02-07-2016, 11:25 AM
The following equation:
where x is a complex variable, can be solved splitting it into two separate equations, one for the real part and another for the imaginary part. Applying this method, one gets the solution:
Substituting sol1 into eq1, gives the exact value 0. Now, I was trying to solve this same equation using the function fsolve:
The calculator (firmware 8051) returns the value:
Trying different initials guesses leads to the same solution. The real parts of sol1 and sol2 are quite close, but not the imaginary parts.
Also: ABS(sol1)-ABS(sol2) = -0.066603127, and ARG(sol1)-ARG(sol2) = 2.56433999704E-2 (in radiants). So, depending on how you look at it, the solution given by fsolve is not so bad.
Does anyone know how to improve the calculator's accuracy?
|x|^2-200*x+500+500*i = 0 (eq1)
197.43587635+2.5*i (sol1)
fsolve(|x|^2-200*x+500+500*i,x,190+i)
197.501663563-2.56405881565*i (sol2)
