10-25-2015, 05:10 PM
Hello folks,
This program calculates the resultes of interception and give them back with exact values. The program uses the command LINSOLVE that is the fastes way because the numerical MSLV needs a lot of more time even for linear systems. And if there is no solution (parallel or skew lines) it will take a lot of more time to come to an end.
But the LINSOLVE only works correct in exact mode. So if you have an input with real vector componets you have them to convert into exact ones (the program does it automatically).
The program recognizes the 2D or 3D input by itself.
A line (2D or 3D) can be represented in the form:
\[ \vec{x} = \vec{t} + \alpha\cdot\vec{r} \].
ti an ri are 2D or 3D vectors
stack 4: ta
stack 3: ra
stack 2: tb
stack 1: rb
Here we go:
output has for all three cases the same two stack form:
stack 2: {[x y (z)] A B} (for interception point for 2D or 3D, coordinates of the point and parameter values for the line representations )
stack 1: 1,
or
stack 2: 'ta + A*ra' (for identical lines)
stack 1: 2,
or
stack 2: {} (for no interception)
stack 1: 0
stack 4: ta
stack 3: ra
stack 2: tb
stack 1: rb
Here we go:
%%HP: T(3)A(R)F(,);
\<< 1, 4, @@convert the vectors in
START \->Q\pi 4, ROLL @@vectors with exact components
NEXT @@\->Q doesn't work on vectors, so you have to use \->Q\pi
\-> TA RA TB RB
\<< TA TB - 'A' RA * 'B' RB * - + @@ preparing input for LINSOLVE
OBJ\-> OBJ\-> DROP \-> N
\<< N
IF 2, ==
THEN 0 = SWAP 0 = SWAP N \->ARRY @@input for 2D vector equation
ELSE 0 = ROT 0 = ROT 0 = ROT N \->ARRY @@input for 3D vector equation
END [ 'A' 'B' ] @@output variables
LINSOLVE
ROT DROP
SWAP DROP
DUP SIZE OBJ\-> DROP \-> LV NL @@preparing output from LINSOLVE for analysing
\<< LV NL GET
EXLR \-> LEQ REQ
\<< IF LEQ 'B' SAME
THEN TB RB REQ * +
REQ LV NL 1, - GET
EXLR SWAP DROP SWAP 3, \->LIST 1, @@ output for interception point
ELSE
IF LEQ 'A' SAME
THEN TA 'A' RA * + 2, @@ output for identical lines
ELSE { } 0, @@ output for parallel or skew lines
END
END
stack 1: 1,
or
stack 1: 2,
or
stack 1: 0
