Full Version: Z Periodic Table (tableau periodique)
Following last weeks announcement in the media that the discovery of new elements has been confirmed, I thought I would make a simple periodic table. This one fits on one page, unlike some that need scrolling. And it works on the Android emulation.
There is some limited interaction, but the user interface does need more work.
Element names and symbols are case sensitive.
 //PERIODS
 //LOCAL APERIODS:={1,3,11,19,37,55,87};
 //ELEMENT DATA AND POSITION
 //ATOM: 1..118 = LIST POS
 //GROUP/COL: 1..18 OR NONE(<0:ARBITRARY FOR DISPLAY ONLY)
 //PERIOD/ROW: 1..7
 EXPORT Z_ELEMENTS:={
 {  1,  1, 1},
 {  2, 18, 1},
 {  3,  1, 2},
 {  4,  2, 2},
 {  5, 13, 2},
 {  6, 14, 2},
 {  7, 15, 2},
 {  8, 16, 2},
 {  9, 17, 2},
 { 10, 18, 2},
 { 11,  1, 3},
 { 12,  2, 3},
 { 13, 13, 3},
 { 14, 14, 3},
 { 15, 15, 3},
 { 16, 16, 3},
 { 17, 17, 3},
 { 18, 18, 3},
 { 19,  1, 4},
 { 20,  2, 4},
 { 21,  3, 4},
 { 22,  4, 4},
 { 23,  5, 4},
 { 24,  6, 4},
 { 25,  7, 4},
 { 26,  8, 4},
 { 27,  9, 4},
 { 28, 10, 4},
 { 29, 11, 4},
 { 30, 12, 4},
 { 31, 13, 4},
 { 32, 14, 4},
 { 33, 15, 4},
 { 34, 16, 4},
 { 35, 17, 4},
 { 36, 18, 4},
 { 37,  1, 5},
 { 38,  2, 5},
 { 39,  3, 5},
 { 40,  4, 5},
 { 41,  5, 5},
 { 42,  6, 5},
 { 43,  7, 5},
 { 44,  8, 5},
 { 45,  9, 5},
 { 46, 10, 5},
 { 47, 11, 5},
 { 48, 12, 5},
 { 49, 13, 5},
 { 50, 14, 5},
 { 51, 15, 5},
 { 52, 16, 5},
 { 53, 17, 5},
 { 54, 18, 5},
 { 55,  1, 6},
 { 56,  2, 6},
 { 57, −3, 6},
 { 58, −4, 6},
 { 59, −5, 6},
 { 60, −6, 6},
 { 61, −7, 6},
 { 62, −8, 6},
 { 63, −9, 6},
 { 64,−10, 6},
 { 65,−11, 6},
 { 66,−12, 6},
 { 67,−13, 6},
 { 68,−14, 6},
 { 69,−15, 6},
 { 70,−16, 6},
 { 71,−17, 6},
 { 72,  4, 6},
 { 73,  5, 6},
 { 74,  6, 6},
 { 75,  7, 6},
 { 76,  8, 6},
 { 77,  9, 6},
 { 78, 10, 6},
 { 79, 11, 6},
 { 80, 12, 6},
 { 81, 13, 6},
 { 82, 14, 6},
 { 83, 15, 6},
 { 84, 16, 6},
 { 85, 17, 6},
 { 86, 18, 6},
 { 87,  1, 7},
 { 88,  2, 7},
 { 89, −3, 7},
 { 90, −4, 7},
 { 91, −5, 7},
 { 92, −6, 7},
 { 93, −7, 7},
 { 94, −8, 7},
 { 95, −9, 7},
 { 96,−10, 7},
 { 97,−11, 7},
 { 98,−12, 7},
 { 99,−13, 7},
 {100,−14, 7},
 {101,−15, 7},
 {102,−16, 7},
 {103,−17, 7},
 {104,  4, 7},
 {105,  5, 7},
 {106,  6, 7},
 {107,  7, 7},
 {108,  8, 7},
 {109,  9, 7},
 {110, 10, 7},
 {111, 11, 7},
 {112, 12, 7},
 {113, 13, 7},
 {114, 14, 7},
 {115, 15, 7},
 {116, 16, 7},
 {117, 17, 7},
 {118, 18, 7}
 EXPORT Z_ELEMENTNAMES:={
 {  1,"H",  "hydrogen"},
 {  2,"He", "helium"},
 {  3,"Li", "lithium"},
 {  4,"Be", "beryllium"},
 {  5,"B",  "boron"},
 {  6,"C",  "carbon"},
 {  7,"N",  "nitrogen"},
 {  8,"O",  "oxygen"},
 {  9,"F",  "fluorine"},
 { 10,"Ne", "neon"},
 { 11,"Na", "sodium"},
 { 12,"Mg", "magnesium"},
 { 13,"Al", "aluminium"},
 { 14,"Si", "silicon"},
 { 15,"P",  "phosphorus"},
 { 16,"S",  "sulfur"},
 { 17,"Cl", "chlorine"},
 { 18,"Ar", "argon"},
 { 19,"K",  "potassium"},
 { 20,"Ca", "calcium"},
 { 21,"Sc", "scandium"},
 { 22,"Ti", "titanium"},
 { 23,"V",  "vanadium"},
 { 24,"Cr", "chromium"},
 { 25,"Mn", "manganese"},
 { 26,"Fe", "iron"},
 { 27,"Co", "cobalt"},
 { 28,"Ni", "nickel"},
 { 29,"Cu", "copper"},
 { 30,"Zn", "zinc"},
 { 31,"Ga", "gallium"},
 { 32,"Ge", "germanium"},
 { 33,"As", "arsenic"},
 { 34,"Se", "selenium"},
 { 35,"Br", "bromine"},
 { 36,"Kr", "krypton"},
 { 37,"Rb", "rubidium"},
 { 38,"Sr", "strontium"},
 { 39,"Y",  "yttrium"},
 { 40,"Zr", "zirconium"},
 { 41,"Nb", "niobium"},
 { 42,"Mo", "molybdenum"},
 { 43,"Tc", "technetium"},
 { 44,"Ru", "ruthenium"},
 { 45,"Rh", "rhodium"},
 { 46,"Pd", "palladium"},
 { 47,"Ag", "silver"},
 { 48,"Cd", "cadmium"},
 { 49,"In", "indium"},
 { 50,"Sn", "tin"},
 { 51,"Sb", "antimony"},
 { 52,"Te", "tellurium"},
 { 53,"I",  "iodine"},
 { 54,"Xe", "xenon"},
 { 55,"Cs", "caesium"},
 { 56,"Ba", "barium"},
 { 57,"La", "lanthanum"},
 { 58,"Ce", "cerium"},
 { 59,"Pr", "praseodymium"},
 { 60,"Nd", "neodymium"},
 { 61,"Pm", "promethium"},
 { 62,"Sm", "samarium"},
 { 63,"Eu", "europium"},
 { 64,"Gd", "gadolinium"},
 { 65,"Tb", "terbium"},
 { 66,"Dy", "dysprosium"},
 { 67,"Ho", "holmium"},
 { 68,"Er", "erbium"},
 { 69,"Tm", "thulium"},
 { 70,"Yb", "ytterbium"},
 { 71,"Lu", "lutetium"},
 { 72,"Hf", "hafnium"},
 { 73,"Ta", "tantalum"},
 { 74,"W",  "tungsten"},
 { 75,"Re", "rhenium"},
 { 76,"Os", "osmium"},
 { 77,"Ir", "iridium"},
 { 78,"Pt", "platinum"},
 { 79,"Au", "gold"},
 { 80,"Hg", "mercury"},
 { 81,"Ti", "thallium"},
 { 82,"Pb", "lead"},
 { 83,"Bi", "bismuth"},
 { 84,"Po", "polonium"},
 { 85,"At", "astatine"},
 { 86,"Rn", "radon"},
 { 87,"Fr", "francium"},
 { 88,"Ra", "radium"},
 { 89,"Ac", "actinium"},
 { 90,"Th", "thorium"},
 { 91,"Pa", "protactinium"},
 { 92,"U",  "uranium"},
 { 93,"Np", "neptunium"},
 { 94,"Pu", "plutonium"},
 { 95,"Am", "americium"},
 { 96,"Cm", "curium"},
 { 97,"Bk", "berkelium"},
 { 98,"Cf", "californium"},
 { 99,"Es", "einsteinium"},
 {100,"Fm", "fermium"},
 {101,"Md", "mendelevium"},
 {102,"No", "nobelium"},
 {103,"Lr", "lawrencium"},
 {104,"Rf", "rutherfordium"},
 {105,"Db", "dubnium"},
 {106,"Sg", "seaborgium"},
 {107,"Bh", "bohrium"},
 {108,"Hs", "hassium"},
 {109,"Mt", "meitnerium"},
 {110,"Ds", "darmstadtium"},
 {111,"Rg", "roentgenium"},
 {112,"Cn", "copernicium"},
 {113,"Uut","ununtrium"},
 {114,"Fl", "flerovium"},
 {115,"Uue","ununpentium"},
 {116,"Lv", "livermorium"},
 {117,"Uus","ununseptium"},
 {118,"Uuo","ununoctium"}
 LOCAL SHO_P:=0;
 LOCAL NELE:=SIZE(Z_ELEMENTS);
 LOCAL NGRPS:=18;//MAX(GROUPS)
 LOCAL NPRDS:= 7;//MAX(PERIODS)
 LOCAL NCOLS:=NGRPS+SHO_P;
 LOCAL NROWS:=NPRDS+2+1;//2 EXTRA ROWS
 LOCAL COLSZ:=IP(320/NCOLS);
 LOCAL ROWSZ:=IP(220/NROWS/2);//2 LINES PER ROW
 LOCAL FONTSZ:=1;//1..7 1..2
 LOCAL MNU:={"Symb","Enter","Num"};
 LOCAL EL,ELSYM,APRD,DPRD,LGRP,DGRP;
 LOCAL II,KK,ML;
 LOCAL BOXED;
 LOCAL LSYM,LELE;
 LOCAL SY:="";
 MSNK()
  LOCAL SNK:=MOUSE();
 DRW_ELE_BOX(LPOS,ONE,TWO)
  LOCAL LMG:=6;//
  LOCAL LW:=1;//LINEWIDTH:KEEP TEXT OFF BOXLINE
  LOCAL DGRP:=MAX(LPOS(1)-1,0);//TRY
  LOCAL DPRD:=LPOS(2);
  LOCAL XX:=IP(DGRP*COLSZ)+LMG;
  LOCAL YY:=IP(2*DPRD*ROWSZ);
  //OMIT U ON SMALL SCREENS)
  LOCAL THREE:=IFTE(DIM(TWO)==3  AND GROBW_P()<640,MID(TWO,2),TWO);
  IF BOXED THEN
   RECT_P(XX,YY,XX+COLSZ,YY+2*ROWSZ,#0,#EEEEEE);//BLACK EDGE GREY FILL
  //LINES 1 AND 2
  TEXTOUT_P(ONE,XX,YY+LW,FONTSZ);
  //RECT_P(0,2*8*ROWSZ,2*COLSZ+LMG,240,#0,#FF);
  TEXTOUT_P(THREE,XX+LW,IP((2*DPRD+1)*ROWSZ)+LW,FONTSZ);
  //AND CORNER BIGGER
  RECT_P(LMG,2*8*ROWSZ+LW,2*COLSZ+LMG-LW,GROBH_P()-20);
  TEXTOUT_P(ONE,LMG,2*8*ROWSZ+LW,3);
  TEXTOUT_P(TWO,LMG,(2*9)*ROWSZ+LW,3);
 POS_ELE_BOX(EL)
  LOCAL LGRP:=Z_ELEMENTS(EL,2);
  LOCAL DGRP:=ABS(LGRP);
  LOCAL APRD:=Z_ELEMENTS(EL,3);
  LOCAL DPRD:=IFTE(LGRP<0,APRD+2,APRD);//8 AND 9 ARE 2 BELOW W AND 7
  RETURN {DGRP,DPRD};
 DRWNAME(ST)
  TEXTOUT_P(ST,3*COLSZ,3*ROWSZ,7);
 EXPORT Z_PERIODIC_TABLE()
  RECT();
  BOXED:=0;
  DRW_ELE_BOX({0,0},"Software by StephenG1CMZ 2016. Any work?","");
  FOR II FROM 1 TO NGRPS DO
   DRW_ELE_BOX({II,0},"",II);
  FOR II FROM  1 TO  NPRDS DO
   DRW_ELE_BOX({0,II},"","P"+II);
  //THESE NAMES WONT BE SEEN WITHOUT ADDING A DELAY OR REPOSITIONING
  DRW_ELE_BOX({4,8},"lanthanoids","");
  DRW_ELE_BOX({4,9},"actinoids","");
  ML:=0;PRINT();
  //DIAGNOSTIC:LONGEST NAME FOR DISPLAY SIZING
  //FOR II FROM 1 TO NELE DO
  // ML:=MAX(ML,DIM(Z_ELEMENTNAMES(II,3)));
  //END;
  //PRINT("LONGESTNAME LENGTH:"+ML);
  //TEXTOUT_P(Z_ELEMENTNAMES(104,3),0,220,FONTSZ);//13CH
  DRW_ELE_BOX({3,7}," ⇊","");
  BOXED:=1;
  FOR  EL FROM 1 TO NELE DO
   //GETSYMBOL:LONGER NAMES LOSE THE "U" ON SMALL SCREEN
   ELSYM:=Z_ELEMENTNAMES(EL,2);
   //DRAW
   DRW_ELE_BOX(POS_ELE_BOX(EL),EL,ELSYM);
  DRAWMENU(MNU);
  REPEAT
   MSNK();
   KK:=WAIT(−1);
   IF TYPE(KK)==0 AND 0 THEN //DIAGNOSTIC
    MSGBOX({TYPE(KK)+","+KK});//WHAT KEY
   MSNK();
   CASE
    IF TYPE(KK)≠0 THEN
     MSGBOX("PLEASE USE KEYPAD");
     KK:=0;
    IF KK==1  THEN //SYMBOL
     LSYM:={};
      LSYM:=CONCAT(LSYM,EL+" "+Z_ELEMENTNAMES(EL,2));
     ML:=CHOOSE(EL,"Symb",LSYM);
    IF KK==11 THEN //NUM
     LSYM:={};
      LSYM:=CONCAT(LSYM,EL+" "+Z_ELEMENTNAMES(EL,2)+" "+Z_ELEMENTNAMES(EL,3))
     ML:=CHOOSE(EL,"Num",LSYM);
    DEFAULT
   IF KK==30 THEN //ENTER
    ML:=INPUT(SY,"Enter element name or Symb");
    IF ML THEN
      IF SY==Z_ELEMENTNAMES(EL,2) OR SY==Z_ELEMENTNAMES(EL,3) THEN
       RECT_P(0,0,320,220);
       DRW_ELE_BOX(POS_ELE_BOX(EL),EL,Z_ELEMENTNAMES(EL,2));
       DRWNAME(Z_ELEMENTNAMES(EL,3));
       WAIT;
   IF ML THEN
    TEXTOUT_P("More: use keys:",0,0,FONTSZ);
    TEXTOUT_P(MNU,320/4,0);
    //BOXED:=0;
    //TEXTOUT_P(Z_ELEMENTNAMES(EL,3),3*COLSZ,3*ROWSZ,7);
    //BOXED:=1;
   //ELSE
  UNTIL KK==4;//ESC
  //PRINT();
  //PRINT("BYE");
 FREEZE;
A guide to the user interface:
The Menu presents 3 options...but these names are just there to act as a Help, to remind you of the available keypresses.
If you tap them you will see "Please use keypad"...
If you tap the screen you will see " please use keypad" (there is no touch interface to select an element).
You will probably need to press On and re-run the program.
Instead, tap the relevant key on the keypad:
Symb: gives a list of symbols (Eg Au)
Num: gives a list of atomic numbers (eg 12)
Enter: let's you search for either an element or its symbol.
Note that the search is case-sensitive
: symbols begin with an Upper case.
: elements are entirely lower case.
: exact matches only
So you can search for "gold" or "Au" but not "go"
Update: Remember - use the keypad, not the Drawmenu.
After you see the "use the keypad" message, the program does not always recover.
Restart the program.
There is much room for improvement...
It has been reported by Salvomic that the line
"ML:=INPUT(SY," Enter...
does not appear to be working in FW 10077...
Thanks for that, Salvo.
So the program's Num and Symb options are available, but not the Enter option.
I only have the Android emulator here, so cannot yet confirm or look for a workaround myself.
Update: Salvo has confirmed this is new problem in 10077 and previously worked in 8151.
Version 2 uses the new Input syntax and works on FW8151 FW10077 and Android.
Also fixed a bug with my For loop going 1 beyond the actual number of elements, and some user interface improvements.
 LOCAL VERNUM:=2;
 LOCAL PT:="Periodic Table. ";
 LOCAL CRID:=PT+" StephenG1CMZ 2016. V"+VERNUM;
 LOCAL NL:=CHAR(10);
 LOCAL USEKEYPAD:=PT+NL+"USE KEYPAD, NOT MENU OR TOUCHSCREEN";
 //PERIODIC TABLE 02
 //FW8151 FW10077
 //CHANGELOG:
 //INPUT UPDATED FOR NEW FW
 //BUG IN FOR LOOP FIXED
 //CASE SYNTAX CORRECTED
 LOCAL HLPTXT:=CRID+NL+"THANKS SALVOMIC AND TYANN";
 //PERIODS
 //PERIOD/ROW: 1..7
 {  1,  1, 1},
 {  2, 18, 1},
 {  3,  1, 2},
 {  4,  2, 2},
 {  5, 13, 2},
 {  6, 14, 2},
 {  7, 15, 2},
 {  8, 16, 2},
 {  9, 17, 2},
 { 10, 18, 2},
 { 11,  1, 3},
 { 12,  2, 3},
 { 13, 13, 3},
 { 14, 14, 3},
 { 15, 15, 3},
 { 16, 16, 3},
 { 17, 17, 3},
 { 18, 18, 3},
 { 19,  1, 4},
 { 20,  2, 4},
 { 21,  3, 4},
 { 22,  4, 4},
 { 23,  5, 4},
 { 24,  6, 4},
 { 25,  7, 4},
 { 26,  8, 4},
 { 27,  9, 4},
 { 28, 10, 4},
 { 29, 11, 4},
 { 30, 12, 4},
 { 31, 13, 4},
 { 32, 14, 4},
 { 33, 15, 4},
 { 34, 16, 4},
 { 35, 17, 4},
 { 36, 18, 4},
 { 37,  1, 5},
 { 38,  2, 5},
 { 39,  3, 5},
 { 40,  4, 5},
 { 41,  5, 5},
 { 42,  6, 5},
 { 43,  7, 5},
 { 44,  8, 5},
 { 45,  9, 5},
 { 46, 10, 5},
 { 47, 11, 5},
 { 48, 12, 5},
 { 49, 13, 5},
 { 50, 14, 5},
 { 51, 15, 5},
 { 52, 16, 5},
 { 53, 17, 5},
 { 54, 18, 5},
 { 55,  1, 6},
 { 56,  2, 6},
 { 57, −3, 6},
 { 58, −4, 6},
 { 59, −5, 6},
 { 60, −6, 6},
 { 61, −7, 6},
 { 62, −8, 6},
 { 63, −9, 6},
 { 64,−10, 6},
 { 65,−11, 6},
 { 66,−12, 6},
 { 67,−13, 6},
 { 68,−14, 6},
 { 69,−15, 6},
 { 70,−16, 6},
 { 71,−17, 6},
 { 72,  4, 6},
 { 73,  5, 6},
 { 74,  6, 6},
 { 75,  7, 6},
 { 76,  8, 6},
 { 77,  9, 6},
 { 78, 10, 6},
 { 79, 11, 6},
 { 80, 12, 6},
 { 81, 13, 6},
 { 82, 14, 6},
 { 83, 15, 6},
 { 84, 16, 6},
 { 85, 17, 6},
 { 86, 18, 6},
 { 87,  1, 7},
 { 88,  2, 7},
 { 89, −3, 7},
 { 90, −4, 7},
 { 91, −5, 7},
 { 92, −6, 7},
 { 93, −7, 7},
 { 94, −8, 7},
 { 95, −9, 7},
 { 96,−10, 7},
 { 97,−11, 7},
 { 98,−12, 7},
 { 99,−13, 7},
 {100,−14, 7},
 {101,−15, 7},
 {102,−16, 7},
 {103,−17, 7},
 {104,  4, 7},
 {105,  5, 7},
 {106,  6, 7},
 {107,  7, 7},
 {108,  8, 7},
 {109,  9, 7},
 {110, 10, 7},
 {111, 11, 7},
 {112, 12, 7},
 {113, 13, 7},
 {114, 14, 7},
 {115, 15, 7},
 {116, 16, 7},
 {117, 17, 7},
 {118, 18, 7}
 {  5,"B",  "boron"},
 {  6,"C",  "carbon"},
 {  8,"O",  "oxygen"},
 { 10,"Ne", "neon"},
 { 26,"Fe", "iron"},
 { 30,"Zn", "zinc"},
 { 50,"Sn", "tin"},
 { 79,"Au", "gold"},
 { 82,"Pb", "lead"},
 LOCAL SHO_P:=0;
 LOCAL MNU:={"Symb","Enter","Num","Help"};
 LOCAL II,KK,ML;
 LOCAL BOXED;
 LOCAL LSYM,LELE;
 LOCAL SY:="";
 MSNK()
  LOCAL SNK:=MOUSE();
  LOCAL LMG:=6;//
  IF BOXED THEN
  //LINES 1 AND 2
  //AND CORNER BIGGER
 POS_ELE_BOX(EL)
  RETURN {DGRP,DPRD};
 DRWNAME(ST)
 HELP()
  MSGBOX(HLPTXT);
 EXPORT Z_PERIODIC_TABLE_02()
  RECT();
  BOXED:=0;
  DRW_ELE_BOX({0,0},CRID,"");
  ML:=0;PRINT();
  //END;
  BOXED:=1;
   //DRAW
  DRAWMENU(MNU);
  REPEAT
   MSNK();
   KK:=WAIT(−1);
   MSNK();
   CASE
    IF TYPE(KK)≠0 THEN
     MSGBOX(USEKEYPAD);
     KK:=0;
    END //IFCASE
     LSYM:={};
    END //IFCASE
     LSYM:={};
    END //IFCASE
     ML:=INPUT({{SY,[2]}},"Enter element name or Symb");//FW8151 AND FW10077
     // THANKS TYANN AND SALVOMIC. 2==STRINGTYPE
     IF ML THEN
      EL:=1;
      WHILE EL≤NELE AND  SY≠Z_ELEMENTNAMES(EL,2)  AND  SY≠Z_ELEMENTNAMES(EL,3) DO
        EL:=EL+1;
      END;//WHILE
       //RECT_P(0,0,320,220);
       //DRW_ELE_BOX(POS_ELE_BOX(EL),EL,Z_ELEMENTNAMES(EL,2));
       //DRWNAME(Z_ELEMENTNAMES(EL,3));
       //WAIT;
     //END;
     END;//IF
    END //IFCASE
   IF KK==3 THEN
    HELP();
   END //CASE
   DEFAULT
   END;//CASE
   IF ML THEN
    //BOXED:=0;
    //BOXED:=1;
   //ELSE
  UNTIL KK==4;//ESC
  //PRINT();
  //PRINT("BYE");
//NOTE:THE ALTERNATIVE OF SHOWING 3CHAR SYMBOLS BY
//BLITTING THE LOWERLEFT BOX IS MUCH LESS LEGIBLE THN
//OMITTING THE 1ST U
 FREEZE;
Version 2.1 has been rewritten to use CHOOSE lists rather than keypad menus...
This seems both easier and the program a little more reliable.
The element names are in English, francais and Polskie, but menus have yet to be internationalised.
 LOCAL VERNUM:=2.1;
 LOCAL PT:={"Periodic Table V","Okresowy Pierwiastków V","Tableau Périodique V"};
 LOCAL SL:=1;
 LOCAL LANGS:={"English","Polskie","Français"};
 //LOCAL CRID:=PT(SL)+VERNUM+"   2016 StephenG1CMZ ";
 LOCAL CRID,PNAME;
 LOCAL NL:=CHAR(10);
 //LOCAL USEKEYPAD:=PT+NL+"USE KEYPAD, NOT MENU OR TOUCHSCREEN";
 //PERIODIC TABLE 02
 //FW8151 FW10077
 LOCAL HLPTXT;
 LOCAL STATNUM:={"Atomic Number","Liczbie atomowe","Les numéro atomique"};
 LOCAL STPERIOD:=" P";
 LOCAL STGROUP:={"Group","Grupa","Groupe"};
 LOCAL STSYMBOL:={"Symbol","symbole","les symboles"};
 //PERIODS
 //PERIOD/ROW: 1..7
 {  1,  1, 1},
 {  2, 18, 1},
 {  3,  1, 2},
 {  4,  2, 2},
 {  5, 13, 2},
 {  6, 14, 2},
 {  7, 15, 2},
 {  8, 16, 2},
 {  9, 17, 2},
 { 10, 18, 2},
 { 11,  1, 3},
 { 12,  2, 3},
 { 13, 13, 3},
 { 14, 14, 3},
 { 15, 15, 3},
 { 16, 16, 3},
 { 17, 17, 3},
 { 18, 18, 3},
 { 19,  1, 4},
 { 20,  2, 4},
 { 21,  3, 4},
 { 22,  4, 4},
 { 23,  5, 4},
 { 24,  6, 4},
 { 25,  7, 4},
 { 26,  8, 4},
 { 27,  9, 4},
 { 28, 10, 4},
 { 29, 11, 4},
 { 30, 12, 4},
 { 31, 13, 4},
 { 32, 14, 4},
 { 33, 15, 4},
 { 34, 16, 4},
 { 35, 17, 4},
 { 36, 18, 4},
 { 37,  1, 5},
 { 38,  2, 5},
 { 39,  3, 5},
 { 40,  4, 5},
 { 41,  5, 5},
 { 42,  6, 5},
 { 43,  7, 5},
 { 44,  8, 5},
 { 45,  9, 5},
 { 46, 10, 5},
 { 47, 11, 5},
 { 48, 12, 5},
 { 49, 13, 5},
 { 50, 14, 5},
 { 51, 15, 5},
 { 52, 16, 5},
 { 53, 17, 5},
 { 54, 18, 5},
 { 55,  1, 6},
 { 56,  2, 6},
 { 57, −3, 6},
 { 58, −4, 6},
 { 59, −5, 6},
 { 60, −6, 6},
 { 61, −7, 6},
 { 62, −8, 6},
 { 63, −9, 6},
 { 64,−10, 6},
 { 65,−11, 6},
 { 66,−12, 6},
 { 67,−13, 6},
 { 68,−14, 6},
 { 69,−15, 6},
 { 70,−16, 6},
 { 71,−17, 6},
 { 72,  4, 6},
 { 73,  5, 6},
 { 74,  6, 6},
 { 75,  7, 6},
 { 76,  8, 6},
 { 77,  9, 6},
 { 78, 10, 6},
 { 79, 11, 6},
 { 80, 12, 6},
 { 81, 13, 6},
 { 82, 14, 6},
 { 83, 15, 6},
 { 84, 16, 6},
 { 85, 17, 6},
 { 86, 18, 6},
 { 87,  1, 7},
 { 88,  2, 7},
 { 89, −3, 7},
 { 90, −4, 7},
 { 91, −5, 7},
 { 92, −6, 7},
 { 93, −7, 7},
 { 94, −8, 7},
 { 95, −9, 7},
 { 96,−10, 7},
 { 97,−11, 7},
 { 98,−12, 7},
 { 99,−13, 7},
 {100,−14, 7},
 {101,−15, 7},
 {102,−16, 7},
 {103,−17, 7},
 {104,  4, 7},
 {105,  5, 7},
 {106,  6, 7},
 {107,  7, 7},
 {108,  8, 7},
 {109,  9, 7},
 {110, 10, 7},
 {111, 11, 7},
 {112, 12, 7},
 {113, 13, 7},
 {114, 14, 7},
 {115, 15, 7},
 {116, 16, 7},
 {117, 17, 7},
 {118, 18, 7},
 {119,  3, 3}
 {  1,"H",  "hydrogen","wodór","hydrogène"},
 {  2,"He", "helium","hel","hélium"},
 {  3,"Li", "lithium","lit","lithium"},
 {  4,"Be", "beryllium","beryl","béryllium"},
 {  5,"B",  "boron","bor","boron"},
 {  6,"C",  "carbon","węgiel","carbone"},
 {  7,"N",  "nitrogen","azot","azote"},
 {  8,"O",  "oxygen","tlen","oxygène"},
 {  9,"F",  "fluorine","fluor","fluor"},
 { 10,"Ne", "neon","neon","néon"},
 { 11,"Na", "sodium","sód","sodium"},
 { 12,"Mg", "magnesium","magnez","magnésium"},
 { 13,"Al", "aluminium","glin","aluminium"},
 { 14,"Si", "silicon","krzem","silicium"},
 { 15,"P",  "phosphorus","fosfor","phosphore"},
 { 16,"S",  "sulfur","siarka","soufre"},
 { 17,"Cl", "chlorine","chlore","chlore"},
 { 18,"Ar", "argon","argon","argon"},
 { 19,"K",  "potassium","potas","potassium"},
 { 20,"Ca", "calcium","wapń","calcium"},
 { 21,"Sc", "scandium","skand","scandium"},
 { 22,"Ti", "titanium","tytan","titane"},
 { 23,"V",  "vanadium","wanad","vanadium"},
 { 24,"Cr", "chromium","chrom","chrome"},
 { 25,"Mn", "manganese","mangan","manganèse"},
 { 26,"Fe", "iron","zelazo","fer"},
 { 27,"Co", "cobalt","kobalt","cobalt"},
 { 28,"Ni", "nickel","nikiel","nickel"},
 { 29,"Cu", "copper","miedź","cuivre"},
 { 30,"Zn", "zinc","cynk","zinc"},
 { 31,"Ga", "gallium","gal","gallium"},
 { 32,"Ge", "germanium","german","germanium"},
 { 33,"As", "arsenic","arsen","arsenic"},
 { 34,"Se", "selenium","selen","sélénium"},
 { 35,"Br", "bromine","brom","brome"},
 { 36,"Kr", "krypton","krypton","krypton"},
 { 37,"Rb", "rubidium","rubid","rubidium"},
 { 38,"Sr", "strontium","stront","strontium"},
 { 39,"Y",  "yttrium","itr","yttrium"},
 { 40,"Zr", "zirconium","cyrkon","zirconium"},
 { 41,"Nb", "niobium","niob","niobium"},
 { 42,"Mo", "molybdenum","molibden","molybd=ne"},
 { 43,"Tc", "technetium","technet","technétium"},
 { 44,"Ru", "ruthenium","ruten","ruthénium"},
 { 45,"Rh", "rhodium","rod","rhodium"},
 { 46,"Pd", "palladium","pallad","palladium"},
 { 47,"Ag", "silver","srebro","argent"},
 { 48,"Cd", "cadmium","kadm","cadmium"},
 { 49,"In", "indium","ind","indium"},
 { 50,"Sn", "tin","cyna","étain"},
 { 51,"Sb", "antimony","antymon","antimoine"},
 { 52,"Te", "tellurium","tellur","tellure"},
 { 53,"I",  "iodine","jod","iode"},
 { 54,"Xe", "xenon","ksenon","xénon"},
 { 55,"Cs", "caesium","cez","césium"},
 { 56,"Ba", "barium","bar","baryum"},
 { 57,"La", "lanthanum","lantan","lanthane"},
 { 58,"Ce", "cerium","cer","cérium"},
 { 59,"Pr", "praseodymium","prazeodym","praséodyne"},
 { 60,"Nd", "neodymium","neodym","néodyme"},
 { 61,"Pm", "promethium","promet","prométhium"},
 { 62,"Sm", "samarium","samar","samarium"},
 { 63,"Eu", "europium","europ","europium"},
 { 64,"Gd", "gadolinium","gadolin","gadolinium"},
 { 65,"Tb", "terbium","terb","terbium"},
 { 66,"Dy", "dysprosium","dyspoz","dysprosium"},
 { 67,"Ho", "holmium","holm","holmium"},
 { 68,"Er", "erbium","erb","erbium"},
 { 69,"Tm", "thulium","tul","thulium"},
 { 70,"Yb", "ytterbium","iterb","ytterbium"},
 { 71,"Lu", "lutetium","lutet","lutécium"},
 { 72,"Hf", "hafnium","hafn","hafnium"},
 { 73,"Ta", "tantalum","tantal","tantale"},
 { 74,"W",  "tungsten","wolfram","tungstène"},
 { 75,"Re", "rhenium","ren","rhénium"},
 { 76,"Os", "osmium","osm","osmium"},
 { 77,"Ir", "iridium","iryd","iridium"},
 { 78,"Pt", "platinum","platyna","platine"},
 { 79,"Au", "gold","zloto","or"},
 { 80,"Hg", "mercury","rtęć","mercure"},
 { 81,"Ti", "thallium","tal","thallium"},
 { 82,"Pb", "lead","ołów","plomb"},
 { 83,"Bi", "bismuth","bizmut","bismuth"},
 { 84,"Po", "polonium","polon","polonium"},
 { 85,"At", "astatine","astat","astate"},
 { 86,"Rn", "radon","radon","radon"},
 { 87,"Fr", "francium","frans","francium"},
 { 88,"Ra", "radium","rad","radium"},
 { 89,"Ac", "actinium","aktyn","actinium"},
 { 90,"Th", "thorium","tor","thorium"},
 { 91,"Pa", "protactinium","proaktyn","protactinium"},
 { 92,"U",  "uranium","uran","uranium"},
 { 93,"Np", "neptunium","neptun","neptunium"},
 { 94,"Pu", "plutonium","pluton","plutonium"},
 { 95,"Am", "americium","ameryk","américum"},
 { 96,"Cm", "curium","kiur","curium"},
 { 97,"Bk", "berkelium","bekerel","berkélium"},
 { 98,"Cf", "californium","kaliforn","californium"},
 { 99,"Es", "einsteinium","einstein","einsteinium"},
 {100,"Fm", "fermium","ferm","fermium"},
 {101,"Md", "mendelevium","mendelew","mendélévium"},
 {102,"No", "nobelium","nobel","nobelium"},
 {103,"Lr", "lawrencium","lorens","lawrencium"},
 {104,"Rf", "rutherfordium","rutherford","rutherforium"},
 {105,"Db", "dubnium","dubn","dubnium"},
 {106,"Sg", "seaborgium","seaborg","seaborgium"},
 {107,"Bh", "bohrium","bohr","bohrium"},
 {108,"Hs", "hassium","has","hassium"},
 {109,"Mt", "meitnerium","meitner","meitnérium"},
 {110,"Ds", "darmstadtium","darmsztadt","darmstadtium"},
 {111,"Rg", "roentgenium","roentgen","roentgenium"},
 {112,"Cn", "copernicium","kopernik","copernicium"},
 {113,"Uut","ununtrium","ununtrium","ununtrium"},
 {114,"Fl", "flerovium","flerovium","flerovium"},
 {115,"Uue","ununpentium","ununpentium","ununpentium"},
 {116,"Lv", "livermorium","livermorium","livermorium"},
 {117,"Uus","ununseptium","ununseptium","ununseptium"},
 {118,"Uuo","ununoctium","ununoctium","ununoctium"},
 {119,"**", "NOT FOUND","nie znaleziono","PAS TROUVÉ"}
 LOCAL OFFSETL:=2;
 LOCAL SHO_P:=0;
 LOCAL NELE:=SIZE(Z_ELEMENTS)-1;
 LOCAL MNUTXT,MNUACT;
 LOCAL II,KK,ML,LOC;
 LOCAL BOXED;
 LOCAL LSYM,LELE;
 LOCAL SY:="";
 LOCAL CHS;
 MSNK()
  LOCAL SNK:=MOUSE();
 END;//NOT IN USE
  LOCAL LMG:=6;//
  IF BOXED THEN
  //LINES 1 AND 2
  //AND CORNER BIGGER
  TEXTOUT_P(TWO,LMG,(2*9)*ROWSZ+LW,3);///THIS
 POS_ELE_BOX(EL)
  RETURN {DGRP,DPRD};
 DRWNAME(ST)
  TEXTOUT_P(ST,2*COLSZ,2*ROWSZ,7);
 DrawPeriodicTable()
  RECT();
  BOXED:=0;
  TEXTOUT_P(PNAME+CRID,5,2,FONTSZ);//DRW_ELE_BOX({0,0},CRID,"");
  ML:=0;PRINT();
  BOXED:=1;
   //DRAW
 DRAW_AN_ELE()
   //IF ML THEN
   //IF ML THEN
    //TEXTOUT_P("More: use keys:",0,0,FONTSZ);
    //TEXTOUT_P(MNU,320/4,0);
   IF ML THEN
    //BOXED:=0;
    //BOXED:=1;
    LOC:="";
    IF EL≤NELE THEN //IF FOUND
     LOC:=STPERIOD+Z_ELEMENTS(EL,3);
     LOC:=IFTE(Z_ELEMENTS(EL,2)>0,STGROUP(SL)+Z_ELEMENTS(EL,2)+","+LOC,LOC);
     LOC:="("+LOC+")";
    DRWNAME(Z_ELEMENTNAMES(EL,OFFSETL+SL)+LOC);
   ELSE
    DRWNAME(Z_ELEMENTNAMES(NELE+1,OFFSETL+SL));
 ENTER_ELE_SYM()
     ML:=INPUT({{SY,[2]}},"Enter element name or Symbol");//FW8151 AND FW10077
     IF ML THEN
      EL:=1;
      WHILE EL≤NELE AND  SY≠Z_ELEMENTNAMES(EL,2)  AND  SY≠Z_ELEMENTNAMES(EL,OFFSETL+SL) DO
        EL:=EL+1;
      END;//WHILE
       //WAIT;
     //END;
      DRAW_AN_ELE();
     END;//IF
 ListSymbols()
   LSYM:={};
     EL:=1;
     ML:=CHOOSE(EL,STSYMBOL(SL),LSYM);
     DRAW_AN_ELE();
 ListAtomicNumbers()
   LSYM:={};
      LSYM:=CONCAT(LSYM,EL+" "+Z_ELEMENTNAMES(EL,2)+" "+Z_ELEMENTNAMES(EL,OFFSETL+SL));
     EL:=1;
     ML:=CHOOSE(EL,STATNUM(SL),LSYM);
     DRAW_AN_ELE();
 LITTLE()
  //PRINT();
  ML:=0;
   ML:=MAX(ML,DIM(Z_ELEMENTNAMES(II,2+SL)));
  MSGBOX("LONGEST NAME LENGTH:"+ML);
   IF ML==SIZE(Z_ELEMENTNAMES(II,2+SL)) THEN
    //PRINT(Z_ELEMENTNAMES(II,2+SL));
    EL:=II;
    DRAW_AN_ELE();
  WAIT;
 TITLES()
  PNAME:=PT(SL)+VERNUM;
  CRID:="   2016 StephenG1CMZ";
  HLPTXT:=PNAME+NL+CRID+NL+"THANKS SALVOMIC AND TYANN";
 Lang()
  ML:=CHOOSE(SL,STRING(LANGS),LANGS);
  IF ML THEN
   MSGBOX(LANGS(SL));
 INTRO()
  DrawPeriodicTable();
  //TEXTOUT_P("ANY",0,320-20,2);
  WAIT;
 CHOOSER()
  LOCAL TTL;
  LOCAL MNU:={"HELP()","DrawPeriodicTable()","ENTER_ELE_SYM()","ListAtomicNumbers()","ListSymbols()","LITTLE()","Lang()"};
  LOCAL MNUACT:=MNU;
  LOCAL MNUTXT:=MNU;
  REPEAT
   TITLES();
   TTL:=PNAME;
   ML:=CHOOSE(CHS,TTL,MNUTXT);
   IF ML THEN
     EXPR(MNUACT(CHS));
     WAIT;
  UNTIL ML==0;
 HELP()
  MSGBOX(HLPTXT);
 EXPORT Z_PERIODIC_TABLE02_1()
  TITLES();
  INTRO();
  CHOOSER();
  //DRAWMENU(MNU);
  //PRINT("BYE");
  FREEZE;
// TBD
// LIST BY ELEMENT NAME
// LIST SEARCH IN ANY LANG NOT 1BY1
// PARTIAL MATCHES
