10-28-2015, 12:24 AM
(10-27-2015 10:25 PM)Dieter Wrote: [ -> ](10-27-2015 07:32 PM)Dieter Wrote: [ -> ]BTW, at the moment I am looking at an 35s implementation of the HP67 routines.
OK, here is a first experimental version of the Chi² algorithm used in the HP67 Stat Pac. PDF and CDF are calculated simultaneously, and both are returned in Y and X. Here is the code:
C001 LBL C
C002 INPUT J
C003 e
C004 IP
C005 STO T
C006 ÷
C007 !
C008 STO G
C009 INPUT X
C010 XEQ C013
C011 STOP
C012 GTO C009
C013 RCL X
C014 RCL÷ T
C015 +/-
C016 e^x
C017 LASTx
C018 +/-
C019 RCL J
C020 RCL÷ T
C021 y^x
C022 x
C023 RCL÷ G
C024 STO A
C025 RCL J
C026 STO B
C027 SGN
C028 ENTER
C029 -
C030 ENTER
C031 ENTER
C032 LASTx
C033 RCLx X
C034 RCL B
C035 RCL+ T
C036 STO B
C037 ÷
C038 +
C039 x≠y?
C040 GTO C030
C041 RCL A
C042 RCL X
C043 x=0?
C044 e^x
C045 ÷
C046 RCLx J
C047 RCL÷ T
C048 x<>y
C049 RCLx A
C050 RCL+ A
C051 RTN
Usage (results as shown in FIX 9 mode):
[XEQ] C [ENTER] J=?
Enter degrees of freedom
10 [R/S] X=?
Enter random variable X
6,3 [R/S] 0,087896860 // =PDF(6,3|10)
0,210539719 // =CDF(6,3|10)
Do another calculation
[R/S] X=?
20 [R/S] 0,009458319 // =PDF(20|10)
0,970747312 // =CDF(20|10)
As usual, comments, suggestions and error reports are welcome. ;-)
Since the main computation routine (C013 ff.) returns both the PDF and the CDF, adding a function that determines the inverse (quantile) is rather simple. I tried an approach using a second-order (Halley) method and it worked well for me. This required about 30 additional lines of code.
Dieter
Dieter, the program works perfect!. Please include the function for the inverse, no mather how long it takes
