10-23-2015, 11:56 AM
Hello !
I noticed that the number format in CAS is always the same as in Home, independently of what I select in CAS Settings.
When I select Floating 3 in Home and Scientific 6 in CAS, all the results are in Floating 3 format, in both Home and CAS.
I know Cas is not intended as a modality to work with real numbers, but as you can select a number format, than you should obtain the result as you defined it. (Stomped on this looking for the 0.5-0.3-0.2 of the "HP Prime miscalculating" thread by Luc4as)
Am I missing something?
Thank you for the help
Reto
Reto
