I have a DM-15L board -- the one with the bad buttons -- and decided to measure the current draw on it. It's quite low except when a button is held down, then it's 10mA. But even worse is that it's still 10mA when the calculator is turned off! So if you have a button that is being pressed down when the calculator is in a bag, pocket, whatever, you'll deplete the CR2032 in short order.
Can someone confirm if the newer boards have the same high current draw when a key is held down.
Yep. I had a replacement board and it shows 11mA when any key is pressed, whether on or off.
Thanks for the heads-up - I'll be careful to make sure it isn't squashed when in my bag.
(12-28-2015 06:35 PM)Katie Wasserman Wrote: [ -> ]I have a DM-15L board -- the one with the bad buttons -- and decided to measure the current draw on it. It's quite low except when a button is held down, then it's 10mA. But even worse is that it's still 10mA when the calculator is turned off! So if you have a button that is being pressed down when the calculator is in a bag, pocket, whatever, you'll deplete the CR2032 in short order.
Hm, I wonder if there is a software fix for that. I would assume there are no external pull up/down resistors on the board. So it shouldn't be too difficiult to change the configuration of the internal ones in sleep mode. But maybe the "ON" key isn't treated differently and is an issue?
I wonder if the ID card-sized calculator variants have the same problem.
Greetings,
Matthias
Just checked my DM41 unit. There is a small increase when keys are pressed in off state, but only 50uA. A minor problem compared to described behavior of L variants (cannot check for myself due to calculator hobby budget screams no no no at the moment) as additional current draw is so low and foil keys are hard to press even incidentally.
(12-30-2015 06:37 PM)matthiaspaul Wrote: [ -> ]I wonder if the ID card-sized calculator variants have the same problem.
Greetings,
Matthias
I asked Mr. Steinmann on this issue. He told me that it was solved in the latest version.
@Katie Wasserman / @BruceH: Did you use the latest firmware (V16) on the machines?
Bernd
(02-04-2016 09:10 PM)Bernd Grubert Wrote: [ -> ]I asked Mr. Steinmann on this issue. He told me that it was solved in the latest version.
Bernd
Bernd,
Could you ask Mr. Steinmann if he is aware of any key scanning issue in the firmware? Refer to the following thread:
http://www.hpmuseum.org/forum/thread-5621.html
Bernd
Yes, my tests were done with firmware V16 installed, I'm perplexed.
(02-05-2016 07:42 AM)Katie Wasserman Wrote: [ -> ]Yes, my tests were done with firmware V16 installed, I'm perplexed.
I will inform Mr. Steinmann about this.
Please see this
thread for solution of the problem.
