10-11-2015, 06:48 AM
The programme ISSQ? economically detects whether an integer is a perfect square, returning 1. for yes, 0. for no.
A problem arises in compiling the programme: the ZINTs in bold type have been processed through the command
FPTR2 ^Z>ZH
& are in fact hexadecimal ZINTs - the on-calculator compiler attempts to return the four numbers as decimal ZINTs, thus debilitating the programme.
Similarly, the decompiler produces the programme as here printed, not indicating the hexadecimal nature of the ZINTs.
Anyone have a solution to this compilation problem?
ISSQ?
CK1&Dispatch
# FF
1LAMBIND
TRUE
ZINT 23;
ZINT 11
ZINT 1218:019866014613
ZINT 65
ZINT 402483012450293
ZINT 63
ZINT 202021202030213
ZINT 64
BINT5
ONE_DO
1GETLAMSWAP_
FPTR2 ^ZMod
FPTR2 ^Z>#
FPTR2 ^ZBit?
SWAPDROP
?SEMI
ISTOP-INDEX
#2*
#1-
NDROP
FALSE
ExitAtLOOP
LOOP
1GETABND
SWAP
NOTcsdrpfls
DUP
Z2_
Z<
DUP
?SEMI
DROPDUP
FPTR2 ^Z>ZH
FPTR2 ^ZBits
BINT2
Z2_
SWAP
FPTR2 ^PPow#
SWAPDROPDUP
3PICKOVER
FPTR2 ^ZQUOText
FPTR2 ^QAdd
Z2_
FPTR2 ^ZQUOText
2DUP
Z>
NOT_UNTIL
DROPDUP
FPTR2 ^ZSQ_
ROT
EQUAL
SWAPDROP
COERCEFLAG
FPTR2 ^Z>ZH
ISSQ?
CK1&Dispatch
# FF
1LAMBIND
TRUE
ZINT 23;
ZINT 11
ZINT 65
ZINT 63
ZINT 64
BINT5
ONE_DO
1GETLAMSWAP_
FPTR2 ^ZMod
FPTR2 ^Z>#
FPTR2 ^ZBit?
SWAPDROP
?SEMI
ISTOP-INDEX
#2*
#1-
NDROP
FALSE
ExitAtLOOP
LOOP
1GETABND
SWAP
NOTcsdrpfls
DUP
Z2_
Z<
DUP
?SEMI
DROPDUP
FPTR2 ^Z>ZH
FPTR2 ^ZBits
BINT2
Z2_
SWAP
FPTR2 ^PPow#
SWAPDROPDUP
3PICKOVER
FPTR2 ^ZQUOText
FPTR2 ^QAdd
Z2_
FPTR2 ^ZQUOText
2DUP
Z>
NOT_UNTIL
DROPDUP
FPTR2 ^ZSQ_
ROT
EQUAL
SWAPDROP
COERCEFLAG
