10-30-2015, 05:09 PM
I like the ENG button in Casio calculator. It display number in engineering format and convert exponent(For example xxxE3 to xxxE6, xxxE6 to xxxE9 or reverse).
HP prime seems do not have this button. So I make one for my HP prime.
You may find that I use a dumb method to do the conversion. If you have better method, it is welcome to post it in this thread.
Operation:
1)Key press: [Shift > User > * (Multiplication)] : exponent+3, E-12>E-9....E3>E6>E9>E12
2)Key press: [Shift > User > / (Division)] : exponent-3, E12>E9....E-3>E-6>E-9>E-12
3)Key press: [Shift > User > + (Addition)] : convert string back to number
Screen shot:
[attachment=2729]
ENG program:
User Defined key:
[attachment=2731]
[attachment=3613]
Last:
Feature request for HP prime:
1) Need "press Enter" function in program. So that I don't need to press Enter after pressing user defined key.
2) Reverse HELP/USER key. So that [Shift] for HELP, normal for USER. This could reduce key stroke for user defined key. Please add this option in Setting mode.
Thanks!
EDITED:2016-JUN-9
Correct negative number bug.
Delete the leading zeor. eg. 1.25000E0 => 1.25E0
Operation:
Screen shot:
[attachment=2729]
ENG program:
EXPORT ENGA(x)
LOCAL pos,s,i,sign;
IF TYPE(x)==0 THEN
s:=STRING(x,4,11);
WHILE INSTRING(s,"0ᴇ") DO
s:=REPLACE(s,"0ᴇ","ᴇ")
RETURN s;
IF (TYPE(x)==2) AND (INSTRING(x,"ᴇ12")) THEN
RETURN x;
IF (TYPE(x)==2) AND (INSTRING(x,"ᴇ12")==0) THEN
IF CHAR(x(1))=="−" THEN
sign:="−";
x:=RIGHT(x,DIM(x)-1);
ELSE
sign:="";
s:=x;
FOR i FROM 1 TO 3 DO
pos:=INSTRING(s,".");
s(pos):=s(pos-1);
s(pos-1):=".";
IF pos==2 THEN
s:="0"+s;
s:=REPLACE(s,"ᴇ9","ᴇ12");
s:=REPLACE(s,"ᴇ6","ᴇ9");
s:=REPLACE(s,"ᴇ3","ᴇ6");
s:=REPLACE(s,"ᴇ0","ᴇ3");
s:=REPLACE(s,"ᴇ−3","ᴇ0");
s:=REPLACE(s,"ᴇ−6","ᴇ−3");
s:=REPLACE(s,"ᴇ−9","ᴇ−6");
s:=REPLACE(s,"ᴇ−12","ᴇ−9");
s:=sign+s;
RETURN s;
EXPORT ENGB(x)
LOCAL pos,s,i,sign;
IF TYPE(x)==0 THEN
s:=STRING(x,4,11);
RETURN s;
IF TYPE(x)==2 AND (INSTRING(x,"ᴇ−12"))THEN
RETURN x;
IF TYPE(x)==2 AND (INSTRING(x,"ᴇ−12")==0)THEN
sign:="−";
ELSE
sign:="";
s:=x;
IF s(pos+1)==7431 THEN
s:=REPLACE(s,".ᴇ","0.ᴇ");
ELSE
s(pos):=s(pos+1);
s(pos+1):=".";
IF (pos==2) AND (s(1)==48) THEN
s:=RIGHT(s,DIM(s)-1);
s:=REPLACE(s,"ᴇ−9","ᴇ−12");
s:=REPLACE(s,"ᴇ−6","ᴇ−9");
s:=REPLACE(s,"ᴇ−3","ᴇ−6");
s:=REPLACE(s,"ᴇ0","ᴇ−3");
s:=REPLACE(s,"ᴇ3","ᴇ0");
s:=REPLACE(s,"ᴇ6","ᴇ3");
s:=REPLACE(s,"ᴇ9","ᴇ6");
s:=REPLACE(s,"ᴇ12","ᴇ9");
s:=sign+s;
RETURN s;
User Defined key:
KEY K_Mul()
RETURN "ENGA(Ans)";
KEY K_Div()
RETURN "ENGB(Ans)";
KEY K_Plus()
RETURN "EXPR(Ans)";
[attachment=2731]
[attachment=3613]
Last:
Thanks!
EDITED:2016-JUN-9
