01-08-2016, 08:26 AM
Whoooo HOoooo!
Made a backup of my plethora of aviation programs using PuTTY and dumping the files then copying to a text file. Reset the calculator and then restored the files confirming the serial transfer works.
Then I 'memory lost' the calculator with a reset! This so that I could create the famous Byte Grabber using Kieth Jarretts "41 Synthetic programming made easy".
Following the instructions I created the synthetic lines needed to create the famed "load bytes (LB)" program.
Late tonight so I am stopping at this point but will use the "LB" to create the Synthetic "make synthetic key assignments" program.
The calculator did freeze on a mistake by me, but reset at the back of the calculator fixed that! Started over and now have the "LB" program created.
So for those adventureous types out there here is the dump of the completed "LB" program. Just envoke PuTTY and hook up the DM41L, follow the instructions to load the dump into your calculator and you will have the "LB" program installed. Will save you time creating it!
Here is the dump for the LB program:
Soon I will post the "Synthetic Key Assignment" program so you can create synthetic key assignments!
I feel like a kid again! Byte Grabbers, Load Bytes and synthetic Key Assignment programs.
Cheers all
p.s. let me know if you are going or have used it.
DM41
04 01000000000000 00000000000000 00000000000000 00000000000000
08 4b010000000000 00000000444e45 11100000008000 00000000000000
0c 00000000006177 1a70016919c177 0000003c048008 00000000007070
bc 00000000000000 00000000000000 00000000000000 41414141410000
c0 f000000004aa35 f0040231f73f41 00000000000000 00000000000000
174 00000000000000 00000000000000 00000000000000 00c0230dc6002d
178 00000000917db2 ce7d907591f171 9673b600000000 00000000f27f83
17c b400b200060000 0000917d749773 ce7d7691f07100 9672b5007a0000
180 0000000000ce76 00000091769b72 7ece75f37f2a2a 11ac0ea81000ce
184 aa11a812ac0fa8 13a814aa12a813 00000000ce7eaa 00001b14400000
188 00000000000000 84ab16b6006f00 f27f3f7e917575 178305f1209b72
18c 404004111a1010 685f11401a114c 0aaa0ca80bce7e aa0aa809aa0ba8
190 08a806aa09a807 a906aa07a805aa 75ce7ea904a905 75f47f000002ce
194 9f087e89907c91 f67f2052454753 689c00a91d9b73 1df22b2b031743
198 87a9157e1c1110 ac32b300118383 2bc000f3004c42 027386841df22b
A: 027386841df22b B: 0000003c046177 C: 0000003c0480fd
M: 00011cd5ff73cb N: 000000000c1420 G: 00
Cheers all
