Full Version: ZIPP: G1CMZ's Immensely Practical Package
A collection of programs intended to be immediately practical -
The intention is
1 Results should be quick...
A thunderstorm calculation might ask for an estimate of air temperature: the user knows if its cold or warm. It won't ask for air density or composition. And don't expect meaningful results if you say the air temperature is absolute zero.
2 Results should be easily assimilated...
Expect results to be presented in km, not mm.
Though you can ask for more if you need it.
3 If you need software that can handle such extremes, ask about my technical version. Thunderstorm times for the arctic, or for Mars, anyone? I may need to tweak a few formula...
4 I've seen plenty of thunderstorm distance calculators, but this one helps you do the timing too. No, it doesn't need a datastream.
It does unit conversion too.
Version 0.1
#pragma mode( separator(.,;) integer(h32) )
 LOCAL ZIPPST:="ZIPP V 0.1 ";
 LOCAL SG:=" StephenG1CMZ";
 LOCAL CRID:=ZIPPST+"© 2015 "+SG;
 LOCAL NL:=CHAR(10);
 LOCAL CD2,CD1;
 EXPORT ZIPPRND;//USER ROUNDING
 LOCAL THSPD_M;
 LOCAL MEAS_INTERVAL_S;
 LOCAL TOMI:=1.60344;//MILES UK
 LOCAL TONM:=1.852;//NAUTI
 MSNK()
   LOCAL SNK:=MOUSE();
 CONVERT_UNIT_GRP(unit,tname)
  LOCAL x,menu,a1,a2,t;
  LOCAL HLP:=tname+":Enter value(s) using:";
  menu:=unit;//AUTO
  CHOOSE(CD2,"Units:"+tname,menu);
  IF CD2 THEN
   INPUT({{ x,[2],{45,20,3} }},"","Convert ",HLP+unit[CD2]);
   //DETECT ESC
   IF string(x,1) == "0" THEN RETURN; END;
   CHOOSE(CD1, "To Units:"+tname, menu);
   a2 := unit[CD2];
   a1 := unit[CD1];
   t := x + "*" + CONVERT(a2,a1);
   RETURN expr(t);
 EXPORT CONVERT_UNITS()
  LOCAL CHSTYP;
  LOCAL TTL:="Unit types";
  LOCAL UTYP:={"Length","Area","Volume",
   "Time","Speed","Acceleration","Mass","Force",
   "Energy","Power","Pressure","Temperature:NO!",
   "Electricity","Light","Angle","Viscosity","Radiation"};
  LOCAL UL:={};
  CHOOSE(CHSTYP,TTL,UTYP);
  CASE
   IF CHSTYP==1 THEN //LENGTH
    //CONVERT_Length();
    UL:={1_m,1_cm,1_mm,1_km,1_in,1_ft,1_yd,1_mile,1_nmi,1_au,1_lyr,1_pc,1_Å};
   IF CHSTYP==2 THEN //AREA
    UL:={1_(cm²),1_(m²),1_(km²),1_(in²),1_(ft²),1_(yd²),1_(mile²),1_(miUS²),1_a​cre,1_ha,1_a,1_b};//A:Are B:Barn
    //CONVERT_UNIT_GRP(UL);
   IF CHSTYP==3 THEN //VOLUME
    UL:={1_(cm^3),1_(m^3),1_ml,1_l,1_(in^3),1_(ft^3),1_(yd^3),1_ptUK,1_galUK,1_​galUS};
   IF CHSTYP==4 THEN //TIME
    UL:={1_s,1_min,1_h,1_d,1_yr,1_Hz};
   IF CHSTYP==5 THEN //SPEED
    UL:={1_(cm/s),1_(m/s),1_kph,1_(km/h),1_(ft/s),1_mph,1_(mile/h),1_knot,1_(rad/s),1_(tr/min),1_(tr/s)};
   IF CHSTYP==6 THEN //ACCEL
    UL:={1_(m/s²),1_(ft/s²),1_grav,1_Gal,1_(rad/s²)};
   IF CHSTYP==7 THEN //MASS
    UL:={1_g,1_kg,1_oz,1_lb,1_tonUK,1_tonUS,1_mol,1_u,1_t};
   IF CHSTYP==8 THEN //FORCE
    UL:={1_(kg*m/s²),1_N,1_dyn,1_lbf,1_kip,1_gf,1_pdl};
   IF CHSTYP==9 THEN //ENERGY
    UL:={1_(kg*m²/s²),1_J,1_Wh,1_kWh,1_(ft*lbf),1_kcal,1_cal,1_eV,1_MeV,1_Btu,1_erg,1_thermUK,1_th​ermEC,1_thermUS};
   IF CHSTYP==10 THEN //POWER
    UL:={1_(kg*m²/s^3),1_W,1_MW,1_hp,1_(ft*lbf/s)};
   IF CHSTYP==11 THEN //PRESSURE
    UL:={1_(kg/(m*s²)),1_Pa,1_bar,1_atm,1_psi,1_torr,1_mmHg,1_inHg,1_inH2O};
   IF CHSTYP==13 THEN //ELEC
    UL:={1_A,1_V,1_C,1_Ohm,1_F,1_Fdy,1_Wb,1_H,1_mho,1_T,1_(A*h),1_S};
   IF CHSTYP==14 THEN //LIGHT:HP MISSING MOST UNITS
    UL:={1_cd,1_flam};
   IF CHSTYP==15 THEN //ANGL
    UL:={1_rad,1_deg,1_arcmin,1_arcs,1_tr};
   IF CHSTYP==16 THEN //VISCOSITY
    UL:={1_(m²/s),1_P,1_St};
   IF CHSTYP==17 THEN //RADIATION
    UL:={1_Bq,1_Ci,1_Gy,1_rd,1_rem,1_Sv,1_R};
   DEFAULT
    //DO NOT CONVERT_UNIT_GRP(UL);
  IF SIZE(UL)>0 THEN //AND CHSTYP>0
   MSGBOX(CONVERT_UNIT_GRP(UL,UTYP(CHSTYP)),1);
 INPUT_INTERVAL_H(TTL)
  LOCAL HH,MM,SS;
  LOCAL LBL:={"HH","MM","SS"};
  LOCAL HLP:="HH MM SS:ETC";
  INPUT({HH,MM,SS},TTL,LBL,HLP,0,0);
  RETURN HH+(MM/60)+(SS/3600);
 EXPORT MEASURE_INTERVAL_S()
  LOCAL TICKB,TICKE,TICKL;
  LOCAL TS,KK;
  LOCAL MI:=0;
  LOCAL MST:="MEASURE SHORT INTERVAL"+NL;
  LOCAL MST1:="OK or Enter: Start"+NL;
  LOCAL MST2:="Enter:Enter HMS numerically"+NL;
  LOCAL MST3:="ANY KEY: End"+NL;
  //LOCAL CNW:="CONNECTIVITY:NO HP DATA";
  LOCAL ENINST:="Enter INTERVAL";
  TICKB:=MSGBOX(MST+MST1+MST2+MST3,1);
  IF TICKB THEN
   RECT();
   TICKB:=Ticks; TS:=Time;
   TICKL:=TICKB;
   REPEAT
    MSNK;
    IF Ticks-TICKL≥1000 THEN
     TICKL:=Ticks;
     RECT();
     TEXTOUT_P(→HMS(ROUND((Ticks-TICKB)/1000,0)/3600),0,20);
     MSNK;
     TEXTOUT_P(TS+MST,0,180);
     TEXTOUT_P(MST2,0,200);
     TEXTOUT_P(MST3,0,220);
    WAIT(0.001);
    MSNK;
    KK:=GETKEY;
   UNTIL KK≥0;
   TICKE:=Ticks;
   MI:=(TICKE-TICKB)/1000;
   IF KK==30 THEN //ENTER
    MI:=3600*INPUT_INTERVAL_H(ENINST);
  RETURN MEAS_INTERVAL_S:=ROUND(MI,ZIPPRND);
 THUNDER_DISTANCE_CALC_M(INTERVAL_S,TEMP_C)
 //INTERVAL
 //CENTIGRADE (NORMAL RANGE)
  LOCAL DISTM;
  THSPD_M:=331.4+0.6*TEMP_C;//M/S
  DISTM:=INTERVAL_S*THSPD_M;
  RETURN ROUND(DISTM,ZIPPRND);
 EXPORT THUNDER_DISTANCE()
  LOCAL OK;
  LOCAL THDST:={};
  LOCAL THDM,THDKM,THDMI,THDNM;
  LOCAL INTERVAL_S,TEMP_C;
  LOCAL TTL:="THUNDER DISTANCE"+SG;
  LOCAL LBL:={"Interval s","Temp C"};
  LOCAL HLP:={"Interval sound-light. (0:use measured value)","temp C eg 0..20:Ground −57: Aircraft"};
  OK:=INPUT({INTERVAL_S,TEMP_C},TTL,LBL,HLP,MEAS_INTERVAL_S,0);
  IF OK THEN
   IF INTERVAL_S≤0 THEN //IMPORT VALUE
    INTERVAL_S:=MEAS_INTERVAL_S;
   THDM:=THUNDER_DISTANCE_CALC_M(INTERVAL_S,TEMP_C);
   THDKM:=THDM/1000;
   THDMI:=THDKM/TOMI;
   THDNM:=THDKM/TONM;
   THDST(1):=ROUND(INTERVAL_S,0)+" s"+" @ "+ROUND(THSPD_M,ZIPPRND)+" m/s"+NL;
   THDST(2):=THDM+" m "+ROUND(THDKM,ZIPPRND)+" km"+NL;
   THDST(3):=ROUND(THDMI,ZIPPRND)+" milesUK"+NL;
   THDST(4):=ROUND(THDNM,ZIPPRND)+" Nautical Miles";
   MSGBOX(THDST(1)+THDST(2)+THDST(3)+THDST(4));
   RETURN THDST(2);
 ABOUT ()
  LOCAL ST:="StephenG1CMZ is a programmer and can work to your requirements."+NL;
  LOCAL SZ:="ZIPP provides useful practical results.
Ask, if you need technical results."+NL;
  LOCAL THANX:="Thanks Han for the CONVERT syntax."+NL;
  LOCAL LGL:="No liability is accepted.";
  PRINT(); PRINT(CRID);
  PRINT(ST+NL+SZ);
  PRINT(THANX);
  PRINT(LGL);
  WAIT;
 HELP ()
  LOCAL ST:="To change the number of digits displayed:
 ZIPPRND:=n where n=−12..12"+NL;
  LOCAL CVT:="CONVERT
Note that not all units within a group can be converted.
Conversion between groups (eg length*length to area) is not implemented here."+NL;
  PRINT(CVT+ST);
  WAIT;
 EXPORT G1CMZ_IMMENSELY_PRACTICAL_PACKAGE ()
  LOCAL CHS;
  REPEAT
   CHOOSE(CHS,CRID,{"ABOUT","HELP","CONVERT UNITS","MEASURE INTERVAL s","THUNDER DISTANCE","EXIT"});
   CASE
    IF CHS==1 THEN ABOUT() END;
    IF CHS==2 THEN HELP() END;
    IF CHS==3 THEN CONVERT_UNITS() END;
    IF CHS==4 THEN MSGBOX(MEASURE_INTERVAL_S()+" s",1) END;
    IF CHS==5 THEN THUNDER_DISTANCE() END;
    IF CHS==6 THEN CHS:=0 END;
    DEFAULT
   //WAIT;
  UNTIL CHS==0;
 EXPORT ZIPP()
  G1CMZ_IMMENSELY_PRACTICAL_PACKAGE();
Version 0.2:
Now supports SI prefixes in unit conversions. User interface tweaked.
 LOCAL ZIPPST:="ZIPP V 0.2 ";
 LOCAL NL:=CHAR(10);
 LOCAL CDFROM,CDTO;
 EXPORT ZIPPROUND;//USER ROUNDING
 LOCAL THSPD_M;
 //SI PREFIXES
 LOCAL YOTTA:=1ᴇ24;
 LOCAL ZETTA:=1ᴇ21;
 LOCAL EXA  :=1ᴇ18;
 LOCAL PETA :=1ᴇ15;
 LOCAL TERA :=1ᴇ12;
 LOCAL GIGA :=1ᴇ9;
 LOCAL MEGA :=1ᴇ6;
 LOCAL KILO :=1ᴇ3;
 LOCAL HECTO:=1ᴇ2;
 LOCAL DECA :=1ᴇ1;
 LOCAL DECI :=1ᴇ−1;
 LOCAL CENTI:=1ᴇ−2;
 LOCAL MILLI:=1ᴇ−3;
 LOCAL MICRO:=1ᴇ−6;
 LOCAL NANO :=1ᴇ−9;
 LOCAL PICO :=1ᴇ−12;
 LOCAL FEMTO:=1ᴇ−15;
 LOCAL ATTO :=1ᴇ−18;
 LOCAL ZEPTO:=1ᴇ−21;
 LOCAL YOCTO:=1ᴇ−24;
 MSNK()
   LOCAL SNK:=MOUSE();
  LOCAL UF;
  LOCAL TTL:="TO USE SI PREFIXES: TYPE PREFIXNAME";
  LOCAL HLP:=tname+": Enter value(s) using: ";
  menu:=unit;//AUTO
  CHOOSE(CDFROM,"Units:"+tname,menu);
  IF CDFROM THEN
   UF:=MID(STRING(unit[CDFROM]),3);//REMOVE 1_
   INPUT({{ x,[2],{45,20,3} }},TTL,"Convert ",HLP+UF);
   //DETECT ESC
   CHOOSE(CDTO, "To Units:"+tname, menu);
   a2 := unit[CDFROM];
   a1 := unit[CDTO];
   RETURN expr(t);
  LOCAL CHSTYP;
  LOCAL UL:={};
  CASE
    //CONVERT_Length();
    UL:={1_cd,1_flam};
   DEFAULT
  LOCAL HH,MM,SS;
  LOCAL IV:="INTERVAL ";
  LOCAL LBL:={IV+"HH",IV+"MM",IV+"SS"};
  LOCAL HLP1:="Decimals & Fractions allowed";
  LOCAL HLP:={HLP1,HLP1,HLP1};
  LOCAL TS,KK;
  LOCAL MI:=0;
  IF TICKB THEN
   RECT();
   TICKL:=TICKB;
   REPEAT
    MSNK;
     TICKL:=Ticks;
     RECT();
     MSNK;
    WAIT(0.001);
    MSNK;
    KK:=GETKEY;
   UNTIL KK≥0;
   TICKE:=Ticks;
  RETURN MEAS_INTERVAL_S:=ROUND(MI,ZIPPROUND);
 //INTERVAL
  LOCAL DISTM;
  RETURN ROUND(DISTM,ZIPPROUND);
  LOCAL OK;
  LOCAL THDST:={};
  IF OK THEN
   THDKM:=THDM/1000;
   THDMI:=THDKM/TOMI;
   THDNM:=THDKM/TONM;
   THDST(1):=ROUND(INTERVAL_S,0)+" s"+" @ "+ROUND(THSPD_M,ZIPPROUND)+" m/s"+NL;
   THDST(2):=THDM+" m "+ROUND(THDKM,ZIPPROUND)+" km"+NL;
   THDST(3):=ROUND(THDMI,ZIPPROUND)+" milesUK"+NL;
   THDST(4):=ROUND(THDNM,ZIPPROUND)+" Nautical Miles";
   RETURN THDST(2);
 ABOUT ()
  PRINT(ST+NL+SZ);
  PRINT(THANX);
  PRINT(LGL);
  WAIT;
 HELP ()
 ZIPPROUND:=n where n=−12..12"+NL;
  LOCAL CVT:="CONVERT
Note that not all units within a group can be converted. Conversion between groups (eg length*length to area) is not implemented here.
SI prefixes allowed, e.g. INPUT 1*NANO (Type it, Do not select from Prefix menu)"+NL ;
  PRINT(CVT+ST);
  WAIT;
  LOCAL CHS;
  REPEAT
   CASE
    DEFAULT
   //WAIT;
  UNTIL CHS==0;
 EXPORT ZIPP()
Version 0.3:
User interface improved. Multilingual support added.
In English, et maintenant en francais aussi (translated with the help of Google).
 LOCAL ZIPPST:="ZIPP V 0.3 ";
 LOCAL NL:=CHAR(10);
 LOCAL SL:=1;
 LOCAL CDFROM,CDTO;
 LOCAL THSPD_M;
 //SI PREFIXES
 LOCAL YOTTA:=1ᴇ24;
 LOCAL ZETTA:=1ᴇ21;
 LOCAL EXA  :=1ᴇ18;
 LOCAL PETA :=1ᴇ15;
 LOCAL TERA :=1ᴇ12;
 LOCAL GIGA :=1ᴇ9;
 LOCAL MEGA :=1ᴇ6;
 LOCAL KILO :=1ᴇ3;
 LOCAL HECTO:=1ᴇ2;
 LOCAL DECA :=1ᴇ1;
 LOCAL DECI :=1ᴇ−1;
 LOCAL CENTI:=1ᴇ−2;
 LOCAL MILLI:=1ᴇ−3;
 LOCAL MICRO:=1ᴇ−6;
 LOCAL NANO :=1ᴇ−9;
 LOCAL PICO :=1ᴇ−12;
 LOCAL FEMTO:=1ᴇ−15;
 LOCAL ATTO :=1ᴇ−18;
 LOCAL ZEPTO:=1ᴇ−21;
 LOCAL YOCTO:=1ᴇ−24;
 LOCAL NMST:={" Nautical Miles"," Miles Nautique"};
 LOCAL LANGS:={"English","Français"};
 //e233
 LOCAL CHOICES:={{"ABOUT","HELP","CONVERT UNITS","MEASURE INTERVAL s","THUNDER DISTANCE","EXIT",LANGS},
 {"SUR","AIDEZ","CONVERTIR DES UNITÉS","INTERVALLE DE MESURE s","DISTANCEdeTONNERRE","AU REVOIR",LANGS}};
 EXPORT ABOUT ()
  PRINT(ST+NL+SZ);
  PRINT(THANX);
  PRINT(LGL);
  WAIT;
 MSNK()
   LOCAL SNK:=MOUSE();
 TRIMMENU(INL)
  LOCAL II;
  LOCAL OUTL:={};
  FOR II FROM 1 TO SIZE(INL)  DO
   OUTL(II):=REPLACE(STRING(INL(II)),"1_","");
  RETURN OUTL;
  LOCAL UF;
  LOCAL TTL:={"To use SI prefixes: INPUT PREFIXNAME",
    "SI préfixe: Saisissez le nom du préfixe"};
  LOCAL EVUST:={
   ": Enter value(s) using: ",
   ": Entrez le(s) valeur(s) à l aide: "};
  LOCAL HLP:=tname+EVUST(SL);
  LOCAL UST:={"Units:","Unités:"};
  LOCAL TOST:={"To ","À "};
  LOCAL CNVRT:={"Convert","Convertir"};
  menu:=TRIMMENU(unit);//AUTO
  CHOOSE(CDFROM,UST(SL)+tname,menu);
  IF CDFROM THEN
   UF:=REPLACE(STRING(unit[CDFROM]),"1_",""); //TRIM 1_
   INPUT({{ x,[2],{45,20,3} }},TTL(SL),CNVRT(SL),HLP+UF);
   //DETECT ESC
   CHOOSE(CDTO, TOST(SL)+UST(SL)+tname, menu);
   a2 := unit[CDFROM];
   a1 := unit[CDTO];
   RETURN expr(t);
  LOCAL CHSTYP;
  LOCAL TTL:={"Unit types","Types d unités"};
  LOCAL UL:={};
  CHOOSE(CHSTYP,TTL(SL),UTYP);
  CASE
    //CONVERT_Length();
    UL:={1_cd,1_flam};
   DEFAULT
  LOCAL HH,MM,SS;
  LOCAL IV:={"Interval ","Intervalle "};
  LOCAL LBL:={IV(SL)+"HH",IV(SL)+"MM",IV(SL)+"SS"};
  LOCAL HLP1:={"Decimals & Fractions allowed",
    "Décimaux et les fractions permis"};
  LOCAL HLP:={HLP1(SL),HLP1(SL),HLP1(SL)};
  LOCAL TS,KK;
  LOCAL MI:=0;
  LOCAL MST:={"MEASURE SHORT INTERVAL"+NL,
   "MESURE COURT INTERVALLE"+NL};
  LOCAL MST1:={"OK or Enter: Start"+NL,
   "OK ou Entrer: Commencez"+NL};
  LOCAL MST2:={"Enter:Enter HMS numerically"+NL,
   "Entrer: Entrez HMS numeriquement"+NL};
  LOCAL MST3:={"ANY KEY: End"+NL,
   "N importe quelle clé: Terminer"+NL};
  LOCAL ENINST:={"Enter INTERVAL","Entrez INTERVALLE"};
  TICKB:=MSGBOX(MST(SL)+MST1(SL)+MST2(SL)+MST3(SL),1);
  IF TICKB THEN
   RECT();
   TICKL:=TICKB;
   REPEAT
    MSNK;
     TICKL:=Ticks;
     RECT();
     MSNK;
     TEXTOUT_P(TS+MST(SL),0,180);
     TEXTOUT_P(MST2(SL),0,200);
     TEXTOUT_P(MST3(SL),0,220);
    WAIT(0.001);
    MSNK;
    KK:=GETKEY;
   UNTIL KK≥0;
   TICKE:=Ticks;
    MI:=3600*INPUT_INTERVAL_H(ENINST(SL));
 //INTERVAL
  LOCAL DISTM;
  LOCAL OK;
  LOCAL THDST:={};
  LOCAL TTL:=CHOICES(SL,5)+SG;
  LOCAL LBL:={{"Interval s","Temp C"},
   {"Intervalle s","Temp C"}};
  LOCAL HLP:={{"Interval sound-light. (0:use measured value)","Temp C eg 0..20:Ground −57: Aircraft"},
   {"Intervalle sonner-lumière. 0:La valeur de mesure","Temp C eg 0..20:Terre −57:Avion"}};
  OK:=INPUT({INTERVAL_S,TEMP_C},TTL,LBL(SL),HLP(SL),MEAS_INTERVAL_S,0);
  IF OK THEN
   THDKM:=THDM/1000;
   THDMI:=THDKM/TOMI;
   THDNM:=THDKM/TONM;
   THDST(4):=ROUND(THDNM,ZIPPROUND)+NMST(SL);
   RETURN THDST(2);
 ZIPP_HELP ()
  LOCAL CHS;
  LOCAL HLPST:={"HELP","AIDEZ"};
  LOCAL PFXS:={"PREFIXES","PRÉFIXES"};
  LOCAL HLPCHO:={"SI "+PFXS(SL),"VARIABLES"};
  LOCAL HC:=CONCAT(HLPCHO,CHOICES(SL));
  LOCAL SIPRFX:={"
ENTER IN UPPERCASE
YOU GET WHAT YOU SAY
Selecting Units/Prefix (Shift C) will not work."+NL,
"Entrez en majuscule
VOUS OBTENEZ QUEL CE VOUS DEMANDEZ
Selection Unites/Prefixe (Decalage C) ne marchant pas."+NL};
 LOCAL SIPRFXEG:="
3MILLI _m
3MILLI _cm
3MILLI _inch";
  LOCAL ST:={"
To change the number of digits displayed:","
Pour changez l arondissement:"};
  LOCAL STEG:="
@Home:
 ZIPPROUND:=n  [n=−12..12]"+NL;
  LOCAL CVT:={"
SI prefixes OK.
Lists and variables OK."+NL, "
Notez que toutes les unités d un groupe ne_peuvent pas etre convertis.
SI préfixes OK.
Listes et variables OK"+NL};
  CHOOSE(CHS,HLPST(SL),HC);
  IF CHS THEN
   PRINT(HC(CHS));
   CASE
    IF CHS==5 THEN PRINT(CVT(SL))  END;
    IF CHS==1 THEN PRINT(SIPRFX(SL)+SIPRFXEG) END;
    IF CHS==2 THEN PRINT(ST(SL)+STEG) END;
    IF CHS==3 THEN ABOUT() END;
    DEFAULT
   WAIT;
 SELECT_LANGUAGE()
  LOCAL CHS;
  CHOOSE(CHS,LANGS(SL),LANGS);//CURRENT
  IF CHS THEN
   SL:=CHS;
  LOCAL CHS;
  REPEAT
   CHOOSE(CHS,CRID,CHOICES(SL));
   CASE
    IF CHS==2 THEN ZIPP_HELP() END;
    IF CHS==7 THEN SELECT_LANGUAGE() END;
    DEFAULT
   //WAIT;
  UNTIL CHS==0;
 EXPORT ZIPP()
Version 0.4:
All functions improved, new functionality added and translations improved.
You will need to create an empty procedure (or comment out the call). - this procedure will be uploaded as a separate program in the next few days.
(Update: Z LIGHTS is now available, so you can install this instead of creating an empty procedure)
 LOCAL ZIPPST:="ZIPP V 0.4 ";
 LOCAL NL:=CHAR(10);
 LOCAL SL:=1;
 //IMPORT Z_LIGHTS();
 LOCAL CDFROM,CDTO;
 LOCAL THSPD_M;
 //SI PREFIXES
 LOCAL YOTTA:=1ᴇ24;
 LOCAL ZETTA:=1ᴇ21;
 LOCAL EXA  :=1ᴇ18;
 LOCAL PETA :=1ᴇ15;
 LOCAL TERA :=1ᴇ12;
 LOCAL GIGA :=1ᴇ9;
 LOCAL MEGA :=1ᴇ6;
 LOCAL KILO :=1ᴇ3;
 LOCAL HECTO:=1ᴇ2;
 LOCAL DECA :=1ᴇ1;
 LOCAL DECI :=1ᴇ−1;
 LOCAL CENTI:=1ᴇ−2;
 LOCAL MILLI:=1ᴇ−3;
 LOCAL MICRO:=1ᴇ−6;
 LOCAL NANO :=1ᴇ−9;
 LOCAL PICO :=1ᴇ−12;
 LOCAL FEMTO:=1ᴇ−15;
 LOCAL ATTO :=1ᴇ−18;
 LOCAL ZEPTO:=1ᴇ−21;
 LOCAL YOCTO:=1ᴇ−24;
 //UNITS
 LOCAL TKINDL:={"Celcius (Centigrade)","Fahrenheit","kelvin"};
 LOCAL EN:=1; LOCAL FR:=2;
 //e233
 //WORDS
 LOCAL WENTERZ:={"Enter","Entrez"};
 LOCAL WHELP:={"Help","Aide"};
 LOCAL WINTERVAL:={"Interval","Intervalle"};
 LOCAL WLIGHTS:={"Lights","Lumières"};
 LOCAL WUNITS:={"Units","Unités"};
 LOCAL WTEMPE:={"Temperature","Température"};
 LOCAL WCNVTT:={"Convert "+WTEMPE(EN),"Convertir la "+WTEMPE(FR)};
 LOCAL WCNVTU:={"Convert Units","Convertir des Unités"};
 LOCAL CHOICES:={{"ABOUT/"+WHELP(EN),WCNVTU(EN),WLIGHTS(EN),"Measure Interval s","Thunder Distance",LANGS,"EXIT"},
 {"A PROPOS/"+WHELP(FR),WCNVTU(FR),WLIGHTS(FR),"Intervalle de Mesure s","Distance de Tonnere",LANGS,"QUITTER"}};//FR:P
 EXPORT ABOUT ()
Thanks Primer."+NL;
  PRINT(ST+NL+SZ);
  PRINT(THANX);
  PRINT(LGL);
  WAIT;
 TEMP_F2C (FF)
  RETURN (FF-32)*5/9;
 TEMP_C2F(CC)
  RETURN (9/5)*CC+32;
 TEMP_K2C(KK)
   RETURN KK-273.15;
 TEMP_C2K(CC)
  RETURN CC+273.15;
 CONVERT_TEMP ()
  LOCAL OK,TKIND;
  LOCAL TEMP,TEMP_C,TEMP_F,TEMP_K;
  LOCAL TTL:=WCNVTT(SL);
  LOCAL LBL:={WUNITS(SL),WTEMPE(SL)};
  LOCAL HLP:="";
  OK:=INPUT({{TKIND,TKINDL},TEMP},TTL,LBL,HLP,1,1);
  IF OK THEN
   CASE
    IF TKIND==1 THEN //C
     TEMP_C:=TEMP;
     TEMP_F:=TEMP_C2F(TEMP_C);
     TEMP_K:=TEMP_C2K(TEMP_C);
    IF TKIND==2 THEN //F
     TEMP_F:=TEMP;
     TEMP_C:=TEMP_F2C(TEMP_F);
    IF TKIND==3 THEN //K
     TEMP_K:=TEMP;
     TEMP_C:=TEMP_K2C(TEMP_K);
    DEFAULT
  RETURN {TEMP_C+TKINDL(1),TEMP_F+TKINDL(2),TEMP_K+TKINDL(3)};
 MSNK()
   LOCAL SNK:=MOUSE();
 TRIMMENU(INL)
  LOCAL II;
  LOCAL OUTL:={};
  RETURN OUTL;
  LOCAL UF;
  LOCAL EVUST:={
   ": Enter value(s) in: ",
   ":Entrez la/les valeur(s) avec: "};//FR:P
  CHOOSE(CDFROM,WUNITS(SL)+":"+tname,menu);
  IF CDFROM THEN
   //DETECT ESC
   CHOOSE(CDTO, TOST(SL)+WUNITS(SL)+":"+tname, menu);
   a2 := unit[CDFROM];
   a1 := unit[CDTO];
   RETURN expr(t);
 CONVERT_UNITS_HP()
  LOCAL CHSTYP;
  LOCAL TTL:={"Unit types","Types d'unités"};
  LOCAL UTYP:={{"Length","Area","Volume",
   "Electricity","Light","Angle","Viscosity","Radiation"},
 {"Longueur","Surface","Volume",
    "Heure","Vitesse","Accélération","Masse","Force",
    "Energie","Puissance","Pression","Température:NON!",
    "Electricité","Lumière","Angle","Viscosité","Radiation"}};
 //TESTING:PUISSANCE(POWER) IS LONGEST INPUT STRING
  LOCAL UL:={};
  CHOOSE(CHSTYP,TTL(SL),UTYP(SL));
  CASE
    //CONVERT_Length();
   IF CHSTYP==12 THEN //TEMP
    //UL:={1_K,1_°C,1_°F};
    UL:={1_cd,1_flam};
   DEFAULT
    MSGBOX(CONVERT_UNIT_GRP(UL,UTYP(SL,CHSTYP)),1);
EXPORT CONVERT_UNITS ()
  LOCAL CHS;
  LOCAL TTL:=WCNVTU(SL)+SG;
  CHOOSE(CHS,TTL,{WCNVTT(SL),WCNVTU(SL)});
  IF CHS THEN
    CASE
     IF CHS==1 THEN MSGBOX(CONVERT_TEMP(),1); END;
     IF CHS==2 THEN CONVERT_UNITS_HP() END;
     DEFAULT
  LOCAL HH,MM,SS,OK;
  LOCAL LBL:={WINTERVAL(SL)+" HH",WINTERVAL(SL)+" MM",WINTERVAL(SL)+" SS"};
    "Décimaux et fractions autorisés"};//FR:P
  OK:=INPUT({HH,MM,SS},TTL,LBL,HLP,0,0);
  IF OK THEN
  ELSE
   RETURN 0; //CANCEL
   //HOW TO SIGNAL CANCEL?
  LOCAL TS,KK;
  LOCAL MI:=0;
  IF TICKB THEN
   RECT();
   TICKL:=TICKB;
   REPEAT
    MSNK;
     TICKL:=Ticks;
     RECT();
     MSNK;
    WAIT(0.001);
    MSNK;
    KK:=GETKEY;
   UNTIL KK≥0;
   TICKE:=Ticks;
    MI:=3600*INPUT_INTERVAL_H(WENTERZ(SL)+" "+WINTERVAL(SL));
    //IDEALLY IF A CANCEL IS DETECTED
    //OUGHT TO RESUME MEASURED TIMING
 //INTERVAL
 //CELCIUS (NORMAL RANGE)
  LOCAL DISTM;
  LOCAL OK;
  LOCAL THDST:={};
  LOCAL INTERVAL_S,TEMP_C,TEMP;
  LOCAL TKIND;
  LOCAL LBL:={WINTERVAL(SL)+" s",WUNITS(SL),WTEMPE(SL)};
  LOCAL HLP:={{"Interval sound-light. (0:use measured value)","","EG Temp C 0..20:Ground −57: Aircraft"},
   {"Intervalle son-lumière. 0:La valeur mesurée","","ex Temp C 0..20:Terre −57:Avion"}};//FR:P
  OK:=INPUT({INTERVAL_S,{TKIND,TKINDL},TEMP},TTL,LBL,HLP(SL),MEAS_INTERVAL_S,​0);
  IF OK THEN
   CASE
    IF TKIND==1 THEN TEMP_C:=TEMP END;
    IF TKIND==2 THEN TEMP_C:=TEMP_F2C(TEMP) END;
    IF TKIND==3 THEN TEMP_C:=TEMP_K2C(TEMP) END;
    DEFAULT
   THDKM:=THDM/1000;
   THDMI:=THDKM/TOMI;
   THDNM:=THDKM/TONM;
   RETURN THDST(2);
 ZIPP_HELP ()
  LOCAL CHS,OK;
  LOCAL HLPCHO:={"VARIABLES"};
  LOCAL HC:=CONCAT(CHOICES(SL),HLPCHO);
  LOCAL SIPRFX:={"
Values may include SI prefixes.
ENTER IN UPPERCASE: Selecting Units/Prefix (Shift C) will not work."+NL,
"Les valeurs peuvent inclure des SI préfixes. Entrez en majuscule: Selection Unites/Préfixe (Decalage C) ne marchant pas."+NL};
 LOCAL SIPRFXEG:="
3NANO _m
3MILLI _inch";
  LOCAL ST:={"
Pour changez la précision affichée:"};//FR:P
  LOCAL STEG:="
@Home:
  LOCAL CVT:={"
SI prefixes OK.
SI préfixes OK.
Listes et variables OK."+NL};
  LOCAL LIGHTSPROG:={"LIGHTS may be installed separately",
    "Lumières peut être installé séparément"};
  LOCAL TRBY:="Traduit par "+SG+" et ......";
  OK:=CHOOSE(CHS,WHELP(SL),HC);
  IF CHS THEN
   PRINT(HC(CHS));
   CASE
    IF CHS==2 THEN
     PRINT(CVT(SL));WAIT;
     OK:=MSGBOX(SIPRFX(SL),1);
     OK:=MSGBOX(SIPRFXEG,1);
    IF CHS==3 THEN PRINT(LIGHTSPROG(SL)) END;
    IF CHS==6 THEN PRINT(TRBY) END;
    IF CHS==8 THEN PRINT(ST(SL)+STEG) END;
    DEFAULT
   WAIT;
 SELECT_LANGUAGE()
  LOCAL CHS;
  IF CHS THEN
   SL:=CHS;
  LOCAL CHS;
  REPEAT
   CASE
    IF CHS==1 THEN ZIPP_HELP() END;
    IF CHS==2 THEN CONVERT_UNITS() END;
    IF CHS==3 THEN Z_LIGHTS() END;
    IF CHS==7 THEN CHS:=0 END;
    IF CHS==6 THEN SELECT_LANGUAGE() END;
    DEFAULT
  UNTIL CHS==0;
 EXPORT ZIPP()
Dzien dobry Panu,
Super, naprawde fajnie ! To swietnie.
Bardzo dzienkuje.
Do zobaczenia !
Gérard.
Glad you like it Gerard.
If anyone would like to see a different approach to unit conversion, have a look at epp's CNV procedure.
Here is ZIPP Version 0.5. Now with data unit conversions and improvements to language setup.
 LOCAL ZIPPST:="ZIPP V 0.5 ";
 LOCAL NL:=CHAR(10);
 LOCAL DEFLT_LANG();
 LOCAL SL:=DEFLT_LANG();
 LOCAL CDFROM,CDTO;
 LOCAL THSPD_M;
 LOCAL VBITS,VBPS,VS;
 //SI PREFIXES
 LOCAL YOTTA:=1ᴇ24;
 LOCAL ZETTA:=1ᴇ21;
 LOCAL EXA  :=1ᴇ18;
 LOCAL PETA :=1ᴇ15;
 LOCAL TERA :=1ᴇ12;
 LOCAL GIGA :=1ᴇ9;
 LOCAL MEGA :=1ᴇ6;
 LOCAL KILO :=1ᴇ3;
 LOCAL HECTO:=1ᴇ2;
 LOCAL DECA :=1ᴇ1;
 LOCAL DECI :=1ᴇ−1;
 LOCAL CENTI:=1ᴇ−2;
 LOCAL MILLI:=1ᴇ−3;
 LOCAL MICRO:=1ᴇ−6;
 LOCAL NANO :=1ᴇ−9;
 LOCAL PICO :=1ᴇ−12;
 LOCAL FEMTO:=1ᴇ−15;
 LOCAL ATTO :=1ᴇ−18;
 LOCAL ZEPTO:=1ᴇ−21;
 LOCAL YOCTO:=1ᴇ−24;
 //DATA UNITS:CAPACITY
 LOCAL UBITS:="bits";
 LOCAL UBY:="Bytes";
 LOCAL UCH:="Characters";//Characters
 LOCAL UWD:="Words(−.)";
 LOCAL DATAS:={1,8,16}; //−1};
 //DATA UNITS:THROUGHPUT
 LOCAL UBPS:="bps";
 LOCAL UBYPS:="Byte/s";
 LOCAL UCPS:="CPS";
 LOCAL UWPM:="WPM(Morse)";
 LOCAL TML:={"s","s","s"};//SIZE MATCH
 //UNITS
 LOCAL NMST:={" Nautical Miles",""," Miles Nautique"};
 LOCAL WSYS:={"System"};
 LOCAL LANGS:={"English","","Français"};
 LOCAL EN:=1; LOCAL FR:=3;
 //e233
 //WORDS
 LOCAL WCAPACITY:={"Capacity","","La Capacité"};
 LOCAL WRATE:={"Throughput","","Taux/Débit"};
 LOCAL WENTERZ:={"Enter","","Entrez"};
 LOCAL WHELP:={"Help","","Aide"};
 LOCAL WINTERVAL:={"Interval","","Intervalle"};
 LOCAL WLIGHTS:={"Lights","","Lumières","Światła"};
 LOCAL WTIME:={"Time","","Temps"};
 LOCAL WUNITS:={"Units","","Unités"};
 LOCAL WTEMPE:={"Temperature","","Température"};
 LOCAL WCNVTT:={"Convert "+WTEMPE(EN),"","Convertir la "+WTEMPE(FR)};
 LOCAL WCNVTU:={"Convert Units","","Convertir des Unités","Konwersja Jednowstek"};
 LOCAL WDATAU:={"Data Units","","Les unités de données"};
 LOCAL WSOLVE:={"Solve for","","Résoudre pour"};
 LOCAL WVALU:={"Value","","La valeur"};
 LOCAL DATATYPES:={{WCAPACITY(EN),WRATE(EN),WTIME(EN)},{"","",""},
 {WCAPACITY(FR),WRATE(FR),WTIME(FR)}};
 EXPORT ABOUT ()
Thanks Primer."+NL;
  PRINT(ST+NL+SZ);
  PRINT(THANX);
  PRINT(LGL);
  WAIT;
 TEMP_F2C (FF)
  RETURN (FF-32)*5/9;
 TEMP_C2F(CC)
  RETURN (9/5)*CC+32;
 TEMP_K2C(KK)
   RETURN KK-273.15;
 TEMP_C2K(CC)
  RETURN CC+273.15;
 CONVERT_TEMP ()
  LOCAL OK,TKIND;
  LOCAL HLP:="";
  IF OK THEN
   CASE
     TEMP_C:=TEMP;
     TEMP_F:=TEMP;
     TEMP_K:=TEMP;
    DEFAULT
  //KNOWN BUG:
  //IF U ESCAPE 0C=0F=0K RETURNED
 MSNK()
   LOCAL SNK:=MOUSE();
 DATA_UNITS()
  LOCAL VH;
  LOCAL OK,CHS,TM,TMU,QTYU,THRU,VALU,SLV;
  LOCAL QTYTP:={UBITS,UBY,UCH}; //,UWD};//BUG:SIZES MUST MATCH
  LOCAL THRUTP:={UBPS,UBYPS,UCPS}; //,UWPM};
  LOCAL TTL:={"","",""};
  LOCAL LBL:=DATATYPES(1);//{WCAPACITY(1),WRATE(1),"TIME"};
  LOCAL HLP:={"","","Select to solve for this unit type BITS BPS S ONLY!"};
  LOCAL VALUES:={};
  REPEAT
   OK:=CHOOSE(CHS,WDATAU(SL)+SG,DATATYPES(SL));
   IF OK THEN
    LBL:={DATATYPES(SL,CHS),WVALU(SL),WSOLVE(SL)};
    CASE
     IF CHS==1  THEN //CAPACITY
      OK:=INPUT({{QTYU,QTYTP},VALU,{SLV,1}},TTL,LBL,HLP,1,1);
      IF OK THEN
       IF SLV THEN //B=BPS*S
        VBITS:=VS*VBPS;
       ELSE
        VBITS:=VALU*DATAS(QTYU);
       VALUES:=VBITS/{DATAS};
       MSGBOX(VALUES);
     IF CHS==2  THEN //THROUGHPUT
      OK:=INPUT({{THRU,THRUTP},VALU,{SLV,1}},TTL,LBL,HLP,1,1);
      IF OK THEN
       IF SLV THEN //BPS=B/S
        VBPS:=VBITS/VS;
       ELSE
        VBPS:=VALU*DATAS(THRU);
       VALUES:=VBPS/{DATAS};
       MSGBOX(VALUES);
     IF CHS==3 THEN //TIME
      OK:=INPUT({{TMU,TML},VALU,{SLV,1}},TTL,LBL,HLP,1,1);
      IF OK THEN
       IF SLV THEN //S=B/BPS
        //MSGBOX(VBITS);
        VS:=VBITS/VBPS;
       ELSE
        VS:=VALU;
       VH:=VS/60/60;
       MSGBOX({VS,→HMS(VH)});
     DEFAULT
  UNTIL CHS==0;
TRIMMENU(INL)
  LOCAL II;
  LOCAL OUTL:={};
  RETURN OUTL;
  LOCAL UF;
  LOCAL TTL:={"To use SI prefixes: INPUT PREFIXNAME","",
  LOCAL EVUST:={
   ": Enter value(s) in: ","",
  LOCAL TOST:={"To ","","À "};
  LOCAL CNVRT:={"Convert","","Convertir"};
  IF CDFROM THEN
   //DETECT ESC
   a2 := unit[CDFROM];
   a1 := unit[CDTO];
   RETURN expr(t);
 CONVERT_UNITS_HP()
  LOCAL CHSTYP;
  LOCAL TTL:={"Unit types","","Types d'unités"};
   "Electricity","Light","Angle","Viscosity","Radiation",
   "","Data Throughput"},
  LOCAL UL:={};
  CASE
    //CONVERT_Length();
    UL:={1_cd,1_flam};
   IF CHSTYP==19 THEN //DATA THROUGHPUT
    UL:={"BPS","bps"};
   DEFAULT
    IF CHSTYP≤17 THEN //HP
    //ELSE //SL
    // CONVERT_GRP_SL(UL,UTYP(SL,CHSTYP));
  LOCAL CHS;
  CHOOSE(CHS,TTL,{WCNVTT(SL),WCNVTU(SL),WDATAU(SL)});
  IF CHS THEN
    CASE
     IF CHS==3 THEN DATA_UNITS() END;
     DEFAULT
  LOCAL HH,MM,SS,OK;
  LOCAL HLP1:={"Decimals & Fractions allowed","",
  IF OK THEN
  ELSE
   RETURN 0; //CANCEL
  LOCAL TS,KK;
  LOCAL MI:=0;
  LOCAL MST:={"MEASURE SHORT INTERVAL"+NL,"",
  LOCAL MST1:={"OK or Enter: Start"+NL,"",
  LOCAL MST2:={"Enter:Enter HMS numerically"+NL,"",
  LOCAL MST3:={"ANY KEY: End"+NL,"",
  IF TICKB THEN
   RECT();
   TICKL:=TICKB;
   REPEAT
    MSNK;
     TICKL:=Ticks;
     RECT();
     MSNK;
    WAIT(0.001);
    MSNK;
    KK:=GETKEY;
   UNTIL KK≥0;
   TICKE:=Ticks;
 //INTERVAL
  LOCAL DISTM;
  LOCAL OK;
  LOCAL THDST:={};
  LOCAL TKIND;
  LOCAL HLP:={{"Interval sound-light. (0:use measured value)","","EG Temp C 0..20:Ground −57: Aircraft"},{},
  IF OK THEN
   CASE
    DEFAULT
   THDKM:=THDM/1000;
   THDMI:=THDKM/TOMI;
   THDNM:=THDKM/TONM;
   RETURN THDST(2);
 ZIPP_HELP ()
  LOCAL CHS,OK;
  LOCAL SIPRFX:={"
ENTER IN UPPERCASE: Selecting Units/Prefix (Shift C) will not work."+NL,"",
 LOCAL SIPRFXEG:="
3NANO _m
3MILLI _inch";
  LOCAL ST:={"
To change the number of digits displayed:","","
  LOCAL STEG:="
@Home:
  LOCAL CVT:={"
SI prefixes OK.
Lists and variables OK."+NL,"", "
SI préfixes OK.
  LOCAL LIGHTSPROG:={"LIGHTS may be installed separately","",
  IF CHS THEN
   PRINT(HC(CHS));
   CASE
    IF CHS==2 THEN
    DEFAULT
   WAIT;
 DEFLT_LANG()
  LOCAL DEF:=1;//PROG DEFAULT
  IF Language==1  OR Language==3 THEN
   DEF:=Language;
  RETURN DEF;
 SELECT_LANGUAGE()
  LOCAL CHS;
  //LOCAL DEF:=1;//PROG DEFAULT IF LANG UNKNOWN
  CHOOSE(CHS,LANGS(SL),CONCAT(LANGS,{WSYS(1)}));//CURRENT
  IF CHS AND CHS≠2 THEN
   SL:=CHS;
   IF CHS==4 THEN SL:=DEFLT_LANG(); END;
  LOCAL CHS;
  SL:=DEFLT_LANG();
  REPEAT
   CASE
    DEFAULT
  UNTIL CHS==0;
 EXPORT ZIPP()
Ignore the reference in input help to "solve for" only working in bit and bps - it should actually work in bytes etc. too.
In ZIPP 0.6, the unit conversions are moved to a standalone program (Z UNITS), callable from ZIPP. Compiled using Android emulator 1.0.9.
 LOCAL ZIPPST:="ZIPP V 0.6 ";
 LOCAL NL:=CHAR(10);
 LOCAL DEFLT_LANG();
 //IMPORT Z_UNITS();
 LOCAL THSPD_M;
 //SI PREFIXES:UNUSED
 LOCAL YOTTA:=1ᴇ24;
 LOCAL ZETTA:=1ᴇ21;
 LOCAL EXA  :=1ᴇ18;
 LOCAL PETA :=1ᴇ15;
 LOCAL TERA :=1ᴇ12;
 LOCAL GIGA :=1ᴇ9;
 LOCAL MEGA :=1ᴇ6;
 LOCAL KILO :=1ᴇ3;
 LOCAL HECTO:=1ᴇ2;
 LOCAL DECA :=1ᴇ1;
 LOCAL DECI :=1ᴇ−1;
 LOCAL CENTI:=1ᴇ−2;
 LOCAL MILLI:=1ᴇ−3;
 LOCAL MICRO:=1ᴇ−6;
 LOCAL NANO :=1ᴇ−9;
 LOCAL PICO :=1ᴇ−12;
 LOCAL FEMTO:=1ᴇ−15;
 LOCAL ATTO :=1ᴇ−18;
 LOCAL ZEPTO:=1ᴇ−21;
 LOCAL YOCTO:=1ᴇ−24;
 //UNITS
 LOCAL WSYS:={"System","","Système"};
 //e233
 //WORDS
 LOCAL CHOICES:={{"ABOUT/"+WHELP(EN),WLIGHTS(EN),"Measure Interval s","Thunder Distance",WUNITS(EN),LANGS,"EXIT"},
 {"A PROPOS/"+WHELP(FR),WLIGHTS(FR),"Intervalle de Mesure s","Distance de Tonnere",WUNITS(FR),LANGS,"QUITTER"}};//FR:P
 EXPORT ABOUT ()
  LOCAL THANX:="Thanks Primer."+NL;
  PRINT(ST+NL+SZ);
  PRINT(THANX);
  PRINT(LGL);
  WAIT;
 TEMP_F2C (FF)
  RETURN (FF-32)*5/9;
 TEMP_K2C(KK)
   RETURN KK-273.15;
 MSNK()
   LOCAL SNK:=MOUSE();
  LOCAL HH,MM,SS,OK;
  IF OK THEN
  ELSE
   RETURN 0; //CANCEL
  LOCAL TS,KK;
  LOCAL MI:=0;
  IF TICKB THEN
   RECT();
   TICKL:=TICKB;
   REPEAT
    MSNK;
     TICKL:=Ticks;
     RECT();
     MSNK;
    WAIT(0.001);
    MSNK;
    KK:=GETKEY;
   UNTIL KK≥0;
   TICKE:=Ticks;
  MEAS_INTERVAL_S:=MI;
  RETURN ROUND(MI,ZIPPROUND);
 //INTERVAL
  LOCAL DISTM;
  LOCAL OK;
  LOCAL THDST:={};
  LOCAL TKIND;
  LOCAL TTL:=CHOICES(SL,4)+SG;
  IF OK THEN
   CASE
    DEFAULT
   THDKM:=THDM/1000;
   THDMI:=THDKM/TOMI;
   THDNM:=THDKM/TONM;
   RETURN THDST(2);
 ZIPP_HELP ()
  LOCAL CHS,OK;
  LOCAL ST:={"
  LOCAL STEG:="
@Home:
  LOCAL MAYBIS:={" may be installed separately","",
    " peut être installé séparément"};
  REPEAT
   IF CHS THEN
    PRINT(HC(CHS));
    CASE
     IF CHS==2  OR CHS==5 THEN PRINT(MAYBIS(SL)) END;
     DEFAULT
    WAIT;
  UNTIL CHS==0;
 DEFLT_LANG()
   DEF:=Language;
  RETURN DEF;
 SELECT_LANGUAGE()
  LOCAL CHS;
  CHOOSE(CHS,LANGS(SL),CONCAT(LANGS,{WSYS(SL)}));//CURRENT
   SL:=CHS;
  LOCAL CHS;
  SL:=DEFLT_LANG();
  REPEAT
   CASE
    IF CHS==2 THEN Z_LIGHTS() END;
    IF CHS==3 THEN MSGBOX(MEASURE_INTERVAL_S()+" s",1) END;
    IF CHS==4 THEN THUNDER_DISTANCE() END;
    IF CHS==5 THEN Z_UNITS() END;
    DEFAULT
  UNTIL CHS==0;
 EXPORT ZIPP()
Dear friend,
I downloaded your app, but i cannot or maybe I dont know hot to install it. Sorry because I´m very new in this, but really before writting you I´ve tried a lot of things to do it but still haven´t found the way.
I´ll appreciate any help you can provide me.
I got a HP Prime.
Thanks in advance...
(03-04-2016 03:27 AM)meseguer24 Wrote: [ -> ]Dear friend,
I got a HP Prime.
Welcome.
The ZIPP program requires 2 external programs.
If you are getting a compilation error at Z_LIGHTS or Z_UNITS, this means that you must first install those programs - alternatively, insert // at the start of those lines to comment out those programs.
A compilation error anywhere else probably indicates a difficulty with the Unicode space character in cutting and pasting the source code. Try deleting a line and retyping it.
Note: These are programs. They do not need installing as apps.
If that does not help, could you give some indication of the error you are having.
If that solved it, please let me know.
http://www.hpmuseum.org/forum/thread-12369.html
KeithB suggested that I mention that this program includes a timer that can be used as a simple stopwatch, to help anyone searching for "stopwatch"...
Though if you want a dedicated stopwatch, there is much scope for improvement.
My short interval timer here currently relies upon TICKS.
In http://www.hpmuseum.org/forum/thread-12369.html Cyrille suggests that ticks can be less accurate than using time/date functions, so I might implement another timer later.
The thunderstorm distance calculations and interval timer are now implemented in Python. It also includes inverse functions.
https://my.numworks.com/python/steveg1cmz
(I'm not sure how much precision is reasonable - I'm probably showing too many digits)
