12-14-2015, 06:55 PM
Has somebody the assembler sources of the 71B KEYBOARD LEX file which is part of the FORTH/Assembler ROM or available as separate LEX file.
TIA,
Christoph
TIA,
Christoph
(12-14-2015 06:55 PM)Christoph Giesselink Wrote: [ -> ]Has somebody the assembler sources of the 71B KEYBOARD LEX file which is part of the FORTH/Assembler ROM or available as separate LEX file.
TIA,
Christoph
(12-14-2015 07:42 PM)rprosperi Wrote: [ -> ](12-14-2015 06:55 PM)Christoph Giesselink Wrote: [ -> ]Has somebody the assembler sources of the 71B KEYBOARD LEX file which is part of the FORTH/Assembler ROM or available as separate LEX file.You have mail...
(12-15-2015 04:35 PM)rprosperi Wrote: [ -> ]Sorry, I was not clear. I do NOT have source for this LEX file. I may have misunderstood Christoph's request, I thought he was requesting the source and/or a copy of the LEX file, so I sent him the LEX file (binary).
Note that the KEYBOARD LEX file in the FORTH/Assembler ROM is Rev B, however the HPILLINK DOS link utility installs a Rev C version of this LEX file when you initially connect the 71B; it appears this file is somehow embedded in the DOS .exe file as I don't recall seeing it in the installed set of files (I need to double check on my HP-110+).
I can share both (Rev B and Rev C) LEX files if wanted.
Sorry if I raised any hopes.
(01-02-2016 06:43 AM)Erwin Wrote: [ -> ]Hallo!
I own the FORTH-Module but I was not able to run an extern keyboard. I have a keyboard with a serial connector from a mainframe but I can't get a connection via the Keyboard command. Is it possible that the keyboard is to exotic? It is hardly possible to get a PC keyboard with serial connector.
Are there any hints about this problem?
best regards Erwin
(01-02-2016 04:36 PM)rprosperi Wrote: [ -> ](01-02-2016 06:43 AM)Erwin Wrote: [ -> ]Hallo!
best regards Erwin
Although the keyword is KEYBOARD IS, it really is referring to a terminal, not just a hardware keyboard. (The keyword DISPLAY IS comes in the 71B itself)The terminal responds to certain character sequences (which can be tailored) and sends replies back onto the IL loop. Which is not to say some keyboard could not be connected, but it would have to "act like" a terminal to be used this way. HTH.
(01-02-2016 07:07 PM)Erwin Wrote: [ -> ]Thank you - this means its not a real possibility today.
(01-02-2016 08:33 PM)Dave Frederickson Wrote: [ -> ](01-02-2016 07:07 PM)Erwin Wrote: [ -> ]Thank you - this means its not a real possibility today.
Not true. By "terminal", Bob is also referring to terminal programs like HyperTerm or PuTTY running on a PC or J-F's Term71 for the Portable PLUS. The preferred method would be to connect the 71 to a PC via a PIL-Box or HP-IL to RS-232 converter.
Dave
(01-02-2016 09:21 PM)Erwin Wrote: [ -> ]I understand that means not via PC-HP-IL-Card? So I have to study the possibility with the HP-IL-RS232 Interface ... exist there any description for such a solution?
(01-02-2016 09:28 PM)Dave Frederickson Wrote: [ -> ](01-02-2016 09:21 PM)Erwin Wrote: [ -> ]I understand that means not via PC-HP-IL-Card? So I have to study the possibility with the HP-IL-RS232 Interface ... exist there any description for such a solution?
No, the HP-IL board for the PC expressly supports a remote keyboard and monitor using HPILLink. Also, there are numerous terminal programs in the archives for the HP-IL to RS-232 converter.
Dave
(01-02-2016 09:36 PM)Erwin Wrote: [ -> ]Thanks Dave - so I look for such programs (in the hpmuseums archive?) and hope to find how to handle this
(01-02-2016 11:11 PM)Dave Frederickson Wrote: [ -> ](01-02-2016 09:36 PM)Erwin Wrote: [ -> ]Thanks Dave - so I look for such programs (in the hpmuseums archive?) and hope to find how to handle this
See HP-71 KEYBOARD IS WHAT?, CHHU Chronicle, V1N3, p.4.
