10-12-2015, 07:19 PM
10-13-2015, 06:44 AM
Yes, it should.
10-16-2015, 03:16 PM
Does using return(param) within a subroutine truncate any digits? One of the issues I have found is that matrix multiplication (row vector times column vector) gives me a slightly different result than calling a subroutine that does the multiplication and returns the inner product (the former is more accurate than the latter it seems). That is, t:=b*v; seems more accurate in the long run (which I use later on to for something else) than t:=inprod(b,v); where inprod(); is a cas routine whose code is:
inprod(b,v):=
local d,k;
local s;
d:=dim(v);
s:=0;
d:=d[1];
for k from 1 to d do
s:=s + b[1,k]*v[k,1];
end;
return(s);
10-17-2015, 04:05 PM
This might happen because the intermediate conversions double <-> giac::gen are not exactly the same in both processes. Every time a double is stored in a giac::gen, the 5 less significant bits are replaced by the type field, and in the other direction the 5 less significant bits are set to 0.
