10-19-2015, 03:37 PM
(Mostly for Bernard)
I am aware of the ability for XCas to switch to maple and ti mode for code compatibility. I was wondering if there is a similar mode switch so that one may simply copy HP Prime CAS programs directly from the calculator/virtual calculator into XCas and run it directly.
At the moment, I have to to manually change all BEGIN-END pairs for code blocks to { and }:; and lower modify indices of matrix[i,j] to matrix[i-1,j-1]. The HP Prime code resembles maple syntax for some things (indices) but not everything (equality checks are == on the Prime and = in maple) so it seems maple compatibility mode does not work directly.
Any suggestion?
Any suggestion?
