I've been writing some simple CAS programs in CAS mode and I've encountered a few issues. The first is to do with return:
#cas
rtest(x):=
IF (x<0) THEN return -1; END;
return 1;
#end
I'd expect this to return -1 if x<0 and 1 otherwise, but it always returns 1. It isn't hard to work around this (using ELSE), but is there something that I'm missing here?
The second issue (rather obscure) is to do with the length() function. length("abc") returns 3, which is fine. length(x+2=y) (note: expressions in XCAS seem to be stored as lists) returns 2, although it has three elements.
More generally: does anyone know where I can find lots of CAS programs written for the Prime? I like to learn a programming language by looking at programs that other people have already written!
Nigel (UK)
(12-01-2015 09:36 PM)Nigel (UK) Wrote: [ -> ]I've been writing some simple CAS programs in CAS mode and I've encountered a few issues. The first is to do with return:
#cas
rtest(x):=
return 1;
#end
Nigel (UK)
Using upper-case RETURN() will do what you want. I remember running into this a long time ago and return() in lower-case only works properly if it is the last statement of the program (the actual "return" is likely due to the ending of the program, though, and not the command itself). I had to make this change in my SVD program listing. I do not know if this ever got reported as a bug, though.
Is length counting an equality as 2 since there are two sides of an equation? I'm not sure how you get 3 elements from x+2=y
There are several cas programs in the HP Prime library. (Joe Horn has written a few, I have one that computes the SVD of a matrix and a few other linear algebra routines, and I am sure you can find more if you look).
Thank you for the RETURN() information; I guess I should have thought of trying uppercase!
So far as length(x+2=y) is concerned, I know that there are three elements because (x+2=y)[1] returns '=', (x+2=y)[2] returns x+2, and (x+2=y)[3] returns y. x+2 is then another three-element list: '+', x, and 2. I was just curious about the reason for a length of 2 being reported. If it is a bug, it's not too important.
Thank you for the program library suggestion. Your SVD program is exactly the type of thing I was looking for. It will be studied!
Nigel (UK)
(12-01-2015 10:15 PM)Nigel (UK) Wrote: [ -> ]Thank you for the RETURN() information; I guess I should have thought of trying uppercase!
Nigel (UK)
Just a fair warning, though: I did not insert as many comments as a good programmer would have.
Indeed, return should be recognized like RETURN.
Expressions are coded as trees. size will return the number of arguments : try size(sin(x)) or size(x+y+z), while op(a) will return the sequence of arguments of the root-node function/operator of a.
(12-02-2015 01:54 PM)parisse Wrote: [ -> ]Indeed, return should be recognized like RETURN.
The current behavior of return() is that it actually does not "return" to the parent function.
