I have very mysterious problems with the AND function in a program if statement.
The program misbehaves until i remove the AND and use two ifs.
E.e
IF ((expr1) AND (expr2)) THEN ....
fails with bad argument error somewhere in the code.
IF (expr1) THEN
IF (expr2) THEN
make the gremlins go away.
Seems odd.
(10-11-2015 01:23 AM)ji3m Wrote: [ -> ]I have very mysterious problems with the AND function in a program if statement.
E.e
IF (expr1) THEN
IF (expr2) THEN
Seems odd.
You can place a DEBUG; statement right before where you think the error occurs and then run the program and this will pull up the debugger so you can see the real cause.
E.e
IF (expr1) THEN
IF (expr2) THEN
Seems odd.
If expr2 has an error in it, the second example works because the IF never gets evaluated if the first IF is false. HPPL, as in most forms of BASIC, evaluates all expressions in an AND statement. There's no early exit if the first part of the AND is false.
Example:
IF 4<2 AND 1/0 >3 THEN
<do something here>
will fail because 1/0 is illegal.
IF 4<2 THEN
IF 1/0>3 THEN
<do something here>
will work because the 1/0 never gets evaluated.
