10-10-2015, 10:52 PM
How to use head and tail with strings inside a program?
It seems quite inconsistent:
Inside a program it seems to work like as in HOME, with or without CAS. in front
HOME:
tail("hola"); // return empty matrix
head("hola"); // return the same string
Syntax error if used uppercades (with msgbox)
CAS:
tail("hola"); // correct
head("hola"); // correct
Weird error if used uppercased (no msgbox) but return:
of(["Error: Bad Argument Value"])
