(01-16-2016 12:40 PM)Gerson W. Barbosa Wrote: [ -> ]This appeared to work, but some cancellation occurs at a critical region:
What's a few ULPs among friends anyway? :-)
Or a few hundred, or a few thousand... ;-)
(01-16-2016 12:40 PM)Gerson W. Barbosa Wrote: [ -> ](...)
That should be expected by just looking at the identity I have used:
\[e^{x}-1=\frac{e^{x}-e^{-x}}{e^{-x}+1}\]
It works better after replacing e
x – e
–x with 2 sinh(x) – provided an
accurate sinh function is available. I tried this on the 34s and in 100.000 random samples there were no errors beyond ±7 ULP. About 75% of the results were within ±1 ULP.
Finally I did a test run with one million random values in [ln 0.9, ln 2] with the method I suggested, and the results are essentially the same as before:
seed = 47,11 n = 1000000
ULP #cases
-5 12 ─── 0,001%
-4 1092 ─┐
-3 674 ├─ 0,24%
-2 676 ─┘
-1 167703 ─┐
±0 659710 ├─ 99,5%
+1 167784 ─┘
+2 666 ─┐
+3 677 ├─ 0,23%
+4 992 ─┘
+5 14 ─── 0,001%
Again, there are two peaks at +4 and –4 ULP that also showed up in earlier tests. I wonder where these come from. Any idea?
As already mentioned, for arguments in [ln10, ln11[ or [ln100, ln101[ etc. the last digit is lost, which leads to an interesting error distribution. Here are some results for x in [ln10, ln11]:
ULP #cases
-5 4990 ─── 5%
-4 10025 ─┐
-3 9952 ├─ 30%
-2 9975 ─┘
-1 10002 ─┐
±0 10024 ├─ 30%
+1 10170 ─┘
+2 9888 ─┐
+3 9941 ├─ 30%
+4 10042 ─┘
+5 4991 ─── 5%
As expected, the errors are evenly distributed in this interval. Again, they do not exceed ±5 ULP.
Dieter
