12-10-2015, 10:44 AM
Inspired by Paul Dale's HP35s bug list, especially by the bug 14, I have written a program which looks for other data giving wrong results in simple calculations.
In short, the program generates randomly 3 input data, stores them in A,B,C variables then calls twice a function with the same input data and displays both (different) results in x and y registers.
When both results are equal they are omitted, when are different program also stores them for later display and manual checking if necesssary.
Attached there is a table with examples of errors found. Some functions take only 1 or 2 input data from 3 values generated.
For 100 tries for every function usually a few sets (5 to 20 - very high percentage) of randomly generated input data giving wrong results were found.
Definitely the problem is with the "-" sign at the beginning of the functions.
Another conclusion was that adding ("+") operation (and probably other operations) performed just before calling the test function makes the function give correct results (so in one place in the code I had to use ISG instead of "+" to see the errors).
To those who wonder why I bother about it.
Unfortunately I bought this calculator (second hand, but it is still on HP menu!) and then looking for manuals I found this forum and Paul's bug list.
So before throwing the 35s away I tried to write a program at least, just for fun.
The code of the program is attached for those who would like to play with it
Wojtek Waszak
PS.
As I spotted an error in attachment with outcomes of the program (one of the input data to function #4 = -(A-B)xC was missing) I enclose here the corrected attachment:
And the code of the program:
PS2
Below there is a short description of the usage of the program. Have fun!
1.
Set the input parameter for the routine C in register x, for example:
0 = max 100 iterations, test function #0, stop after 1st error found
150.99 = max 150 iterations, test function #9, find max 9 errors
2.
Run the routine C (press XEQ C)
3.
Usually after a few seconds to about 1 minute message ERRORS FOUND is displayed.
3.
Then you can press R/S to see:
in y register - the number of iterations made
in x register - the number of errors found
4.
Then you can press R/S to repeat the same process (routine C) with the same input data as before, or
5.
You can run the procedure D (press XEQ D) to see outcomes of the selected test function in x and y registers (and input values in A,B,C variables, and function number in V). When you press R/S the next outcome is displayed.
6.
When the outcomes are displayed by routine D you can also run routine B (press XEQ B) to repeat the calculations with the same input data in A,B,C variables and compare the results (saved in x and y registers) with the ones calculated previously by routine C (in z and t registers). The values in x and y should be the same as values in z and t
Wojtek Waszak
PS.
# | FUNCTION | A, B, C | results | remarks
0 -(A) 27.7231744712 -27.7231744712 correct
27.723174471 bad sign, last digit missing
812.083201122 -812.083201122 correct
812.08320112 bad sign, last digit missing
1 -(A+1) 27.7231744712 -28.7231744712 correct
27.723174471 the same as from -(A) function
812.083201122 -813.083201122 correct
812.08320112 the same as from -(A) function
2 -(Ax2) 469.905386026 -939.810772052 correct
1879.6215441 wrong, = -2 x correct
3 -(A+B) 311.009796507 -1071.47176962 correct
760.461973111 311.009796489 wrong, almost same as data in A
4 -(A-B)xC 77.403198273 63876.0881102 correct
365.311711707 -14090656.4407 wrong
221.862449805
5 -(A+B)/C 653.642816498 -375694.722782 correct
334.936336329 142649873.314 wrong
380.035044951
6 -Ax(B-C)/C 139.48921215 60.3314372662 correct
491.736252651 129.777293812 wrong
866.521356475
7 -(A+B)/(B-C) 72.6138248053 -1.59167078012 correct
677.915633404 3.252000122 wrong
206.380019642
8 -A+BxC 465.408630753 476927.326742 correct
763.771068422 364262828.495 wrong
625.04689574
9 -Ax(B-C)/(B+C) 821.083201122 -628.990515742 correct
247.259901524 -911.297127623 wrong
32.754761305
10 -A no errors found
11 -A+B no errors found
12 -A-B no errors found
13 (A-B)/C no errors found
@ HP-35s program for testing errors while computing formulae in ALG mode
@ Wojtek Waszak (12.2015)
@ ROUTINE C - input data in x register, of N.FS structure, where:
@ N = # of iterations (0=default=100), F = function number from 0-9 range
@ S - stop flag (0=default=stop after 1-st error, other value = search for more errors, <10)
@ examples: x=0 means max 100 iterations, test function #0, stop after 1st error found
@ x=200.49 means max 200 iterations, test function #4, find max 9 wrong/correct results' pairs
@ ROUTINE D - no input data. Displays correct & wrong results from memory,
@ stores input data in variables A,B,C and function number in V for verification by routine B
@ ROUTINE B - no input data, repeats calculations for data displayed by routine D
@ which had led to wrong results, based on data in variables A,B,C and V.
@ Stores results of procedure D in t and z and verified results in registers x and y
@ ROUTINES E,F,X - auxiliary test routines
@ ROUTINE E - calculations with data in A,B,C and V and test function from Y routine
@ ROUTINE F - calculations with data in A,B,C and arbitrary function coded in F006 line
@ ROUTINE X - calculations with arbitrary data in A,B,C and V and test function in routine Y
@ DATABASE RECORD STRUCTURE (6 fields) in indirect register pool:
@ 1-1st result (correct), 2-2nd result, 3-number of test function, 4-A, 5-B, 6-C
@ VARIABLES USED:
@ A,B,C - random generated input parameters for test functions
@ S - copy of start parameter from x register for routine C
@ U - max number of iterations, V - test function number, W - max number of errors to be found
@ X - counter of errors found, Y - iteration counter
@ D,E,Z - working variables, T - working variable - copy of I variable
@ ROUTINE C - input data in x register - SET x REGISTER BEFORE RUNNING THIS ROUTINE!
C001 LBL C @ main loop (in RPN mode) (CHS=4997, bytes=118)
STO S @ save start parameters from x register in S variable
C003 XEQ Z025 @ fetch start parameters
0
STO Y @ clear iteration counter
STO I @ clear index to store data
SEED @ clear seed for radom generator
SF 10 @ set message flag
C009 XEQ Z010 @ call random test data generator
XEQ Z048 @ call testing functions
ISG Y @ increment iteration counter
x<>y @ dummy instruction
RCL Y
RCL U
- @ if x=0 all iterations done
RCL X @ if X=0 assumed number of errors was found
x
X<>0?
GTO C009 @ continue search if iteration# and error# less then assumed
RCL W
RCL X
STO Z
x<>0? @ check assumed number of results found and stored
ERRORS FOUND
x=0?
NO ERRORS @ press R/S to see number of errors found
CF 10 @ clear message flag
RCL Y @ number of iterations to y register
RCL Z @ number of errors found to x register
STOP @ press R/S to continue
C030 GTO C003 @ go on for another search with same initial settings
@ displays correct and wrong results found
@ stores input data in A,B and C variables, stores number of test function in V
D001 LBL D
SF 10 @ (CHS=08A6, bytes=132)
0
STO I @ clear index of data
RCL W @ recall number of wrong results found
RCL X
x=0?
GTO D035
STO Z @ set counter of wrong results (working variable)
D011 RCL I
STO T @ save copy of I in T
XEQ Z006 @ load to stack and display correct and wrong results
STO D
XEQ Z006
STO E
XEQ Z006
STO V @ save test function number
XEQ Z006 @ save input data to test functions which generated errors
STO A
XEQ Z006
STO B
XEQ Z006
STO C
0 @ put marker onto the stack
RCL V @ load test function number
RCL D @ load to y register calculated wrong result
RCL E @ load to x register calculated correct result
DSE Z @ decrement data counter
GTO D011
END OF ERRORS
PSE
GTO D001 @ display again the same data set
D035 NO ERRORS
D036 GTO D035
@ ROUTINE B - check procedure - no input data.
@ loads data pointed by I and repeats calculations that have led to wrong results
B001 LBL B @ (CHS=9556, bytes=39)
RCL T
STO I
XEQ Z006
STO D
XEQ Z006
STO E
XEQ Y001 @ calculate again based on input data in A,B,C and V variables
XEQ Y001
RCL E @ restore correct and wrong results from repeated calculations
RCL D
STOP @ display results
B013 GTO B001 @ repeat the check calculations
@ ROUTINE X - check procedure for single case of A,B,C set giving wrong result
X001 LBL X @ (CHS=CA88, bytes=75)
8
STO V @ set function number from 0-9 range from Y routine
465.408630753
STO A
763.771068422
STO B
625.04689574
STO C @ with A,B,C as above function 8 gives 364262828.495 and 476927.326742
XEQ Y001
XEQ Y001
X012 STOP
E001 LBL E @ check procedure taking input data from A,B,C, (CHS=49C8, bytes=15)
XEQ Y001 @ and calling test function from set in routine Y
XEQ Y001 @ number of test function is in V
STOP
E005 GTO E001
F001 LBL F @ check procedure for single case of A,B,C set, (CHS=667F, bytes=27)
XEQ F006 @ and test functions not limited to set in routine Y
XEQ F006
STOP
GTO F001
F006 -(A x 2) @ example test function
F007 RTN
@ SUBROUTINE - test functions for generating errors
Y001 LBL Y @ (CHS=9B7B, bytes=252)
RCL V @ load test function number from 0-9 range
IP
Y004 STO Z
ISG Z @ change function number to 1-10 range.
Y006 1 @ dummy
@ it would be more straightforward just add 1 before STO Z (in Y004)
@ instead of ISG Z and 1 here but "+" makes all the functions
@ in routine Y give only correct results!
Rv
Y008 DSE Z @ select test function
GTO Y011
GTO Y038
Y011 DSE Z
GTO Y014
GTO Y040
Y014 DSE Z
GTO Y017
GTO Y042
Y017 DSE Z
GTO Y020
GTO Y044
Y020 DSE Z
GTO Y023
GTO Y046
Y023 DSE Z
GTO Y026
GTO Y048
Y026 DSE Z
GTO Y029
GTO Y050
Y029 DSE Z
GTO Y032
GTO Y052
Y032 DSE Z
GTO Y035
GTO Y054
Y035 DSE Z
GTO Y038
GTO Y056
Y038 -(A) @ function 0 (errors)
RTN
Y040 -(A + 1) @ function 1 (errors)
RTN
Y042 -(A x 2) @ function 2 (errors)
RTN
Y044 -(A + B) @ function 3 (errors)
RTN
Y046 -(A - B) x C @ function 4 (errors)
RTN
Y048 -(A + B) / C @ function 5 (errors)
RTN
Y050 -A x (B - C) / C @ function 6 (errors)
RTN
Y052 -(A + B) / (B - C) @ function 7 (errors)
RTN
Y054 -A + B x C @ function 8 (errors)
RTN
Y056 -A x (B - C) / (B + C) @ function 9 (errors)
RTN
@ AUXILIARY SUBROUTINES
Z001 LBL Z @ (CHS=1FE7, bytes=210)
@ SUBROUTINE - store data from x register in indirect register pool
Z002 STO (I)
ISG I
RTN
RTN
@ SUBROUTINE - load data from indirect register pool to x register
Z006 RCL (I)
ISG I
RTN
RTN
@ SUBROUTINE - generate 3 random test data
Z010 1000 @ range of random data, can be 100 or other number here
RANDOM
x<>y
x
STO A @ store data in A,B,C variables
LASTx
RANDOM
x<>y
x
STO B
LASTx
RANDOM
x
STO C
Z024 RTN
@ SUBROUTINE - set start parameters for C routine
Z025 100
STO U @ set default max number of iterations
RCL S @ restore x register from S variable
IP
x>0?
STO U @ set max number of iterations from input data
10
RCL S
FP
x
ENTER
IP
STO V @ save test function number from 0-9 range
x<>y
FP
10
x
IP
x=0?
1
STO W @ set max number of errors to be found
STO X @ set counter of errors
RTN
@ SUBROUTINE - call test functions and store results
Z048 XEQ Y001 @ call testing function
XEQ Y001 @ call again the same test function
x=y? @ check if results are equal
RTN @ return if equal
x<>y
XEQ Z002 @ store correct and wrong results
x<>y
XEQ Z002
RCL V
XEQ Z002 @ store function number
RCL A
XEQ Z002 @ store data which led to errors
RCL B
XEQ Z002
RCL C
XEQ Z002
DSE X @ decrement counter of errors found
RTN @ return if X>0
Z066 RTN @ return if X<=0
1.
2.
3.
3.
4.
5.
6.
