01-28-2014, 08:05 AM
Here is a Conway's Game of Life.
The code of the starting sets is the RLE coding usually found on Internet.
Version 1.0 Time per generation: 5226 ms
The board is 80x80 and with zoom by 3x
The number of neighbors is stored in the color scheme. It avoid the need of other storage.
Optimization:
- Each pixel/cell stores neighbors only horizontally, so each partial count is used in 3 different cells.
But it is still highly unoptimized.
Version 1.1 Time per generation: 2184 ms
Optimizations:
- avoid empty lines recalc.
Version 1.2 Time per generation: 763 ms
Optimizations:
- avoid empty lines and empty trails recalc.
Version 2.0 Time per generation: 218 ms
New method: The board is stored as a bitmap
Optimization: counting is done by bitwise operations only
Calc need to be set as Hexadecimal 64 bits (rev 6030: not needed anymore thanks to new pragme feature)
Version 2.2 Time per generation: 331 ms
added screen trail (green)
Optimization:
- unrolled the loop and removed unneeded operations in LOcc
Version 2.3 Time per generation: 350 ms
The board is now 120x100 and with zoom by 2x
the Next Generation is now computed in constant time, the difference in timing now depend on the number of cells alive to display.
Optimization:
- Taking advantage of lists special handling, it compensate a board twice as big
Look at set 6 (Acorn Set)
Version 2.4 zoom x 2 Time per generation: 350 ms
The board is now 120x160 and with zoom by 2x
Optimization:
- LDisp now detects changes since last generation and only draw the changes.
- LNext now detects changes since last generation and only calc thoses places
- LNext1 is LNext version that handle lists, rename to LNext to test it
Look at set 7 (Snark Glider Reflector Loop), this set is Fast and Furious.
Acorn sets (5 and 6) are also impressives.
Version 2.4 zoom x 1
The same in full screen size, I recommand sets 6 and 9.
Timing depend on set size.
Optimization:
#pragma mode( separator(.,;) integer(h64) )
// Conway's Game of Life B3/S23
Black, White;
LNext()
LOCAL px, py, Clr, Tmp;
// Calcul Voisins
FOR py FROM 1 TO 78 DO
FOR px FROM 1 TO 78 DO
Tmp:= BITAND(GETPIX_P(px-1, py),#800h)+BITAND(GETPIX_P(px, py),#800h)+BITAND(GETPIX_P(px+1, py),#800h);
Tmp:=BITAND(GETPIX_P(px, py),White)+#18h-BITSR(Tmp,8);
PIXON_P(px, py, Tmp);
Tmp:= BITAND(GETPIX_P(px, py-1),#18h)+BITAND(GETPIX_P(px, py),#18h)+BITAND(GETPIX_P(px, py+1),#18h);
IF (Tmp == #18h AND BITAND(GETPIX_P(px, py),#800h) <> 0) OR ((Tmp == #20h OR Tmp == #18h) AND BITAND(GETPIX_P(px, py),#800h) == 0) THEN
Clr:= Black;
ELSE
Clr:= White;
PIXON_P(px, py, Clr+BITAND(GETPIX_P(px, py),#18h));
BLIT_P(G0,80,0,319,239,G0,0,0,79,79);
RLEMap (px, py, RLE, ClrOn)
LOCAL Row, Col, Ptr, Cnt, Cod;
Row:= 0; Col:= 0; Cnt:= 0;
FOR Ptr FROM 1 TO DIM(RLE) DO
Cod:= MID(RLE, Ptr, 1); // pour debogage
CASE
IF INSTRING("0123456789", MID(RLE, Ptr, 1)) <> 0 THEN Cnt:= Cnt*10+EXPR(MID(RLE, Ptr, 1)); END;
IF MID(RLE, Ptr, 1) == "$" THEN Row:= Row+MAX(1, Cnt); Col:= 0; Cnt:= 0; END;
IF INSTRING("b.", MID(RLE, Ptr, 1)) <> 0 THEN Col:= Col+MAX(1, Cnt); Cnt:= 0; END;
IF INSTRING("oA", MID(RLE, Ptr, 1)) <> 0 THEN
FOR Col FROM Col TO Col+MAX(1, Cnt)-1 DO
PIXON_P(px+Col, py+Row, ClrOn);
Cnt:= 0; END;
EXPORT Life(St)
LOCAL Kb;
Black:= #0h; White:= #F8F8E0h;
RECT_P(0,0,319,239,White);
IF St == 1 THEN
RLEMap (10, 11, "3o!", Black); // Blinker
RLEMap (23, 14, "bo$3o$obo$3o$bo!", Black); // Pulsar
LNext();
RLEMap (10, 16, "b3o$3o!", Black); // Toad
RLEMap (40, 14, "bo$3o$obo$3o$bo!", Black); // Pulsar
RLEMap (10, 26, "24bo11b$22bobo11b$12b2o6b2o12b2o$11bo3bo4b2o12b2o$2o8bo5bo3b2o14b$2o8bo3bob2o4bobo11b$10bo5bo7bo11b$11bo3bo20b$12b2o!", Black); // Canon
IF St == 2 THEN
RLEMap (27, 18, "10b2o3b2o10b$9bo2bobo2bo9b$5b2o3b2o3b2o3b2o5b$5bo15bo5b$2b2obo15bob2o2b$o2bob2o13b2obo2bo$2obo19bob2o$3bo19bo3b$3b2o17b2o3b$9b3o3b3o9b$9bobo3bobo9b$9b3o3b3o9b4$9bo7bo9b$8bobo5bobo8b$9bo7bo!", Black);
IF St == 3 THEN
RLEMap (1, 1, "13bo20b$13b3o7b2o9b$16bo6bo10b$9bo5b2o4bobo10b$9b3o9b2o11b$12bo4b3o6b2o6b$5bo5b2o4b3o6bo7b$5b3o16bobo7b$8bo15b2o8b$bo5b2o4b3o13b2o3b$b3o9b3o4b3o6bo4b$4bo4b3o8b3o4bobo4b$3b2o4b3o4b3o8b2o5b$16b3o4b3o6b2o$23b3o6bob$5b3o22bobob$5b3o4b3o15b2o2b$2b2o8b3o4b3o12b$bobo4b3o8b3o4b3o5b$bo6b3o4b3o8b3o5b$2o13b3o4b3o9b$5b2o15b3o4b2o3b$4bobo22bo4b$4bo6b3o16b3ob$3b2o6b3o4b3o4b2o5bob$8b2o8b3o4bo8b$7bobo4b3o9b3o5b$7bo6b3o4b2o5bo5b$6b2o13bo12b$11b2o9b3o9b$10bobo4b2o5bo9b$10bo6bo16b$9b2o7b3o13b$20bo!", Black);
IF St == 4 THEN
RLEMap (0, 0, "11bo7bo39bo7bo11b$10bobo5bobo37bobo5bobo10b$11bo7bo9b2o17b2o9bo7bo11b$29bo19bo29b$27bobo19bobo27b$27b2o21b2o27b$6bo17bo29bo17bo6b$6bo17bo12bo3bo12bo17bo6b$6bo17bo11bobobobo11bo17bo6b$2b2o31bo2bobo2bo31b2o2b$bobo7b3o3b3o15bo7bo15b3o3b3o7bobob$bo8bo3bobo3bo14bo2bobo2bo14bo3bobo3bo8bob$2o34bobobobo34b2o$37bo3bo37b$7b2o13b2o31b2o13b2o7b$7b2o13b2o31b2o13b2o7b$37bo3bo37b$2o34bobobobo34b2o$bo8bo3bobo3bo14bo2bobo2bo14bo3bobo3bo8bob$bobo7b3o3b3o15bo7bo15b3o3b3o7bobob$2b2o31bo2bobo2bo31b2o2b$6bo17bo11bobobobo11bo17bo6b$6bo17bo12bo3bo12bo17bo6b$6bo17bo29bo17bo6b$27b2o21b2o27b$27bobo19bobo27b$29bo19bo29b$11bo7bo9b2o17b2o9bo7bo11b$10bobo5bobo37bobo5bobo10b$11bo7bo39bo7bo!", Black); // Pre-pulsar shuttle 47
IF St == 5 THEN
RLEMap (50, 60, "bo$3bo$2o2b3o!", Black); // Acorn
REPEAT LNext(); Kb:= GETKEY(); UNTIL Kb==4;
Optimizations:
Lignes, Black, White;
LNext()
// Calcul Voisins
CASE
IF Lignes[py+1] == 1 THEN
LINE_P(0,py,79,py,White);
Lignes[py+1] := 0;
IF Lignes[py+1] == 2 THEN
IF Lignes[py]+Lignes[py+1]+Lignes[py+2] <> 0 THEN
IF Lignes[py+1] == 2 THEN Lignes[py+1] := 1; END;
Clr:= Black; Lignes[py+1] := 2;
ELSE
Clr:= White;
RLEMap (px, py, RLE)
CASE
PIXON_P(px+Col, py+Row, Black);
Cnt:= 0; Lignes[py+Row+1]:= 2;
EXPORT Life(St)
LOCAL Kb, Lap;
Lignes:= MAKELIST(0,A,0,79);
IF St == 1 THEN
RLEMap (10, 11, "3o!"); // Blinker
RLEMap (23, 14, "bo$3o$obo$3o$bo!"); // Pulsar
LNext();
RLEMap (10, 16, "b3o$3o!"); // Toad
RLEMap (40, 14, "bo$3o$obo$3o$bo!"); // Pulsar
RLEMap (10, 26, "24bo11b$22bobo11b$12b2o6b2o12b2o$11bo3bo4b2o12b2o$2o8bo5bo3b2o14b$2o8bo3bob2o4bobo11b$10bo5bo7bo11b$11bo3bo20b$12b2o!"); // Canon
IF St == 2 THEN
RLEMap (27, 18, "10b2o3b2o10b$9bo2bobo2bo9b$5b2o3b2o3b2o3b2o5b$5bo15bo5b$2b2obo15bob2o2b$o2bob2o13b2obo2bo$2obo19bob2o$3bo19bo3b$3b2o17b2o3b$9b3o3b3o9b$9bobo3bobo9b$9b3o3b3o9b4$9bo7bo9b$8bobo5bobo8b$9bo7bo!");
IF St == 3 THEN
RLEMap (1, 1, "13bo20b$13b3o7b2o9b$16bo6bo10b$9bo5b2o4bobo10b$9b3o9b2o11b$12bo4b3o6b2o6b$5bo5b2o4b3o6bo7b$5b3o16bobo7b$8bo15b2o8b$bo5b2o4b3o13b2o3b$b3o9b3o4b3o6bo4b$4bo4b3o8b3o4bobo4b$3b2o4b3o4b3o8b2o5b$16b3o4b3o6b2o$23b3o6bob$5b3o22bobob$5b3o4b3o15b2o2b$2b2o8b3o4b3o12b$bobo4b3o8b3o4b3o5b$bo6b3o4b3o8b3o5b$2o13b3o4b3o9b$5b2o15b3o4b2o3b$4bobo22bo4b$4bo6b3o16b3ob$3b2o6b3o4b3o4b2o5bob$8b2o8b3o4bo8b$7bobo4b3o9b3o5b$7bo6b3o4b2o5bo5b$6b2o13bo12b$11b2o9b3o9b$10bobo4b2o5bo9b$10bo6bo16b$9b2o7b3o13b$20bo!");
IF St == 4 THEN
RLEMap (0, 0, "11bo7bo39bo7bo11b$10bobo5bobo37bobo5bobo10b$11bo7bo9b2o17b2o9bo7bo11b$29bo19bo29b$27bobo19bobo27b$27b2o21b2o27b$6bo17bo29bo17bo6b$6bo17bo12bo3bo12bo17bo6b$6bo17bo11bobobobo11bo17bo6b$2b2o31bo2bobo2bo31b2o2b$bobo7b3o3b3o15bo7bo15b3o3b3o7bobob$bo8bo3bobo3bo14bo2bobo2bo14bo3bobo3bo8bob$2o34bobobobo34b2o$37bo3bo37b$7b2o13b2o31b2o13b2o7b$7b2o13b2o31b2o13b2o7b$37bo3bo37b$2o34bobobobo34b2o$bo8bo3bobo3bo14bo2bobo2bo14bo3bobo3bo8bob$bobo7b3o3b3o15bo7bo15b3o3b3o7bobob$2b2o31bo2bobo2bo31b2o2b$6bo17bo11bobobobo11bo17bo6b$6bo17bo12bo3bo12bo17bo6b$6bo17bo29bo17bo6b$27b2o21b2o27b$27bobo19bobo27b$29bo19bo29b$11bo7bo9b2o17b2o9bo7bo11b$10bobo5bobo37bobo5bobo10b$11bo7bo39bo7bo!"); // Pre-pulsar shuttle 47
IF St == 5 THEN
RLEMap (50, 60, "bo$3bo$2o2b3o!"); // Acorn
REPEAT
Lap:= TICKS();
LNext();
Lap:= TICKS()-Lap;
// to display time between screen updates
TEXTOUT_P(Lap,0,160,0,Black,80,White);
Kb:= GETKEY();
UNTIL Kb==4;
Optimizations:
// Author: Patrice Torchet
// 1.0 2014/01 First release.
// 1.1 2014/02 Little optimization for speed to avoid recalc of empty lines.
// 1.2 2014/02 Better optimization for speed to avoid recalc of empty left and right
LNext()
LOCAL px, py, db, fn, Clr, Tmp;
// Calcul Voisins
FOR py FROM 2 TO 81 DO
CASE
IF Lignes[py,1] == 1 THEN
Lignes[py] := {0,80,0};
IF Lignes[py,1] == 2 THEN
db:= MAX(Lignes[py,2]-1,1); fn:= MIN(Lignes[py,3]+1,78);
Lignes[py] := {2,80,0};
FOR px FROM db TO fn DO
Tmp:= #18h-BITSR(BITAND(GETPIX_P(px-1, py),#800h)+BITAND(GETPIX_P(px, py),#800h)+BITAND(GETPIX_P(px+1, py),#800h),8);
IF Tmp <> #0 THEN Lignes[py] := {2,MIN(Lignes[py,2],px),MAX(Lignes[py,3],px)}; END;
PIXON_P(px, py, BITAND(GETPIX_P(px, py),White)+Tmp);
IF Lignes[py-1,1]+Lignes[py,1]+Lignes[py+1,1] <> 0 THEN
db:= MIN(Lignes[py-1,2],Lignes[py,2],Lignes[py+1,2]); fn:=MAX(Lignes[py-1,3],Lignes[py,3],Lignes[py+1,3]);
IF Lignes[py,1] == 2 THEN Lignes[py,1]:= 1; END;
Clr:= Black; Lignes[py] := {2,MIN(Lignes[py,2],px),MAX(Lignes[py,3],px)};
ELSE
Clr:= White;
BLIT_P(G0,80,0,319,239,G0,0,2,79,81);
Row:= py+2; Col:= px+1; Cnt:= 0;
Cod:= MID(RLE, Ptr, 1); // for debug
CASE
IF MID(RLE, Ptr, 1) == "$" THEN Row:= Row+MAX(1, Cnt); Col:= px+1; Cnt:= 0; END;
Lignes[Row,1]:= 2; Lignes[Row,2]:= MIN(Lignes[Row,2],Col);
PIXON_P(Col, Row, Black);
Cnt:= 0; Lignes[Row,3]:= MAX(Lignes[Row,3],Col);
EXPORT Life(St)
LOCAL Kb, Lap;
Lignes:= MAKELIST({0,80,0},A,0,83);
IF St == 1 THEN
LNext();
IF St == 2 THEN
RLEMap (0, 0, "10b2o3b2o10b$9bo2bobo2bo9b$5b2o3b2o3b2o3b2o5b$5bo15bo5b$2b2obo15bob2o2b$o2bob2o13b2obo2bo$2obo19bob2o$3bo19bo3b$3b2o17b2o3b$9b3o3b3o9b$9bobo3bobo9b$9b3o3b3o9b4$9bo7bo9b$8bobo5bobo8b$9bo7bo!");
IF St == 3 THEN
RLEMap (0, 0, "13bo20b$13b3o7b2o9b$16bo6bo10b$9bo5b2o4bobo10b$9b3o9b2o11b$12bo4b3o6b2o6b$5bo5b2o4b3o6bo7b$5b3o16bobo7b$8bo15b2o8b$bo5b2o4b3o13b2o3b$b3o9b3o4b3o6bo4b$4bo4b3o8b3o4bobo4b$3b2o4b3o4b3o8b2o5b$16b3o4b3o6b2o$23b3o6bob$5b3o22bobob$5b3o4b3o15b2o2b$2b2o8b3o4b3o12b$bobo4b3o8b3o4b3o5b$bo6b3o4b3o8b3o5b$2o13b3o4b3o9b$5b2o15b3o4b2o3b$4bobo22bo4b$4bo6b3o16b3ob$3b2o6b3o4b3o4b2o5bob$8b2o8b3o4bo8b$7bobo4b3o9b3o5b$7bo6b3o4b2o5bo5b$6b2o13bo12b$11b2o9b3o9b$10bobo4b2o5bo9b$10bo6bo16b$9b2o7b3o13b$20bo!"); // Extended dinner table
IF St == 4 THEN
REPEAT
Lap:= TICKS();
LNext();
Lap:= TICKS()-Lap;
Kb:= GETKEY();
UNTIL Kb==4;
// The 2 lower bits of each pixels is used to store neighb on right and left.
// Avoid recalc of empty lines.
// Avoid recalc of empty left and right
// 2.0 2014/02 Even faster, better scaling
// using bitmap storage and bitwise operations
Lignes;
LOcc(Lst) // Occurence
LOCAL v1, v2, v3, v4, sx, cx;
v1:= #0; v2:= #0; v3:= #0; v4:= #0;
FOR sx FROM 1 TO SIZE(Lst) DO
cx:= Lst(sx);
v4:= BITOR(v4,BITAND(v3,cx)); v3:= BITOR(v3,BITAND(v2,cx));
v2:= BITOR(v2,BITAND(v1,cx)); v1:= BITOR(v1,cx);
RETURN {v1, v2, v3, v4};
LNext()
LOCAL T1, T2, T3, L, Tmp;
Tmp:= MAKELIST({#0,#0},A,1,82);
FOR L FROM 2 TO 81 DO
IF BITOR(Lignes(L-1,1),Lignes(L,1),Lignes(L+1,1)) <> #0 THEN
T1:= LOcc({BITSL(Lignes(L-1,1),1),Lignes(L-1,1),BITSR(Lignes(L-1,1),1), BITSL(Lignes(L,1),1),BITSR(Lignes(L,1),1), BITSL(Lignes(L+1,1),1),Lignes(L+1,1),BITSR(Lignes(L+1,1),1)});
T2:= BITAND(BITOR(BITXOR(T1(3),T1(4)), BITAND(BITXOR(T1(2),T1(3)),Lignes(L,1))),#1FFFFFFFFFE);
//IF BITAND(T2, #10000000000) <> #0 THEN T3:= #1; ELSE T3:= #0; END;
T3:= BITSR(T2, 40);
ELSE
T2:= #0; T3:= #0;
IF BITOR(Lignes(L-1,2),Lignes(L,2),Lignes(L+1,2)) <> #0 THEN
T1:= LOcc({BITSL(Lignes(L-1,2),1),Lignes(L-1,2),BITSR(Lignes(L-1,2),1), BITSL(Lignes(L,2),1),BITSR(Lignes(L,2),1), BITSL(Lignes(L+1,2),1),Lignes(L+1,2),BITSR(Lignes(L+1,2),1)});
T3:= BITOR(T3,BITAND(BITOR(BITXOR(T1(3),T1(4)), BITAND(BITXOR(T1(2),T1(3)),Lignes(L,2))),#1FFFFFFFFFE));
IF BITAND(T3, #2) <> #0 THEN T2:= BITOR(T2,#20000000000) END;
Tmp(L):={T2,T3};
Lignes:= Tmp;
LDisp()
LOCAL T1, L, L2, C2;
RECT_P(0,0,79,82,#F8F8E0h);
FOR L2 FROM 1 TO 2 DO
T1:= Lignes(L,L2); C2:= (L2-1)*40;
WHILE T1 <> 0 DO
IF BITAND(T1,#1) THEN PIXON_P(C2, L, #0); END;
T1:= BITSR(T1,1); C2:= C2+1;
BLIT_P(G0,80,0,320,240,G0,0,2,80,82);
Row:= py+2; Col:= px; Cnt:= 0;
CASE
IF MID(RLE, Ptr, 1) == "$" THEN Row:= Row+MAX(1, Cnt); Col:= px; Cnt:= 0; END;
Lignes(Row, IP(Col/40)+1):= BITOR(Lignes(Row, IP(Col/40)+1), BITSL(#1,(Col MOD 40)+1 ));
Cnt:= 0;
FOR Row FROM 2 TO 81 DO
IF BITAND(Lignes(Row,1), #10000000000) <> #0 THEN Lignes(Row,2):= BITOR(Lignes(Row,2),#1) END;
IF BITAND(Lignes(Row,2), #2) <> #0 THEN Lignes(Row,1):= BITOR(Lignes(Row,1),#20000000000) END;
LDisp();
EXPORT Life(St)
LOCAL Kb, Lap;
Lignes:= MAKELIST({#0,#0},A,1,82);
RECT_P(0,0,319,239,#F8F8E0h);
IF St == 1 THEN
RLEMap (1, 1, "3o!"); // Blinker
RLEMap (13, 5, "bo$3o$obo$3o$bo!"); // Pulsar
LNext();
RLEMap (1, 6, "b3o$3o!"); // Toad
RLEMap (30, 5, "bo$3o$obo$3o$bo!"); // Pulsar
RLEMap (1, 17, "24bo11b$22bobo11b$12b2o6b2o12b2o$11bo3bo4b2o12b2o$2o8bo5bo3b2o14b$2o8bo3bob2o4bobo11b$10bo5bo7bo11b$11bo3bo20b$12b2o!"); // Glider Canon
IF St == 2 THEN
RLEMap (1, 1, "10b2o3b2o10b$9bo2bobo2bo9b$5b2o3b2o3b2o3b2o5b$5bo15bo5b$2b2obo15bob2o2b$o2bob2o13b2obo2bo$2obo19bob2o$3bo19bo3b$3b2o17b2o3b$9b3o3b3o9b$9bobo3bobo9b$9b3o3b3o9b4$9bo7bo9b$8bobo5bobo8b$9bo7bo!"); // Pre-pulsar shuttle 29
IF St == 3 THEN
RLEMap (1, 1, "13bo20b$13b3o7b2o9b$16bo6bo10b$9bo5b2o4bobo10b$9b3o9b2o11b$12bo4b3o6b2o6b$5bo5b2o4b3o6bo7b$5b3o16bobo7b$8bo15b2o8b$bo5b2o4b3o13b2o3b$b3o9b3o4b3o6bo4b$4bo4b3o8b3o4bobo4b$3b2o4b3o4b3o8b2o5b$16b3o4b3o6b2o$23b3o6bob$5b3o22bobob$5b3o4b3o15b2o2b$2b2o8b3o4b3o12b$bobo4b3o8b3o4b3o5b$bo6b3o4b3o8b3o5b$2o13b3o4b3o9b$5b2o15b3o4b2o3b$4bobo22bo4b$4bo6b3o16b3ob$3b2o6b3o4b3o4b2o5bob$8b2o8b3o4bo8b$7bobo4b3o9b3o5b$7bo6b3o4b2o5bo5b$6b2o13bo12b$11b2o9b3o9b$10bobo4b2o5bo9b$10bo6bo16b$9b2o7b3o13b$20bo!"); // Extended dinner table
IF St == 4 THEN
REPEAT
Lap:= TICKS();
LNext(); LDisp();
Lap:= TICKS()-Lap;
TEXTOUT_P(Lap,0,160,0,#0,80,#F8F8E0h);
Kb:= GETKEY();
UNTIL Kb==4;
Optimization:
// 2.1 2014/02 with trail
// show life span in green
// 2.2 A little optimization in LOcc
// Unrolled the loop and removed unneeded ops
// the Game of Life play field is 80*80 cells
// each ligne is stored in 2 integers using 2 time 40 bits
// Slice = 40
// Mask = 2^41-2= #1FFFFFFFFFEh
// LeftBit = 2^41 = #10000000000h
// RightLink= 2^42 = #20000000000h
// LeftLink = 1 = 1h
// RightBit = 2 = 2h
EXPORT Lignes, Trail;
LOcc(P1, P2, P3) // Occurence
LOCAL v1, v2, v3, v4, T;
v2:= BITAND(P1,P3); v1:= BITOR(P1,P3);
T:= BITSR(P1);
v3:= BITAND(v2,T); v2:= BITOR(v2,BITAND(v1,T)); v1:= BITOR(v1,T);
T:= BITSL(P1);
v4:= BITAND(v3,T); v3:= BITOR(v3,BITAND(v2,T)); v2:= BITOR(v2,BITAND(v1,T)); v1:= BITOR(v1,T);
T:= BITSR(P2);
v4:= BITOR(v4,BITAND(v3,T)); v3:= BITOR(v3,BITAND(v2,T)); v2:= BITOR(v2,BITAND(v1,T)); v1:= BITOR(v1,T);
T:= BITSL(P2);
T:= BITSR(P3);
T:= BITSL(P3);
LNext()
LOCAL T1, T2, T3, L;
Trail:= Lignes;
IF BITOR(Trail(L-1,1),Trail(L,1),Trail(L+1,1)) <> #0 THEN
T1:= LOcc(Trail(L-1,1),Trail(L,1),Trail(L+1,1));
T2:= BITAND(BITOR(BITXOR(T1(3),T1(4)), BITAND(BITXOR(T1(2),T1(3)),Trail(L,1))),#1FFFFFFFFFE);
T3:= BITSR(T2, 40);
ELSE
T2:= #0; T3:= #0;
IF BITOR(Trail(L-1,2),Trail(L,2),Trail(L+1,2)) <> #0 THEN
T1:= LOcc(Trail(L-1,2),Trail(L,2),Trail(L+1,2));
T3:= BITOR(T3,BITAND(BITOR(BITXOR(T1(3),T1(4)), BITAND(BITXOR(T1(2),T1(3)),Trail(L,2))),#1FFFFFFFFFE));
Lignes(L):={T2,T3};
LDisp()
LOCAL T1, Tr, L, L2, C2;
//RECT_P(0,0,79,82,#F8F8E0h);
T1:= Lignes(L,L2); Tr:= Trail(L,L2); C2:= (L2-1)*40-1;
WHILE T1 <> #0 OR Tr <> #0 DO
ELSE
IF BITAND(Tr,#1) THEN PIXON_P(C2, L, #F800); END;
T1:= BITSR(T1,1); Tr:= BITSR(Tr,1); C2:= C2+1;
CASE
Cnt:= 0;
LDisp();
EXPORT Life(St)
LOCAL Kb, Lap;
Trail:= MAKELIST({#0,#0},A,1,82);
IF St == 1 THEN
LNext();
IF St == 2 THEN
IF St == 3 THEN
IF St == 4 THEN
IF St == 5 THEN
RLEMap (38, 38, "bo$3bo$2o2b3o!"); // Acorn
REPEAT
Lap:= TICKS();
LNext(); LDisp();
Lap:= TICKS()-Lap;
Kb:= GETKEY();
UNTIL Kb==4;
Optimization:
// 2.3 board is now 120*100 and zoom x2 and
// Next Gen takes advantage of calc on lists
// the Game of Life play field is 120*100 cells
T:= BITSR(P1);
T:= BITSL(P1);
T:= BITSR(P2);
T:= BITSL(P2);
T:= BITSR(P3);
T:= BITSL(P3);
v4:= BITOR(v4,BITAND(v3,T)); v3:= BITOR(v3,BITAND(v2,T)); v2:= BITOR(v2,BITAND(v1,T)); // v1:= BITOR(v1,T);
LNext() // Next Generation
LOCAL T1, T2, Row;
Trail:= Lignes;
Trail(1):= BITOR(Trail(1),BITSL(BITAND(Trail(2),#2),60));
Trail(2):= BITOR(Trail(2),BITSR(Trail(1),60));
FOR Row FROM 1 TO 2 DO
T1:= LOcc(SUB(Trail(Row),1,100),SUB(Trail(Row),2,101),SUB(Trail(Row),3,102));
T2:= BITAND(BITOR(BITXOR(T1(3),T1(4)), BITAND(BITXOR(T1(2),T1(3)),SUB(Trail(Row),2,101))),#1FFFFFFFFFFFFFFE);
Lignes(Row):= CONCAT(#0,T2,#0);
LDisp()
FOR L FROM 0 TO 99 DO
T1:= Lignes(L2,L+1); Tr:= Trail(L2,L+1); C2:= (L2-1)*60-1;
IF BITAND(T1,#1) THEN PIXON_P(L, C2, #0);
ELSE
IF BITAND(Tr,#1) THEN PIXON_P(L, C2, #F800); END;
BLIT_P(G0,120,0,320,240,G0,0,0,100,120);
Row:= py; Col:= px+2; Cnt:= 0;
CASE
IF INSTRING("0123456789", Cod) <> 0 THEN Cnt:= Cnt*10+EXPR(Cod); END;
IF Cod == "$" THEN Row:= Row+MAX(1, Cnt); Col:= px+2; Cnt:= 0; END;
IF INSTRING("b.", Cod) <> 0 THEN Col:= Col+MAX(1, Cnt); Cnt:= 0; END;
IF INSTRING("oA", Cod) <> 0 THEN
Lignes(IP(Row/60)+1, Col):= BITOR(Lignes(IP(Row/60)+1, Col), BITSL(#2,(Row MOD 60) ));
Cnt:= 0;
LDisp();
EXPORT Life(St)
LOCAL Kb, Lap;
Lignes:= MAKELIST(MAKELIST(#0,B,1,102),A,1,2);
Trail:= Lignes;
IF St == 1 THEN
LNext();
IF St == 2 THEN
IF St == 3 THEN
IF St == 4 THEN
IF St == 5 THEN
IF St == 6 THEN
RLEMap (52, 80, "o$obo$$bo$o$o$o!"); // Acorn vertical
REPEAT
Lap:= TICKS();
LNext(); LDisp();
Lap:= TICKS()-Lap;
TEXTOUT_P(Lap,0,225,0,#0,80,#F8F8E0h);
Kb:= GETKEY();
UNTIL Kb==4;
Optimization:
// 2.1 2014/02 with PrevN
// 2.3 board is now 120*160 and zoom x2 and
// Next Gen takes advantage of lists handling
// 2.4 Getting Fast and Furious on large sets
// the Game of Life play field is 120*160 cells
// each ligne is stored in 2 integers using 2 time 60 bits
// Slice = 60
// Mask = 2^61-2= #1FFFFFFFFFFFFFFEh
EXPORT Lignes;
PrevD, PrevN, Delta, Tmp;
IterMax:= -1;
//This routine is good with small sets but do degrade with big ones.
LNext() // Next Generation one by one elements
LOCAL R, Row;
LOCAL P1, P2, P3, v1, v2, v3, v4;
// Link between columns
FOR R FROM 1 TO 2 DO
Tmp:= Lignes(R);
IF R <> 1 THEN Tmp:= BITOR(Tmp,BITAND(BITSR(PrevN(R-1),60),#1)); END;
IF R <> 2 THEN Tmp:= BITOR(Tmp,BITSL(BITAND(Lignes(R+1),#2),60)); END;
Delta:= BITXOR(PrevN(R),Tmp);
PrevN(R):=Tmp;
FOR Row FROM 2 TO 161 DO
IF BITOR(Delta(Row-1),Delta(Row),Delta(Row+1)) <> #0 THEN
P1:= PrevN(R,Row-1); P2:= PrevN(R,Row); P3:= PrevN(R,Row+1);
P1:= BITSL(P1); P2:= BITSL(P2); P3:= BITSL(P3);
v3:= BITAND(v2,P1); v2:= BITOR(v2,BITAND(v1,P1)); v1:= BITOR(v1,P1);
v4:= BITAND(v3,P2); v3:= BITOR(v3,BITAND(v2,P2)); v2:= BITOR(v2,BITAND(v1,P2)); v1:= BITOR(v1,P2);
v4:= BITOR(v4,BITAND(v3,P3)); v3:= BITOR(v3,BITAND(v2,P3)); v2:= BITOR(v2,BITAND(v1,P3)); v1:= BITOR(v1,P3);
P1:= BITSR(P1,2); P2:= BITSR(P2,2); P3:= BITSR(P3,2);
v4:= BITOR(v4,BITAND(v3,P1)); v3:= BITOR(v3,BITAND(v2,P1)); v2:= BITOR(v2,BITAND(v1,P1)); v1:= BITOR(v1,P1);
v4:= BITOR(v4,BITAND(v3,P2)); v3:= BITOR(v3,BITAND(v2,P2)); v2:= BITOR(v2,BITAND(v1,P2)); v1:= BITOR(v1,P2);
v4:= BITOR(v4,BITAND(v3,P3)); v3:= BITOR(v3,BITAND(v2,P3)); v2:= BITOR(v2,BITAND(v1,P3)); // v1:= BITOR(v1,P3);
Lignes(R,Row):= BITAND(BITXOR(BITOR(v3,BITAND(v2,PrevN(R,Row))),v4),#1FFFFFFFFFFFFFFE);
LDisp()
LOCAL T1, Tx, C, R2, R;
FOR R2 FROM 1 TO 2 DO
Delta:= BITXOR(Lignes(R2),PrevD(R2));
FOR C FROM 0 TO 159 DO
T1:= Lignes(R2,C+2); Tx:= Delta(C+2); R:= (R2-1)*60;
WHILE Tx > #1 DO
IF BITAND(Tx,#2) THEN
IF BITAND(T1,#2) THEN PIXON_P(G1, C, R, #0);
ELSE PIXON_P(G1, C, R, #F800);
T1:= BITSR(T1,1); Tx:= BITSR(Tx,1); R:= R+1;
PrevD:= Lignes;
BLIT_P(G0,G1);
LOCAL Row, Col, Ptr, Cnt, Cod, Tmp;
CASE
Tmp:= BITOR(Lignes(IP(Row/60)+1, Col), BITSL(#2,(Row MOD 60) ));
Lignes(IP(Row/60)+1, Col):= Tmp;
Cnt:= 0;
LDisp();
EXPORT Life(St)
LOCAL Kb, LapN, LapD;
LOCAL Tm:=0, Gen:=0;
Gen:=0;
Lignes:= MAKELIST(MAKELIST(#0,B,1,322),A,1,4);
PrevN:= Lignes; PrevD:= Lignes;
DIMGROB(G1,160,120); RECT_P(G1);
RECT_P(0,0,159,119,#F8F8E0h);
IF St == 1 THEN
LNext();
IF St == 2 THEN
IF St == 3 THEN
IF St == 4 THEN
IF St == 5 THEN
RLEMap (80, 80, "bo$3bo$2o2b3o!"); // Acorn
IF St == 6 THEN
RLEMap (80, 80, "o$obo$$bo$o$o$o!"); // Acorn vertical
IF St == 7 THEN
RLEMap (1, 1, "26b2o3b2o$24b3obo2b2o$23bo4bo$23bo2b2ob4o$22b2obobobo2bo$23bobobobo$23bobob2o$24bo2$37b2o$28b2o7bo$28b2o5bobo$9bo25b2o$9b3o$12bo15b2o$11b2o15bobo$28bo2$2ob2o$2obo21b2o$3bo22bo$3b3o4b2o11b3o$b2o3bo3b2o11bo22bo$o2b4o21b2o14b5o$2obo15b2o8bo13bo5bo$bo2b3o12bobo7bobo12b3o2bo$bo5bo13bo8b2o15bob2o$2b5o14b2o21b4o2bo$4bo22bo11b2o3bo3b2o$25b3o11b2o4b3o$24bo22bo$24b2o21bob2o$46b2ob2o3$38b2o$38bo$39b3o$14b2o25bo$13bobo5b2o$13bo7b2o$12b2o2$26bo$22b2obobo$21bobobobo$18bo2bobobob2o$18b4ob2o2bo$22bo4bo$18b2o2bob3o$18b2o3b2o!"); // Snark Glider Reflector Loop
IF St == 8 THEN
RLEMap (50, 50, "b2o$2o$bo!"); // R pentamino
IF St == 9 THEN
RLEMap (80, 800, "o3b3o$3o2bo$bo!"); // Rabits
REPEAT
LapN:= TICKS(); LNext(); LapN:= TICKS()-LapN;
LapD:= TICKS(); LDisp(); LapD:= TICKS()-LapD;
Tm:=Tm+LapN+LapD; Gen:= Gen+1; IF Gen == IterMax THEN RETURN Tm/IterMax; END;
TEXTOUT_P(STRING(Gen,2,0)+"-"+STRING(LapN,2,0)+"-"+STRING(LapD,2,0),0,225,0,#0,160,#F8F8E0h);
Kb:= GETKEY();
UNTIL Kb==4;
Lignes:= 0; PrevN:= 0; PrevD:= 0;
// Slice = 60
EXPORT Lignes;
IterMax:= -1;
LOCAL R, Row;
FOR R FROM 1 TO 4 DO
Tmp:= Lignes(R);
IF R <> 4 THEN Tmp:= BITOR(Tmp,BITSL(BITAND(Lignes(R+1),#2),60)); END;
PrevN(R):=Tmp;
FOR Row FROM 2 TO 321 DO
LDisp()
FOR R2 FROM 1 TO 4 DO
FOR C FROM 0 TO 319 DO
WHILE Tx > #1 DO
PrevD:= Lignes;
BLIT_P(G0,G1);
CASE
Cnt:= 0;
LDisp();
EXPORT Life(St)
Gen:=0;
DIMGROB(G1,320,240); RECT_P(G1);
IF St == 1 THEN
LNext();
IF St == 2 THEN
IF St == 3 THEN
IF St == 4 THEN
IF St == 5 THEN
RLEMap (160, 150, "bo$3bo$2o2b3o!"); // Acorn
IF St == 6 THEN
RLEMap (160, 150, "o$obo$$bo$o$o$o!"); // Acorn vertical
IF St == 7 THEN
IF St == 8 THEN
IF St == 9 THEN
RLEMap (160, 150, "o3b3o$3o2bo$bo!"); // Rabits
REPEAT
Kb:= GETKEY();
UNTIL Kb==4;
