02-16-2016, 02:05 PM
Blog entry: http://edspi31415.blogspot.com/2016/02/h...mbers.html
Program (Updated 2/21/2016: I was mistaken on the definition of squarefree integers, the program is now corrected.)
The commands isprime and ifactors are generated from the CAS-Integer (Options 6 then 1 for isprime; option 3 for ifactors) submenu. However, I think in order for this program to work properly, the “CAS.” must be deleted and the command should be in all-lowercase.
Introduction
An integer n is a Carmichael number (1910) when the following holds:
a^n ≡ a mod n
(or for a>0 and n>0)
a^n – integer(a^n/n) * n = a
For all integers a.
The program ISCARMICHAEL tests whether an integer n qualifies as a Carmichael number based on the Korselt’s Criterion:
1. n is a positive, composite integer. That is, n can be factored into a multiplication of prime numbers.
2. n is square-free.
3. For each prime factor p dividing n (not 1 or n), the following is true: (p-1) divides (n-1) evenly (without fraction).
EXPORT ISCARMICHAEL(n)
// EWS 2016-02-21
// Thanks: Hank
LOCAL l1,s,flag,k;
LOCAL vect;
flag:=0;
// composite test
IF isprime(n)==1 THEN
RETURN 0; KILL;
// setup
vect:=ifactors(n);
l1:=SIZE(vect);
s:=l1(1);
// square-free number test
FOR k FROM 2 TO s STEP 2 DO
IF vect(k)>1
THEN
flag:=1; BREAK;
// factor test
FOR k FROM 1 TO s STEP 2 DO
IF FP((n-1)/(vect(k)-1))≠0
THEN
flag:=1; BREAK;
// final result
IF flag==0 THEN
RETURN 1;
ELSE
RETURN 0;
Introduction
a^n ≡ a mod n
For all integers a.
