For my Calc III class lecture I have the following infinite series for the students:
-9 + 27/4 - 81/16 + 243/64 - 729/256 ...
This is a geometric series with the first term a = -9 and the common ratio r = -3/4.
The infinite series value is S = a/(1-r) = -9/(1-(-3/4)) = -36/7
When entered into the Prime, regardless how I enter it I get the result of +/- inf, not -36/7.
I'm entering it as the summation as k goes from 1 to infinity, of (-9)(-3/4)^(k-1). I've tried it various ways and can never get the result -36/7.
Any ideas.
C
Did you try sum() in CAS mode?
The CAS currently interprets (-9)(-3/4)^(k-1) as (-9) being given (-3/4)^(k-1) as an argument, not as implicit multiplication of (-9) and (-3/4)^(k-1).
Try using (-9)*(-3/4)^(k-1).
So far none of the suggestions have worked, neither with the summation sign, nor the sum command. I think the problem lies with it being an alternating series and the parsing of the parentheses. The prime seems to be ignoring the parentheses around the base (-0.75)^k. Non alternating series and partial sums seem to work, but not an infinite alternating series. Still not sure what is actually happening though. Seems a little random on what is evaluated and what is no.
(01-07-2016 11:32 PM)chazzs Wrote: [ -> ]So far none of the suggestions have worked, neither with the summation sign, nor the sum command. I think the problem lies with it being an alternating series and the parsing of the parentheses. The prime seems to be ignoring the parentheses around the base (-0.75)^k. Non alternating series and partial sums seem to work, but not an infinite alternating series. Still not sure what is actually happening though. Seems a little random on what is evaluated and what is no.
If you enter Σ(-9*(-3/4)^(k-1),k,1,∞) in (algebraic notation in) CAS you should get the desired result. You can also use textbook and the template and get the same result. The multiplication must be explicit between -9 and (-3/4), and as seems to be the case with most CAS functions the Angle Measure setting must be Radians.
Hope this helps
Cheers, Terje
Have you been able to resolve this? Indeed, you must put * between things in the CAS to avoid problems as stated.
