I have a problem with the decimal separator. If I use the comma necessary to use the "fracmod ()" the program that contains the function no longer runs it stops on every point of the program, for example, list of variables etc ... And if I uses the period as the separator the program works except the "fracmod ()" which does not run because it forward a number with a comma and not a point.
How to define what functions to work with a point rather than a variable?
Thank you for your help.
(10-28-2015 05:06 AM)wChris79 Wrote: [ -> ]Hello,
That's because the program lacks the #pragma line.
this line tells the calculator what are the separators used to built the program (the source)
It can be optained with menu key while editing the program.
What you can do :
Change your configuration to find the one that make this program to works.
Ok, then edit the source and insert pragma at first line.
example :
#pragma mode( separator(.,;) integer(h32) )
Excuse me, but where is the menu button in the edit mode of the program and the item 5 "insert pragma"
On the other hand I have a syntax error by inserting exactly your example online
#pragma mode (separator (.,;) integer (h32)) in first line of the program.
(10-28-2015 08:15 AM)wChris79 Wrote: [ -> ]On the other hand I have a syntax error by inserting exactly your example online
First, you have a space after "mode", mine does not. same with separator and integer.
Second, separator in my example comes from my settings.
Until I see your program, I can't tell you if it's ok for your program... your program may require something different, that's why I told you to find the right setting and then to insert program from the "menu" key.
Regards.
Don't forget to update the firmware if you have not already done so
I can not find the solution.
I tried several combinations.
In settings: the decimal separator is the point.
decimal separator is a point in the program.
parameter separator is a comma in the program.
command separator is a semi in the program.
and integers are 32 bits hexadecimal
Here is my code:
#pragma mode(separator(.,
integer(h32))
EXPORT TEST2()
LOCAL x, y;
10 -> x;
2015 -> y;
PRINT("TEST ANNEE : " + y + " MOIS : " + x);
Votre programme fonctionne très bien, j'ai juste modifié "->" en "▶"
Your program does works, I only changed "->" into "▶"
#pragma mode(separator(.,;) integer(h32))
EXPORT TEST2()
LOCAL x, y;
10▶x;
2015▶y;
