12-30-2015, 12:31 AM
So I have fat fingers and the way I press buttons isn't very "normal" is the nice way to put it. That being said along the same idea of Having larger text for better visibility, would it be possible to add an option to make the soft menu keys "taller", the width is fine. The issue I have is the height. I would sacrifice screen space for key height up to the max height of the physical key height. Why the physical key height? Well as it turns out my brain is Already used to pressing the keys and having that kind of real estate In the interface. And I will be frank I dread having to use the soft menu sometimes because the initial interface is the bottle neck. After I have pressed Var> Home (it is this home option and others like it that make the feel, the flow, and the efficiently not what it should be) once I have pressed the Home soft key button in this case I can use the arrow keys and I prefer the numeric shortcuts to navigate.
