M(II,KK),D);
END;//FOR KK
END;//FOR II
RETURN(M);
