Is it possible to force the zero to the left of the decimal point to be displayed (0.0000)?
Is there a way to turn on the commas separating thousands like the 48g and 50g (100,000.0000)?
Thanks
Normally, the 0 is displayed already.
Thousand separators are also displayed in Home (at least). You can actually tune it in the home settings (Digit grouping).
In CAS, you do unfortunately not have this option.
Cyrille
(02-23-2016 01:08 AM)Tim McQuade Wrote: [ -> ]Is it possible to force the zero to the left of the decimal point to be displayed (0.0000)?
Thanks
You probably need to update. Both of these options have been in there for a while now...
If you do not see "digit grouping" as the third line option in your home settings screen, then yes - you need to update.
