01-07-2016, 10:16 PM
165 steps.
* CSV, an Ostrowski-Traub based complex solver
* v1.5L (20160107) by M. César Rodríguez GGPL
* Usage:
* Input:
* XY: contains an initial root estimation. X is the real part, Y the
* imaginary one
* alpha: contains the name of the program to be solved. This program
* is called with the stack (an SSIZE8 one) filled with a complex
* estimation of the root. The program must return a complex
* number in XY (X real, Y imaginary)
* Output:
* XY: the root found or the value of the last estimation for the
* root. X real, Y imaginary
* ZT: the value of the program to be solved evaluated at the
* returned complex value in XY. Z real, T imaginary
* LI: the input XY value
* If the user interrupts the program ([<-] key), or the program to
* be solved evaluates to infinity or NaN, or the solver reaches
* its maximum iteration number (800 iterations), it ends with the
* message "No root Found"
* The user can interrupt the program pressing the [<-] key. If the
* user interrupts the program with [EXIT] or [R/S], the values in
* the stack, ABCD, L & I registers and flag D are not defined. Also,
* the size of the stack will be 8. The same will occur if the
* program to be solved throws an error (e.g. trying to access a non
* existent register)
* Register usage:
* ABCD are cleared (no matter if the user works in SSIZE4 or SSIZE8)
* Stack size is forced to 8 levels, but it is restored to the value
* prior to calling the solver upon program end
* Flag D is set (so function to be solved returns infinite or NaN
* instead of reporting errors). This flag is restored to the value
* Algorithm:
* The Ostrowski-Traub algorithm has 4th order convergence into
* single roots. Requires 3 function evaluations on each iteration.
* See, for example, [1]
* For each root estimate z_i, a new estimate is computed with:
* w_i = z_i - f(z_i)/f'(z_i) (this is a Newton iteration)
* where here the derivative f'(z_i) is estimated with:
* f'(z_i) ~ (f(z_i + e_i) - f(z_i))/e_i
* Thus, the expression used here to get the w_i estimate is:
* w_i = z_i + e_i/(1 - f(z_i + e_i)/f(z_i))
* Then, such estimate is refined with:
* z_{i+1} = w_i - f(w_i)(z_i - w_i)/(f(z_i) - 2f(w_i))
* which is implemented here as:
* z_{i+1} = w_i + (z_i - w_i)/(2 - f(z_i)/f(w_i))
* After each iteration, |z_{i+1} - z_i| is checked to be smaller
* than max(|z_i|/10^4, 10^-8). If so, a flag is set signaling that
* the algorithm is "converging". This flag remains set until
* program end
* After each iteration and if the algorithm is "converging",
* |z_{i+1} - z_i| is compared to |z_i - z_{i-1}|, being greater the
* algorithm is supposed to had converged and z_i (not z_{i+1}) is
* declared a root. This stopping algorithm is, basically, the Ward's
* criterion [2]
* The program will also exit with a root found (hopefully) if:
* - evaluating the program to be solved returns 0 + 0j
* - f(z_i + e_i) = f(z_i)
* - z_{i+1} = z_i
* The program will exit with error message "No root Found" if:
* - evaluating the program to be solved returns Infinite or NaN
* - the algorithm reaches 800 iterations (in DBLOFF mode and with
* single roots, the algorithm many times needs only 3 iterations
* to converge)
* - the user interrupts the program pressing [<-]
* When a root is found, it is "beautified" by:
* - changing numbers like 1.124999999973587 or 1.125000000032518
* to 1.125. The code for this is adapted from the PRS polynomial
* solver for the wp34s by Franz Huber
* - numbers with an imaginary (real) part much smaller than its
* real (imaginary) part, are converted to real (imaginary) ones
* zeroing the smaller part
* Then, the function to be solved is evaluated at this new,
* beautified, root and it the value of the function is closer
* (or equally close) to 0, then the beautified root is returned as
* the root
* When estimating the value of the derivative f'(z_i) with:
* (f(z_i + e_i) - f(z_i))/e_i, the increment e_i is:
* - if z_i is real, then
* e_i = |z_i - z_{i-1}|/10^3
* - otherwise
* e_i = |z_i - z_{i-1}|/10^3·exp(j·ai), with a_i a random
* angle between 0 and 2·pi
* Thus, if the function to be solved is real valued for real
* arguments and the initial root estimate is real, the program
* will only search for real roots
* When called from another program, this solver will behave like a
* test, executing next program step when a root is found, or
* skipping it when not found
* This solver does also work in DBLON mode
* References:
* [1] Wei-hong, B.I., Qing-biao, W.U., Hong-min R. "Convergence ball
* and error analysis of Ostrowski-Traub’s method." Appl. Math. J.
* Chinese Univ. 2010, 25(3): 374-378
* [2] Ward, R.C. "The QR algorithm and Hyman’s method on vector
* computers." Mathematics of Computation 01/1976; 30(133): 132-132
LBL'CSV' // Complex SolVer
LocR 16 // Local registers and flags:
// .00 mode
// .01 |d_i| (that's |z_i - z_{i-1}|)
// .02-03 z_i
// .04-05 e_i
// .06-07 f(z_i)
// .08-09 z_0
// .10 iteration counter
// .11 fname
// .12-13 w_i
// .14-15 arg, argument for program to
// solve, also beautified zi
// F.00 no convergence, or f evaluates
// to special, or user interrupt
// F.01 algorithm is converging
// F.02 backup of D flag
STOM .00 // STOM mode. Mode is restored at exit
SSIZE8
FS? D // backup flag D
SF .02
SF D // specials are not errors here
aSTO .11 // aSTO fname. Name of function to solve
cSTO .08 // cSTO z0. Initial guess
cSTO .02 // cSTO zi. Estimate
cABS // |z0|
x=? Y // |z0| = 0?
# 001
SDR 005 // |d0| = |z0| / 10^5, or 10^-5 if |z0| = 0
STO .01 // STO |di|
# 080
SDL 001 // 800, maximum iter #
STO .10 // STO counter
// first pass, Newton's estimate
CSV_mloop:: cRCL .02 // cRCL zi
GSB CSV_eval // eval function, check for special or root
JMP CSV_exit // if result is special or root, exit
cSTO .06 // cSTO f(zi)
// compute e_i to estimate derivative
RCL .03 // RCL Im(zi)
# 000
x=? Y // zi is real?
JMP CSV_noai // yes, e_i must also be real
ACOS // no. pi/2 (or 90º or 100 grad)
# 004
RAN#
* // ai, random angle between 0 and 2pi
CSV_noai:: RCL .01 // RCL |di|. ai or 0 in Y
SDR 003 // |di|/10^3
>REC
cSTO .04 // cSTO ei
// estimate derivative
cRCL+ .02 // RCL+ zi. zi + ei
GSB CSV_eval // f(zi + ei)
cRCL/ .06 // cRCL/ f(zi). f(zi + ei)/f(zi)
cCHS // -f(zi + ei)/f(zi)
INC X // 1 - f(zi + ei)/f(zi)
cx=0? // f(zi + ei) = f(zi)?
JMP CSV_exit // then exit (converged)
cRCL .04 // cRCL ei
cRCL/ Z // ei/(1 - f(zi + ei)/f(zi))
cRCL+ .02 // cRCL+ zi. zi + ei/(1 - f(zi + ei)/f(zi))
cSTO .12 // cSTO wi. New wi
// 2nd pass, Ostroswki's refine
GSB CSV_eval // f(wi)
cRCL .06 // cRCL f(zi)
cRCL/ Z // f(zi)/f(wi)
DEC X
DEC X // f(zi)/f(wi) - 2
cRCL .12 // cRCL wi
cRCL- .02 // cRCL- zi. wi - zi
cRCL/ Z // (wi - zi)/(f(zi)/f(wi) - 2)
cRCL+ .12 // wi + (zi - wi)/(2 - f(zi)/f(wi)) (zi+1)
// compute new |di| for next derivative estimation and check
// convergence
cFILL // stack filled with zi+1
cRCL- .02 // cRCL- zi. zi+1 - zi
cABS // |zi+1 - zi| (|d_{i+1}|)
x=0? // zi+1 = zi?
cRCL .02 // cRCL zi
cABS // |zi|
SDR 004 // |zi|/10^4
# 001
SDR 008 // 10^-8
MAX // max(|zi|/10^4, 10^-8)
x>? Z // |zi+1 - zi| < max(|zi|/10^4, 10^-8)?
SF .01 // yes, algorithm is converging
x<> Z // |zi+1 - zi|
FC? .01 // converging?
JMP CSV_updt // no, skip convergence test
x>? .01 // converged?
CSV_updt:: STO .01 // STO |di|
cRCL A // cRCL zi+1
cSTO .02 // cSTO zi
// check user interrupt
KEY? X // any key?
JMP CSV_nok // no, continue
# 035 // keycode for <-
x=? Y // key is [<-]?
JMP CSV_flag // yes, mark as no root found and exit
// check iteration limit #
CSV_nok:: DSZ .10 // DSZ counter
JMP CSV_mloop // goto main loop
CSV_flag:: SF .00 // flag no root found
// root found (F.00 reset) or not (F.00 set)
CSV_exit:: FS? .00 // no root?
JMP CSV_nopp // no root, skip post process
// beautify x.xx...999999xxxx and x.xx...000000xxxx roots
cRCL .02 // cRCL zi
cSTO .14 // save zi in arg
RSD 11 // Re(zi) rounded to 11 digits
x<> .14
RSD 09 // Re(zi) rounded to 9 digits
x!=? .14 // rounded to 11 digits != rounded to 9?
RCL L // yes, keep Re(zi) untouched
STO .14 // otherwise, use new, beautified, value
RCL .15 // RCL Im(zi)
RSD 11 // Im(zi) rounded to 11 digits
x<> .15
RSD 09 // Im(zi) rounded to 9 digits
x!=? .15 // rounded to 11 digits != rounded to 9?
RCL L // yes, keep Im(zi) untouched
STO .15 // otherwise, use new, beautified, value
// beautify almost real/imaginary roots
cRCL .14 // cRCL zi (partially beautified)
EXPT
x<> Y
EXPT
- // orders of magnitude between Re and Im
# 011
x<? Y // almost real?
JMP CSV_real // yes, convert to real
CHS
x<? Y // almost imaginary?
JMP CSV_chkb // no, keep intact. Check new zi
# 000 // here if almost imaginary, clear Re
STO .14
JMP CSV_chkb // zi beautified, check it
CSV_real:: # 000 // here if almost real, clear Im
STO .15
// check if beautified zi is a better root
CSV_chkb:: cRCL .14 // cRCL zi (beautified)
cx=? .02 // beautified zi = zi?
JMP CSV_nopp // yes, no need to check, skip
GSB CSV_eval // compute f(zi) for beautified zi
JMP CSV_nopp // beautified zi lets f(zi) special, skip...
// or is a true root, also skip
cENTER
cABS // abs(f(zi)) with zi beautified
cRCL .06
cABS // abs(f(zi)) with zi non-beautified
x<? Z // the beautified zi is no better?
JMP CSV_nopp // yes, keep root intact
cRCL A // yes, root is the new zi. cRCL f(zi)
cSTO .02 // cSTO zi (beautified)
// build return stack
CSV_nopp:: cRCL .08 // cRCL z0
cSTO L // input argument copied to LI
CLSTK // tidy stack (A-D lost)
FC? .02 // restore user's D flag
CF D
RCLM .00 // RCLM mode, restore user mode
cRCL .02 // cRCL zi. Now f(zi), zi on stack
cVIEW .02 // cVIEW zi, show root in complex form
FC? .00 // root found?
RTN // yes, that's enough
MSG 20 // no, report it
RTN+1 // to behave like a test
// wrapper for program to be solved. Saves the argument,
// fills the stack and checks return value. Behaves like
// a test. The test returns false if the return value is
// neither special nor zero. Returns true otherwise,
// setting flag .00 if return value is special or storing
// 0+0j in f(zi) and the argument in zi if the argument is
// a root
CSV_eval:: cSTO .14 // cSTO arg. Save argument
cFILL
aXEQ .11 // evaluate f
SF .00
SPEC? // Re(f) is special?
RTN // yes, test returns true & F.00 set
x<> Y
SPEC? // Im(f) is special?
x<> Y
CF .00
cx!=0? // argument is not a root?
RTN+1 // not a root, test returns false
cSTO .06 // cSTO f(zi). Is a root, save 0+0j in f(zi)
cRCL .14 // cRCL arg
cSTO .02 // cSTO zi. Store the root in zi
RTN // test returns true & F.00 reset
END
