10-08-2015, 12:03 PM
I made a small function browser for prime.
run the program by FBrowser.
Features :
Download : [attachment=2650]
Version 0.1 : 8th of Oct 2015.
I may change few things in UI.
[attachment=2648]
Let me know your feeling...
I've a idea for a feature that may take time to be built... too early to speak about
Features :
- identify function definition, display their names and params (remove comments)
- display line number
- visually show function decorators (exported in green, keys assign in orange)
- user interface : move with up/down key, it scrolls the screen if needed (no mouse yet, sorry)
- user interface : close with ESC. press ENTER to jump to line nr (well, actually it just display a msgbox because such function does not exist... Tim ? )
- it exports "fct" variable (list of function names)
// functions browser v 0.1
// by primer - 8th of Oct 2015
#pragma mode( separator(.,;) integer(h32) )
//frw decl
pickPrg();
Analyse(p);
display();
EXPORT FBrowser() // functions browser entry point.
local p:=pickPrg();
if p≠"" then
Analyse(p);
display();
end;
pickPrg() // to pick a prog name
begin
local prgs:=Programs;
local p;
choose(p,"Fct Browse to program",prgs);
if p==0 then return ""; end;
return prgs(p);
end;
collectFcts(p); //frw decl
///----------- Analysis ------------
// perform analysis on a program
Analyse(p)
begin
collectFcts(p);
end;
/////////////////////// public vars
export fct;
export fctn;
analyseline(l,n); //frw decl
collectFcts(p)
begin
local src:=Programs(p);
local s:=size(src);
local n:=1;
local i,c,l;
fct:={};
fctn:={};
l:="";
for i from 1 to s do
c:=mid(src,i,1);
if c==char(10) then // line feed
analyseline(l,n);
n:=n+1; // inc lin nr
l:="";
else
l:=l+c;
end;
end; // for
analyseline(l,n);
end;
//frw decl
trim(x);
trim_cmt(x);
register_fct(txt,n);
// statics vars
local prev:="";
local nprev:=0;
analyseline(l,n) // analyse la ligne
begin
local a:=trim(trim_cmt(l));
if upper(a)=="BEGIN" then
register_fct(prev,nprev);
prev:="";
else
if a≠"" then prev:=a; nprev:=n; end;
end; // begin
end;
register_fct(txt,n) // save function information
begin
// print("L"+n+" : "+txt);
local a:=upper(txt);
local p:=instring(a,"EXPORT ");
local export:=0;
local pars:="";
local nopar:=0;
if p==1 then
txt:=trim(mid(txt,p+6));
export:=1;
end;
p:=instring(a,"KEY ");
if p==1 then
txt:=trim(mid(txt,p+3));
export:=2; // it's a key assign
nopar:=1; // no need for params
end;
// check is ends with ";", it should not
if right(txt,1)==";" then return; end; // fausse alerte
if nopar==1 then
pars:="";
else
p:=instring(txt,"(");
if p==0 then return; end; // fausse alerte :^)
pars:=mid(txt,p);
txt:=left(txt,p-1);
end;
fct:=concat(fct,txt);
fctn:=concat(fctn, {{n, export, pars}});
end;
trim_cmt(x) // remove cmt
begin
local p:=instring(x,"//");
if p==0 then return x; end;
if p==1 then return ""; end;
return mid(x,1,p-1);
end;
trim(x) // l/r trim
begin
local s:=size(x);
if s==0 then return ""; end;
local i,a;
local ok:=0;
//debug;
//left trim
if mid(x,i,1)≠" " then
if i==1 then a:=x; else a:=mid(x,i); end;
ok:=1;
break;
end; //if
end; //for
if ok==0 then return ""; end;
//right trim
s:=size(a);
for i from s downto 1 do
if mid(a,i,1)≠" " then
a:=mid(a,1,i);
break;
end; //if
end; //for
return a;
end;
//#missing hppl fct : split, trim, mid(x,?,0)->"", mid(x,0)???
///----------- user interface ------------
// frw decl
initdsp();
dsploop();
display()
begin
initdsp();
dsploop();
end;
initdsp() // prepare G9 with all fcts from <ftc> + <ftcn> vars
begin
local h:=SIZE(fct)*12;
local i,t,x,p;
DIMGROB_P(G9,300,h);
for i from 1 to size(fct) do
t:=fct(i);
x:=fctn(i,2); // export y/n
p:=fctn(i,3); // pars
TEXTOUT_P(t,G9,10,(i-1)*12,2,#0h); // fct name
TEXTOUT_P(p,G9,100,(i-1)*12,2,#444444h); // params
if x==1 then RECT_P(G9,1,1+(i-1)*12,8,(i*12)-2,#21AC0Dh,#29D810h); end; // exported
if x==2 then RECT_P(G9,1,1+(i-1)*12,8,(i*12)-2,#E7B00Eh,#F4CE59h); end; // key
end;
end;
dsploop()
begin
local f:=0; // ends the display loop
local k; // key
local pos:=1; // position
local t; // temp txt
local voffs:=0; // vertical offset
while f==0 do
RECT_P(); // clean screen
BLIT_P(G0,40,1,G9,1,1+voffs);
RECT_P(G0,1,(pos-1)*12-voffs,320,pos*12-voffs, {#54A7FAh, 127},{#54A7FAh, 127}); // selector
t:=fctn(pos,1); // line nr
TEXTOUT_P(t,G0,1,(pos-1)*12-voffs,2,#FFFFFFh,40,#0h); // fct name
k:=wait();
if k==30 then f:=1; msgbox("Jump to line "+fctn(pos,1)); end; // enter
if k==4 then f:=1; end; // esc
if k==2 then // up
pos:=max(pos-1,1);
if pos*12-voffs<1 then voffs:=voffs-12; end; // move veiwport up
end;
if k==12 then // down
pos:=min(pos+1,size(fct));
if pos*12-voffs>228 then voffs:=voffs+12; end; // move veiwport down
end;
end; // while
end;
